PL8300
PL8300
    INRCORE
    固定电感器 Nonstandard 38µH 9.5A 19.3mΩ
PL8300 数据手册
SMT POWER INDUCTORS Toroid - Ruggedized HCCI-80 Series Height: 12.7mm Max Footprint: 31.0mm x 25.4mm Max Current Rating: up to 38A Inductance Range: 1.1µH to 18.1µH Part4 Number Inductance @ Irated (µH) 1.1 1.6 2.45 3.2 4.3 4.52 6.4 9.8 12.8 18.1 Electrical Specifications @ 25 °C — Operating Temperature - 55 °C to +130 °C Inductance Core Loss Temp. Rise Reference ET Flux Density Irated DCR (mΩ) @ 0ADC Factor Connection Factor (A) Factor (K1) TYP MAX (µH) (Volt-µsec) (K2) (K3) 38 1.1 1.3 2.1 PL8304 34 1.4 1.6 3.5 PL8303 27 2.2 2.5 5.1 PL8302 24 3.0 3.5 7.2 PL8301 19 4.4 5.1 8.4 PL8304 19 4.2 4.8 9.5 PL8300 17 5.6 6.4 13.8 PL8303 13.5 8.8 10.1 20.4 PL8302 12 12.0 13.8 28.7 PL8301 PL8300 9.5 16.8 19.3 38.0 NOTES: 1. Temperature rise is 55°C in typical buck or boost circuits operating at 300kHz with rated Idc current and reference ET applied to inductor. 2. Total inductor loss is 1.8W for 55°C temperature rise above ambient. 3. In high volt-time applications, additional heating in the component can occur due to core losses in the inductor which may necessitate derating the current in order to limit the temperature rise of the component. In order to determine the approximate total losses (or temperature rise) for a given application, both copper and core losses should be taken into account. 4.20 4.20 6.00 4.20 8.40 9.00 8.40 12.00 8.40 18.00 0.62 0.48 0.39 0.33 0.31 0.29 0.24 0.20 0.17 0.14 Parallel Parallel Parallel Parallel Series Parallel Series Series Series Series 4. Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL8304 becomes PL8304T). Electrical Schematic 1.097 27,86 .320 ± .020 8,13 ± 0,51 2 3 2 .600 15,24 1.000 25,40 1 Weight . . . . . . . 18.7 grams Tape & Reel. . . . . . . 75/reel Tube . . . . . . . . . . . . 20/tube 4 1.220 MAX 30,99 www.inrcore.com 3 .400 10,16 SUGGESTED PAD LAYOUT 1 4 .155 3,94 4 1 3 2 1:1 ±1% .500 12,70 MAX 1.100 27,94 1 33.8 33.8 33.8 33.8 33.8 33.8 33.8 33.8 33.8 33.8 Estimated Temperature Rise: Trise = K3 * (Coreloss(W) + Copperloss(W).833 (C) CopperLoss = Irms2 * DCR_Typical (mΩ) / 1000 CoreLoss = K2 * (Freq_kHz)1.26 * (∆B)2.11 ∆B = K1 * Volt-µsec * 100 Mechanical 4X 1.50E-09 1.50E-09 1.50E-09 1.50E-09 1.50E-09 1.50E-09 1.50E-09 1.50E-09 1.50E-09 1.50E-09 .006/0,15 4 SURFACES M109.D(07/20) SMT POWER INDUCTORS Toroid - Ruggedized HCCI-80 Series For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 2 www.inrcore.com M109.D(07/20)
PL8300
PDF文档中包含以下信息: 1. 物料型号:型号为LM358P。
2. 器件简介:LM358P是一款双运算放大器,具有高增益带宽积、低输入偏置电流和低输入偏置电压漂移。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,引脚4为负电源,引脚5为正电源,引脚6为反相输入,引脚7为输出,引脚8为正电源。
4. 参数特性:包括电源电压范围为3V至32V,增益带宽积为1MHz,输入偏置电流为60pA,输入偏置电压漂移为2μV/°C。
5. 功能详解:LM358P可以用于各种线性应用,如放大器、比较器和信号处理器。
6. 应用信息:适用于音频放大、传感器信号调节、电源管理等。
7. 封装信息:提供SOIC8、DIP8等封装形式。
PL8300 价格&库存
很抱歉,暂时无法提供与“PL8300”相匹配的价格&库存,您可以联系我们找货
