PL8133T
PL8133T
    INRCORE
    SMD,18.4x14.6mm
    固定电感器 Nonstandard 1.134mH 740mA 1.25Ω
PL8133T 数据手册
SMT POWER INDUCTORS Toroid SLED Series Ruggedized Ruggedized header with SLED rails for secure board mounting Four package sizes Current Rating: up to 14.3ADC Frequency Range: up to 1MHz Moisture Sensitivity Level: 1 Electrical Specifications @ 25 °C — Operating Temperature - 55 °C to +130 °C Irated (µH) @ 0ADC (Volt-µsec) Factor (K1) Temp. Rise Factor (K2) Factor (K3) SLED 20 PL8102 17.6 1.00 106.25 125 22.7 2.4 1.21 3.29E-11 323.9 323.9 323.9 3.8 9.4 29.7 4.80 2.80 1.40 14.705 36.89 141.1 17.3 43.4 166 5.2 12.3 35.3 1.76 2.7 4.6 1.28 0.83 0.49 1.39E-10 1.39E-10 1.39E-10 148.0 148.0 148.0 148.0 5.1 16.2 4.9 9 29.1 0.81 5.40 2.70 7.80 5.50 2.70 14.30 15.045 63 10.54 25 85 2.125 17.7 72 12.4 28 100 2.5 7.5 21.9 7.9 14 40.5 1.25 2.51 4.29 3.04 4.06 6.9 1.035 0.92 0.54 0.67 0.51 0.30 2.23 1.87E-10 1.87E-10 3.35E-10 3.35E-10 3.35E-10 1.87E-10 114.2 114.2 114.2 114.2 114.2 114.2 85.7 85.7 85.7 85.7 114.2 114.2 PL8140 7.20 15.895 18.7 9.3 PL8141 5.10 27.2 32.0 16.1 PL8142 2.60 113.05 133 50 3.5 PL8170 12.40 5.61 6.6 5.2 PL8180 15.40 5.27 6.2 9.4 PL8181 10.90 10.5 12.3 NOTES: 1. Reference values are for an inductor with a 55°C temperature rise. The core loss is 10% of the copper loss at the ET listed and 500kHz. 2. Core does not saturate abruptly. The ET and DC current are limited by the desired inductance and temperature rise. 3. In high volt-time applications, additional heating in the component can occur due to core losses in the inductor which may necessitate derat-ing the current in order to limit the temperature rise of the component. In order to determine the approximate total losses (or temperature rise) for a given application, both copper and core losses should be taken into account. 16 25.9 72.9 6.5 4.92 6.27 10.5 3.1 0.41 0.32 0.19 0.64 4.52E-10 4.52E-10 4.52E-10 4.52E-10 67.9 67.9 67.9 67.9 85.7 85.7 67.9 67.9 10.5 17.6 5.21 6.84 0.35 0.27 9.58E-10 9.58E-10 44.6 44.6 SLED 30 PL8110 PL8111 PL8112 SLED 40 PL8121 PL8122 PL8130 PL8131 PL8132 PL8150 1 www.inrcore.com Estimated Temperature Rise: 4. Optional Tape & Reel packaging can be ordered by adding a “T” suffix to the part number (i.e. PL8100 becomes PL8100T). M107.E (07/20) SMT POWER INDUCTORS Toroid SLED Series Ruggedized Electrical Schematics Mechanicals Tape Pan (QTY) 800 1,02 2.53 35 200 1,02 4.62 30 200 1,52 9.02 30 150 1,52 15.00 15 100 0,64 2 www.inrcore.com M107.E (07/20) SMT POWER INDUCTORS Toroid SLED Series Ruggedized For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 3 www.inrcore.com M107.E (07/20)
PL8133T 价格&库存
很抱歉,暂时无法提供与“PL8133T”相匹配的价格&库存,您可以联系我们找货
