SCRH6D28-100
SCRH6D28-100
    SIGNAL
    非标准
    固定电感器 Nonstandard 10µH ±30% 1.7A 65mΩ
SCRH6D28-100 数据手册
SCRH6D28 SMD POWER INDUCTORS XXX MARKING ● Features 1. Magnetically shielded construction 2 Excellent Power Density 3 Engineered to Provide High Efficiency CHARACTERISTICS DC Resistance (Ω MAX) (2) (1) Saturation(3) Temperature (4) Current Current (A) (A) SCRH6D28-3R0 3.0 10KHZ 24m 3.00 4.70 SCRH6D28-3R9 3.9 10KHZ 27m 2.60 4.50 SCRH6D28-5R0 5.0 10KHZ 31m 2.40 4.00 SCRH6D28-6R0 6.0 10KHZ 35m 2.25 3.60 SCRH6D28-7R3 7.3 10KHZ 54m 2.10 3.23 SCRH6D28-8R6 8.6 10KHZ 58m 1.85 2.90 SCRH6D28-100 10 10KHZ 65m 1.70 2.60 SCRH6D28-120 12 10KHZ 70m 1.55 2.34 SCRH6D28-150 15 10KHZ 84m 1.40 2.10 SCRH6D28-180 18 10KHZ 95m 1.32 1.89 SCRH6D28-220 22 10KHZ 128m 1.20 1.70 SCRH6D28-270 27 10KHZ 142m 1.05 1.62 SCRH6D28-330 33 10KHZ 165m 0.97 1.37 SCRH6D28-390 39 10KHZ 210m 0.86 1.23 SCRH6D28-470 47 10KHZ 238m 0.80 1.17 SCRH6D28-560 56 10KHZ 277m 0.73 1.11 SCRH6D28-680 68 10KHZ 304m 0.65 0.99 SCRH6D28-820 82 10KHZ 390m 0.60 0.89 SCRH6D28-101 100 10KHZ 535m 0.54 0.80 SCRH6D28-121 120 10KHZ 580m 0.45 0.72 SCRH6D28-151 150 10KHZ 615m 0.42 0.68 SCRH6D28 decrease bycur current BCRH6D28Inductance I nduct ance decr ease by r ent 1000 I nduct ance( Inductance (µH)uH) Inductance Test (uH) Frequency 151 100 220 10 3R0 1 0. 1 10 100 1000 100000 10000 DCcurrent cur r ent(mA) ( mA) DC SCRH6D28 Temperature bycurcurrent BCRH6D28 Temper at ur e r rise i se by r ent 80 °C℃ TemTemperature per at ur e rrise i se Part Number 70 60 220 151 50 3R0 40 30 20 10 0 1000 2000 3000 4000 5000 6000 7000 DDC C cur r ent(mA) ( mA) current 8000 9000 10000 (1). Inductance tolerance ±30% tested at 0.25V, 0ADC and 25℃ (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 35% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ambient. Click here for QUANTITY PER REEL & PACKING INFORMATION Custom versions available upon request. belfuse.com/signal © 2019 Signal Transformer –Specification subject to change without notice. 12.19 115 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com
SCRH6D28-100
物料型号:SCRH6D28系列
器件简介:该系列电感器具有磁屏蔽结构,优秀的功率密度,以及为提供高效率而设计的工程特性。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性:包括电感值、测试频率、直流电阻、饱和电流和温度电流等详细参数。例如,SCRH6D28-3R0型号的电感值为3.0uH,直流电阻为24mΩ,饱和电流为3.00A。
功能详解:文档中没有提供具体的功能详解,但提到了电感值随电流变化的特性和电流引起的温度上升。
应用信息:文档中没有明确提供应用信息,但电感器的高效率和磁屏蔽特性可能适用于电源管理和其他需要高功率密度的应用。
封装信息:文档中没有提供封装信息,但提到了定制版本可以根据要求提供。
SCRH6D28-100 价格&库存
很抱歉,暂时无法提供与“SCRH6D28-100”相匹配的价格&库存,您可以联系我们找货
