1534A
1534A
    HAMMONDMANUFACTURING
    插件,D11.9xL22.2mm
    固定电感器 Axial 1mH ±5% 160mA 8.6Ω 2.6MHz 83@250KHz
1534A 数据手册
Quality Products. Service Excellence. R.F. & Hash Chokes 1531-1535 Series Features All models impregnated with a moisture and fungus resistant varnish. Lead length of 1.5" (+/- 0.13") Wound for low distributed capacity by using solenoid (single coil) or 3-Pi windings. All single coil versions include vinyl insulation covering. Ambient Temperature range -40°C to +105°C Self Resonant Inductance Part No. L L Q Test Tolerance Minimum Frequency Min. Freq. Maximum Maximum D.C. Resistor D.C. Current (MHz) (Ohms) (ma.) Coil Core Core Coil Diameter Material Length Type 1531L 2.4 uH 0.1 56 7.9 MHz 120 0.19 1500 0.27 Phenolic 0.75 Single 1531R 10 uH 0.1 36 7.9 MHz 61 1.5 500 0.27 Phenolic 0.75 Single 1532A 10 uH 0.1 69 2.5 MHz 40 0.11 1500 0.29 Iron 0.88 Single 1532B 15 uH 0.1 62 2.5 MHz 33 0.17 1000 0.29 Iron 0.88 Single 1532C 24 uH 0.1 65 2.5 MHz 25 0.34 800 0.29 Iron 0.88 Single 1532D 39 uH 0.1 70 2.5 MHz 0.2 0.65 600 0.29 Iron 0.88 Single 1532E 55 uH 0.1 72 2.5 MHz 17 1 500 0.29 Iron 0.88 Single 1532H 100 uH 0.1 107 0.79 MHz 12 3 400 0.29 Iron 0.88 Single 1533H 1 mH 0.05 59 250KHz 3.7 19 160 0.56 Phenolic 0.75 3-Pi 1534A 1 mH 0.05 83 250KHz 2.6 8.6 160 0.47 Iron 0.88 3-Pi 1534C 2.4 mH 0.05 80 250KHz 1.7 15 160 0.53 Iron 0.88 3-Pi 1535B 2.5 mH 0.05 106 250KHz 1.3 9 160 0.47 Ferrite 0.88 3-Pi 1535D 5 mH 0.05 91 250KHz 1 14 160 0.53 Ferrite 0.88 3-Pi 1535G 10 mH 0.05 108 79 KHz 0.71 31 100 0.53 Ferrite 0.88 3-Pi 1535J 25 mH 0.05 102 79 KHz 0.47 82 65 0.53 Ferrite 0.88 3-Pi 1535L 50 mH 0.05 113 79 KHz 0.33 127 65 0.62 Ferrite 0.88 3-Pi Data subject to change without notice. © 2017. Hammond Manufacturing Ltd. All rights reserved.
1534A 价格&库存
很抱歉,暂时无法提供与“1534A”相匹配的价格&库存,您可以联系我们找货
