SMT POWER INDUCTORS
Shielded Drum Core - PL95XX Series
Ruggedized
Height: 0.122 inches (3.1mm) Max
Footprint: 0.256 inches x 0.256 inches (6.5mm x 6.5mm) Max
Inductance Range: 2.15µH to 85.39µH
Current Rating: up to 2.60A
Moisture Sensitivity Level: 1
Electrical Specifications @ 25 °C — Operating Temperature - 5 5 °C to +130 °C
DCR (mΩ )
Irated 2
Saturation 3
Inductance
Inductance
(µH TYP)
(A)
TYP
15.3
24.9
49.9
54
72
82
102
119
146
183
210
230
305
351
419
520
@0ADC
(A) @25°C
Heating 4
Current
3.45
3.31
2.84
2.70
2.37
2.19
2.01
1.76
1.65
1.44
1.33
1.26
1.08
0.97
0.96
0.86
0.81
0.75
0.66
*Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts.
Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL9501 becomes PL9501T).
Notes from Tables
4. The heating current is the DC current, which causes the temperature
of the part to increase by approximately 40°C. This current is
1. Temperature of the component (ambient plus temperature 5. etermined by extending the terminals of the component with 30mm
rise) must be within specified operating temperature range.
length 28 gauge buss wires and applying the current to the device for
2. The rated current as listed is either the saturation current or
30 minutes. The temperature is measured by placing the thermo-couple
the heating current depending on which value is lower.
between the winding and the shield.
3. The saturation current is the current which causes the
6. In high volt*time applications, additional heating in the component can
inductance to drop to 75% of its initial inductance at zero
occur due to core losses in the inductor which may necessitate derating
bias. This current is determined by placing the component at
the current in order to limit the temperature rise of the compo-nent. In
room ambient (25°C), and applying a short duration pulse
order to determine the approximate total loss (or temperature rise) for a
current (to eliminate
given application, both copper losses and core losses should be taken into
self-heating effects) to the component.
account.
1
www.inrcore.com
M124.J (07/20)
SMT POWER INDUCTORS
Ruggedized
Electrical Schematic
Mechanical
Percentage of the intitial inductance�
Schematic
Inductance vs. Current Characteristics
120%
100%
80%
60%
40%
20%
0%
0.0
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
Normalized Isat
2
www.inrcore.com
M124.J (07/20)
SMT POWER INDUCTORS
Ruggedized
For More Information
Global Sales Representatives and Lo cations:
http://www.inrcore.com
iNRCORE,LLC
311 Sinclair Road Bristol,
PA 19007-6812 U.S.A
Tel: + 1.215.781.6400
Fax: +1.215.7816430
Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names
mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved.
3
www.inrcore.com
M124.J (07/20)
很抱歉,暂时无法提供与“PL9518”相匹配的价格&库存,您可以联系我们找货
