PL9318T
PL9318T
    INRCORE
    SMD-4P,10.4x10.4mm
    固定电感器 Nonstandard 330µH ±20% 600mA 1.133Ω
PL9318T 数据手册
SMT POWER INDUCTORS Shielded Drum Core - PL93XX Series Ruggedized Height: 0.157 inches (4.0mm) Max Footprint: 0.410 inches x 0.410 inches (10.5mm x 10.5mm) Max Inductance Range: 0.62µH to 278µH Current Rating: up to 7.6A Moisture Sensitivity Level: 1 Part Numbers PL9301 PL9302 PL9303 PL9304 PL9305 PL9306 PL9307 PL9308 PL9309 PL9310 PL9311 PL9312 PL9313 PL9314 PL9315 PL9316 PL9317 PL9318 Electrical Specifications @ 25 °C — Operating Temperature - 5 5 °C to +130 °C Inductance @Irated DCR (mΩ) Inductance Irated 2 Saturation3 (A) @0ADC (µH) Current (A) @25°C TYP MAX (µH TYP) 0.62 1.2 1.9 2.8 4.0 5.4 6.9 8.0 11 12 19 25 38 55 83 123 178 278 7.60 7.10 5.80 5.20 4.70 3.70 3.50 3.40 3.00 2.80 2.30 2.10 1.65 1.32 1.10 0.88 0.73 0.60 4.2 5.6 8.4 10.2 15.1 20.8 23.7 26.5 36.1 39.5 62 71 113 170 262 400 591 906 5.5 7.3 10.9 13.3 19.6 27.0 30.8 33.2 45.2 49.4 77 89 142 212 328 500 739 1133 *Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts. Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL9301 becomes PL9301T). Mechanical 1 www.inrcore.com 0.68±25% 1.3±25% 2.2±25% 3.3±25% 4.7±25% 6.0±25% 7.6±25% 10±20% 12±20% 15±20% 22±20% 27±20% 47±20% 68±20% 100±20% 150±20% 220±20% 330±20% Heating4 Current (A) 10.00 8.00 6.15 5.80 5.40 4.50 4.00 3.80 3.40 3.10 2.80 2.30 2.10 1.50 1.35 1.15 0.92 0.70 7.60 7.10 5.80 5.20 4.70 3.70 3.50 3.40 3.00 2.80 2.30 2.10 1.65 1.32 1.10 0.88 0.73 0.60 NOTES FROM TABLE: (See back page) Electrical Schematic M120.E (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL93XX Series Ruggedized Notes from Tables Percentage of the intitial inductance� 4. The heating current is the DC current, which causes the temperature of the part to increase 1. Temperature of the component (ambient plus temperature rise) must be by approximately 40°C. This current is determined by extending the within specified operating temperature range. terminals of the component with 30mm length 28 gauge buss wires and 2. The rated current as listed is either the saturation current or the heating applying the current to the device for 30 minutes. The temperature is current depending on which value is lower. measured by placing the thermo-couple between the winding and the 3. The saturation current is the current which causes the inductance to drop shield. to 75% of its initial inductance at zero bias. This current is determined 5. In high volt*time applications, additional heating in the component can by placing the component at room ambient (25°C), and applying a occur due to core losses in the inductor which may necessitate derating short duration pulse current (to eliminate self-heating effects) to the the current in order to limit the temperature rise of the compo-nent. In component. order to determine the approximate total loss (or temperature rise) for a given application, both copper losses and core losses should be taken into account. Inductance vs. Current Characteristics 120% 100% 80% 60% 40% 20% 0% 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 Normalized Isat 2 www.inrcore.com M120.E (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL93XX Series Ruggedized For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 3 www.inrcore.com M120.E (07/20)
PL9318T 价格&库存
很抱歉,暂时无法提供与“PL9318T”相匹配的价格&库存,您可以联系我们找货
