Technical Data 10199
Effective January 2014
MPI2520
High Current, Low Profile, Miniature Power Inductors
HALOGEN
Pb HF
FREE
Applications:
Mobile/smart phones
Handheld/mobile equipment
Digital cameras
Media players
GPS
MP3 Players
Tablets/e-readers
l
e
i
t
v
i
t
n
c
u
e
r
f
f
o
E
6
1
d
t
e
2
n
u
e
d
n
i
5
e
t
m
t
1
n
e
e
r
l
o be
c
p
c
a
l
e
s
ep
Di tem is d
r
p ory ded
e
S
t
n
n
e
e
v
in omm 2
c
e
R I25-V
MP
Environmental data:
Storage temperature range (Component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
Packaging:
Product description:
Halogen free, lead free,
RoHS compliant
125°C maximum total temperature
operation
2.7 x 2.2 x 1.0 / 1.2mm maximum
surface mount package
Magnetically shielded, low EMI
Inductance range from
0.47µH to 10.0µH
Current range from 1.1 to 4.8 amps
Supplied in tape and reel packaging, 3000
parts per 7” diameter reel
MPI2520 High Current, Low Profile
Product specifications
Part
Number5
OCL1
(μH)±20%
Irms2
(Amps)
Isat3
(Amps)
DCR (mΩ) @
25°C typical
DCR (mΩ) @
25°C max
K-Factor4
R0 —1.0mm Height
MPI2520R0-R47-R
0.47
4.1
4.4
28
34
2887
MPI2520R0-1R0-R
0.9
3.2
3.2
50
60
1925
MPI2520R0-1R5-R
1.5
2.4
2.6
80
96
1444
MPI2520R0-2R2-R
2.2
2.2
2.4
103
124
1283
MPI2520R0-3R3-R
3.3
1.6
1.6
190
228
1050
MPI2520R0-4R7-R
4.7
1.4
1.4
240
288
825
R1 - 1.2mm Height
l
e
i
t
v
i
t
n
c
u
e
r
f
f
o
E
6
1
d
t
e
2
n
u
e
d
n
i
5
e
t
m
t
1
n
e
e
r
l
o be
c
p
c
a
l
e
s
ep
Di tem is d
r
p ory ded
e
S
t
n
n
e
e
v
in omm 21
c
e
R I25-V
MP
MPI2520R1-R47-R
0.47
4.5
4.8
2310
MPI2520R1-1R0-R
1.0
3.7
4.0
35
42
1925
MPI2520R1-1R5-R
1.5
2.9
3.4
55
66
1444
MPI2520R1-2R2-R
2.2
2.3
2.7
75
90
1255
MPI2520R1-3R3-R
3.3
1.8
2.4
105
126
962
MPI2520R1-4R7-R
4.7
1.6
1.9
150
180
825
MPI2520R1-5R6-R
5.6
1.5
1.5
200
240
679
MPI2520R1-6R8-R
6.8
1.3
1.3
300
360
679
MPI2520R1-100-R
10.0
1.1
1.2
390
468
525
1. Open Circuit Inductance (OCL) Test Parameters: 1MHz, 0.1Vrms,
0.0Adc, 25°C
2. Irms: DC current for an approximate temperature rise of 40°C without core
loss. Derating is necessary for AC currents. PCB layout, trace thickness and
width, air-flow, and proximity of other heat generating components will affect
the temperature rise. It is recommended that the temperature of the part
not exceed 125°C under worst case operating conditions verified in the end
application.
3. Isat: Peak current for approximately 30% rolloff at +25°C
2
www.eaton.com/elx
4. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K * L * ∆I. Bp-p:(Gauss), K: (K-factor from table),
L: (Inductance in µH), ∆I (Peak to peak ripple current in Amps).
5. Part Number Definition: MPI2520Rx-yyy-R
- MPI2520Rx = Product code and size
- yyy = Inductance value in µH, R = decimal point,
if no R is present then third character = number of zeros.
- “-R” suffix = RoHS compliant
Dimensions - mm
l
e
i
t
v
i
t
n
c
u
e
r
f
f
o
E
6
1
d
t
e
2
n
u
e
d
n
i
5
e
t
m
t
1
n
e
e
r
l
o be
c
p
c
a
l
e
s
ep
Di tem is d
r
p ory ded
e
S
t
n
n
e
e
v
in omm 2
c
e
R I25-V
MP
Packaging information - mm
www.eaton.com/elx
3
Temperature rise vs. total loss
Temperature Rise (°C)
50
40
30
l
e
i
t
v
i
t
n
c
u
e
r
f
f
o
E
6
1
d
t
e
2
n
u
e
d
n
i
5
e
t
m
t
1
n
e
e
r
l
o be
c
p
c
a
l
e
s
ep
Di tem is d
r
p ory ded
e
S
t
n
n
e
e
v
in omm 2
c
e
R I25-V
MP
10
MPI2520R0
MPI2520R1
0.2
0.3
0.4
0.5
Total Loss (W)
Core loss
4
www.eaton.com/elx
0.6
0.7
0.8
0.9
Inductance characteristics
MPI2520R0-1R0-R
MPI2520R0-1R5-R
0.50
2.00
0.40
1.60
Inductnace (µH)
Inductnace (µH)
MPI2520R0-R47-R
0.30
0.20
1.20
0.80
l
e
i
t
v
i
t
n
c
u
e
r
f
f
o
E
6
1
d
t
e
2
n
u
e
d
n
i
5
e
t
m
t
1
n
e
e
r
l
o be
c
p
c
a
l
e
s
ep
Di tem is d
r
p ory ded
e
S
t
n
n
e
e
v
in omm 2
c
e
R I25-V
MP
0.10
0.40
0.00
0.00
1
1.5
2
2.5
3
3.5
4
4.5
0.5
1
1.5
2.5
3
3.5
4
6
7
Idc (Amps)
Idc (Amps)
MPI2520R0-2R2-R
MPI2520R0-3R3-R
MPI2520R0-4R7-R
5.60
2
MPI2520R1-R47-R
0.50
Inductnace (µH)
Inductnace (µH)
4.80
4.00
3.20
2.40
1.60
0.40
0.30
0.20
0.10
0.80
0.00
0.00
1
1.5
Idc (Amps)
2
2.5
3
2
3
4
5
Idc (Amps)
www.eaton.com/elx
5
MPI2520R1-2R2-R
MPI2520R1-3R3-R
MPI2520R1-4R7-R
MPI2520R1-1R0-R
MPI2520R1-1R5-R
4.80
1.60
Inductnace (µH)
Inductnace (µH)
4.00
1.20
0.80
1.60
0.80
0.00
1
1.5
2
2.5
3
3.5
4
4.5
MPI2520R1-5R6-R
MPI2520R1-6R8-R
MPI2520R1-100-R
11.00
10.00
9.00
8.00
7.00
6.00
5.00
4.00
3.00
2.00
1.00
0.00
0.8
1.2
Idc (Amps)
www.eaton.com/elx
5
1
1.5
Idc (Amps)
Idc (Amps)
Inductnace (µH)
2.40
l
e
i
t
v
i
t
n
c
u
e
r
f
f
o
E
6
1
d
t
e
2
n
u
e
d
n
i
5
e
t
m
t
1
n
e
e
r
l
o be
c
p
c
a
l
e
s
ep
Di tem is d
r
p ory ded
e
S
t
n
n
e
e
v
in omm 2
c
e
R I25-V
MP
0.40
0.00
6
3.20
1.6
2
2
2.5
3
Solder reflow profile
TP
TC -5°C
Temperature
Preheat
A
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020D
Profile Feature
Preheat and Soak
Standard SnPb Solder
100°C
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company . Life support
systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to
result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update,
without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
www.eaton.com/elx
© 2014 Eaton
All Rights Reserved
Publication No. 10199 — BU-SB131200
January 2014
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
www.eaton.com/elx
7
很抱歉,暂时无法提供与“MPI2520R0-R47-R”相匹配的价格&库存,您可以联系我们找货
