Data Sheet
Customer:
Product:
High Voltage Thick Film Chip Resistor - HVR Series
Size:
0402/0603/0805/1206/2010/2512
Issued Date:
10-Mar-21
Edition:
REV.B5
VIKING TECH CORPORATION
光頡科技股份有限公司
VIKING TECH CORPORATION KAOHSIUNG BRANCH
光頡科技股份有限公司高雄分公司
VIKING ELECTRONICS (WUXI) CO., LTD.
光頡電子(無錫)有限公司
No.70 Guangfu N. Rd., Hukou
Township, Hsinchu County 303,
Taiwan
No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung,
806, Taiwan
TEL:886-3-5972931
FAX:886-3-5972935•886-3-5973494
E-mail:sales@viking.com.tw
TEL:886-7-8217999
FAX:886-7-8228229
No.22 Xixia Road, Machinery & Industry Park,
National Hi-Tech Industrial Development Zone
of Wuxi, Wuxi, Jiangsu Province, China
Zip Code:214028
TEL:86-510-85203339
FAX:86-510-85203667•86-510-85203977
E-mail:china@viking.com.tw
Produced by
(QC)
Checked
(QC)
Approved by
(QC)
10-Mar-21
10-Mar-21
10-Mar-21
Susan Huang
J.C. Liu
J.C. Liu
Prepared by
(Sales)
Accepted by
(Customer)
【HVR Series】
■Scope
-This specification applies to all sizes of rectangular-type fixed
chip resistors with Ruthenium-base as material.
■Features
-Highly reliable multilayer electrode construction
-Higher component and equipment reliability
-Excellent performance at high voltage
-Reduced size of final equipment
-IEC 62368-1 & IEC 60950-1 Safety Certificate issued by UL
Demko
■Construction
■Applications
L
-Inverter
-Outdoor Equipments
D1
-Converter
W
T
-High Pulse Equipment
D2
Alumina Substrate
Bottom Electrode
Top Electrode
Edge Electrode
Barrier Layer
External Electrode
Resistor Layer
Primary Overcoat
Secondary Overcoat
■Dimensions
Type
Size
(Inch)
(mm)
(mm)
(mm)
(mm)
(mm)
Weight
(g)
(1000pcs)
HVR02
0402
1.00±0.05
0.50±0.05
0.35±0.05
0.20±0.10
0.20±0.10
0.620
HVR03
0603
1.60±0.10
0.80±0.10
0.45±0.10
0.30±0.20
0.30±0.20
2.042
HVR05
0805
2.00±0.10
1.25±0.10
0.50±0.10
0.35±0.20
0.40±0.20
4.368
HVR06
1206
3.10±0.10
1.55±0.10
0.55±0.10
0.50±0.25
0.50±0.20
8.947
HVR0A
2010
5.00±0.10
2.50±0.15
0.55±0.10
0.60±0.25
0.50±0.20
24.241
HVR12
2512
6.35±0.10
3.10±0.15
0.55±0.10
0.60±0.25
0.50±0.20
39.448
L
W
T
D1
D2
■IEC 62368-1 & IEC 60950-1 Safety Certificate Scope
G.10.2 (2.5KV impulse test)
HVR02
HVR03
HVR05
10M~100M
10M~100M
100K~100M
G.10.3.2 (10KV surge)
10M~100M
G.10.3.3 (5KV impulse)
100K~100M
www.viking.com.tw
HVR06
HVR0A
HVR12
470K~100M
51K~100M
30K~100M
For detail questions, contact:sales@viking.com.tw
1
Edition: REV.B5
Revision: 10-Mar-2021
【HVR Series】
■Part Numbering
HVR
03
F
T
E
Product
Type
Dimensions
Resistance
Tolerance
F: ±1%
J: ±5%
Packaging
Code
TCR
(PPM/°C)
02: 0402
03: 0603
05: 0805
06: 1206
0A: 2010
12: 2512
■Recommend Land Pattern
T: 7”Taping Reel
V:10”Taping Reel
W:13”Taping Reel
X
E: ±100
F: ±200
H: ±400
1003
Power
Rating
Y: 1/16W
X: 1/10W
W: 1/8W
V: 1/4W
U: 1/2W
T: 1W
Resistance
1003: 100KΩ
1004: 1MΩ
1005: 10MΩ
■Derating Curve
Derating Curve
100
Power ratio(%)
B
C
A
Type
A
(mm)
B
(mm)
C
(mm)
HVR02
0.50
0.45
0.60
HVR03
0.90
0.60
0.90
HVR05
1.20
0.70
1.30
HVR06
2.00
0.90
1.60
HVR0A
3.80
0.90
2.80
HVR12
4.90
1.60
3.50
80
60
40
60
80
100
120
140
160
180
Ambient Temperature(℃)
■Soldering Condition (IPC/JEDEC J-STD-020)
www.viking.com.tw
2
Edition: REV.B5
【HVR Series】
■Standard Electrical Specifications
Item
Type
Power
Rating
at 70C
Operating
Temp. Range
Max.
Operating
Voltage
Max.
Overload
Voltage
Resistance Range
±1%(E24、E96)
±5%(E24)
39KΩ - 1MΩ
HVR02 (0402)
1/16W
100V
200V
1/10W
200V
400V
1.1MΩ - 20MΩ
±200
22MΩ - 100MΩ
±400
1/8W
400V
800V
1.1MΩ - 20MΩ
±200
22MΩ - 100MΩ
±400
1/4W
1.1MΩ - 20MΩ
±200
22MΩ - 100MΩ
±400
100KΩ- 1MΩ
500V
1000V
1/2W
2000V
3000V
1.1MΩ - 20MΩ
±200
22MΩ - 100MΩ
±400
1W
3000V
4000V
±100
1.02MΩ - 20MΩ
1.1MΩ - 20MΩ
±200
22MΩ - 100MΩ
±400
30KΩ - 1MΩ
HVR12 (2512)
±100
1.02MΩ - 10MΩ
51KΩ- 1MΩ
HVR0A (2010)
±100
1.02MΩ - 10MΩ
-55 ~ +155C
HVR06 (1206)
±100
1.02MΩ - 10MΩ
100KΩ - 1MΩ
HVR05 (0805)
±100
1.02MΩ - 10MΩ
56KΩ - 1MΩ
HVR03 (0603)
TCR
(PPM/C)
±100
1.02MΩ - 20MΩ
1.1MΩ - 20MΩ
±200
22MΩ - 100MΩ
±400
Operating Voltage=√(P*R) or Max. Operating Voltage listed above, whichever is lower.
Overload Voltage=2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower.
■ Viking is capable of manufacturing the optional spec based on customer’s requirement.
www.viking.com.tw
3
Edition: REV.B5
【HVR Series】
■Environmental Characteristics
Requirement
Item
Temperature Coefficient of
Resistance (T.C.R.)
JIS-C-5201-1 4.8
IEC-60115-1 4.8
As Spec.
Short Time Overload
(1.0%+0.05Ω)
Insulation Resistance
10G
Endurance
Test Method
5%
1%
(2.0%+0.10Ω)
(2.0%+0.05Ω)
At 25C/-55C and 25C/+125C, 25C is the
reference temperature
JIS-C-5201-1 4.13
IEC-60115-1 4.13
RCWV*2.5 or Max. Overload Voltage whichever is
lower for 5 seconds
JIS-C-5201-1 4.6
IEC-60115-1 4.6
(3.0%+0.10Ω)
Damp Heat with Load
(2.0%+0.10Ω)
(3.0%+0.10Ω)
Dry Heat
(1.0%+0.05Ω)
(1.5%+0.10Ω)
Max. Overload Voltage for 1 minute
JIS-C-5201-1 4.25
IEC-60115-1 4.25.1
702C, RCWV for 1000 hrs with 1.5 hrs “ON” and
0.5 hr “OFF”
JIS-C-5201-1 4.24
IEC-60115-1 4.24
402C, 90~95% R.H., RCWV for 1000 hrs with 1.5
hrs “ON” and 0.5 hr “OFF”
JIS-C-5201-1 4.23
IEC-60115-1 4.23.2
at +155C for 1000 hrs
Bending Strength
(1.0%+0.05Ω)
Solderability
95% min. coverage
Bending once for 60 seconds
2010, 2512 sizes: 2mm
Other sizes: 3mm
JIS-C-5201-1 4.17
IEC-60115-1 4.17
(0.5%+0.05Ω)
2455C for 3 seconds
JIS-C-5201-1 4.18
IEC-60115-1 4.18
Resistance to Soldering Heat
Voltage Proof
(1.0%+0.05Ω)
JIS-C-5201-1 4.33
IEC-60115-1 4.33
(1.0%+0.05Ω)
2605C for 10 seconds
JIS-C-5201-1 4.7
IEC-60115-1 4.7
HVR02: 150V for 1 minute
HVR03: 300V for 1 minute
HVR05/HVR06/HVR0A/HVR12: 500V for 1 minute
JIS-C-5201-1 4.18
IEC-60068-2-58 8.2.1
No breakdown or flashover
Individual leaching area ≦5%
Leaching
Total leaching area ≦ 10%
Rapid Change of Temperature (0.5%+0.05Ω)
(1.0%+0.05Ω)
2605C for 30 seconds
JIS-C-5201-1 4.19
IEC-60115-1 4.19
-55C to +155C, 5 cycles
RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower.
■ Storage Temperature: 15~28°C; Humidity < 80%RH
www.viking.com.tw
4
Edition: REV.B5
【HVR Series】
▓Packaging
Reel Specifications & Packaging Quantity
Type
HVR02
Paper
HVR03
HVR05
Paper
HVR06
HVR0A
HVR12
Tape Width
Reel
Diameter
ΦA
(mm)
10K
8mm
7 inch
178.5±1.5
20K
8mm
10 inch
254±1.0
40K
8mm
13 inch
330±1.0
5K
8mm
7 inch
178.5±1.5
10K
8mm
10 inch
254±1.0
20K
8mm
13 inch
330±1.0
4K
12mm
7 inch
178.5±1.5
8K
12mm
10 inch
250±1.0
Bottom Tape
Top Tape
Packaging
Quantity
ΦB
(mm)
ΦC
(mm)
W
(mm)
T
(mm)
13.0±0.2
9.0±0.5
12.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
13.0±0.2
9.0±0.5
12.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
+1/-0
13.0±0.5
13.0±0.5
15.5±0.5
62±0.5
13.0±0.5
12.5±0.5
16.5±0.5
60
60
60
+1/-0
+1/-0
Embossed
Paper Tape Specifications
ψ D0
E
A
F
W
B
T
Paper Tape
Type
A
(mm)
B
(mm)
W
(mm)
P1
Resistor
E
(mm)
F
(mm)
P0
(mm)
P2
P0
P1
(mm)
Direction of unreeling
P2
(mm)
ΦD0
(mm)
T
(mm)
HVR02
0.65±0.10 1.15±0.10 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10
HVR03
1.10±0.10 1.90±0.10 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10
HVR05
1.60±0.10 2.40±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10
HVR06
1.90±0.10 3.50±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10
www.viking.com.tw
5
Edition: REV.B5
【HVR Series】
Embossed Plastic Tape Specifications
Top Tape
ψ D0
E
A
F
W
B
ψD11.5+0.25,-0
T
P1
Resistor
P2
P0
Embossed Tape
P1
(mm)
ΦD0
(mm)
Type
A
(mm)
B
(mm)
W
(mm)
E
(mm)
F
(mm)
P0
(mm)
P2
(mm)
T
(mm)
HVR0A
2.80±0.10
5.40±0.20
12.0±0.30
1.75±0.10
5.50±0.05
4.00±0.10
4.00±0.10 2.00±0.05 1.50+0.1, -0
1.2
+0
HVR12
3.50±0.10
6.70±0.10
12.0±0.30
1.75±0.10
5.50±0.05
4.00±0.10
1.2
+0
■Marking
No Marking for 0402
1% for 0805/1206/2010/2512: 4 digits marking
Example:
Resistance
Marking
49.9KΩ
4992
100KΩ
1003
1MΩ
1004
4.99MΩ
4994
10MΩ
1005
5% for 0603/0805/1206/2010/2512: 3 digits marking in E24
st
Example: 124=120KΩ 106=10MΩ (1 and 2
E24
code
10
11
12
13
15
16
18
nd
rd
are E24 code and 3 code is multiplier)
24
27
30
33
36
39
43
47
51
56
62
68
75
82
91
1% for 0603: 3 digits marking in E96
14C
www.viking.com.tw
3 digits marking for Example: 75C=59KΩ 39E=2.49MΩ
6
Edition: REV.B5
【HVR Series】
■Marking Table
Code
E96
Code
E96
Code
E96
Code
E96
01
100
25
178
49
316
73
562
02
102
26
182
50
324
74
576
03
105
27
187
51
332
75
590
04
107
28
191
52
340
76
604
05
110
29
196
53
348
77
619
06
113
30
200
54
357
78
634
07
115
31
205
55
365
79
649
08
118
32
210
56
374
80
665
09
121
33
215
57
383
81
681
10
124
34
221
58
392
82
698
11
127
35
226
59
402
83
715
12
130
36
232
60
412
84
732
13
133
37
237
61
422
85
750
14
137
38
243
62
432
86
768
15
140
39
249
63
442
87
787
16
143
40
255
64
453
88
806
17
147
41
261
65
464
89
825
18
150
42
267
66
475
90
845
19
154
43
274
67
487
91
866
44
280
68
499
92
887
21
162
45
287
69
511
93
909
22
165
46
294
70
523
94
931
23
169
47
301
71
536
95
953
174
48
309
72
549
96
976
24
Code
A
Multiplier
10
B
www.viking.com.tw
10
C
1
10
D
2
10
E
3
10
F
4
10
X
5
10
-1
Y
10
7
-2
Edition: REV.B5
【HVR Series】
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version B
Jun 03, 2014
- Environmental Characteristics updated
Version B1 Oct 27, 2014
Version B2 Jul 15, 2016
Version B3 Jan 12, 2018
Version B4 May 20, 2019
- Modify TCR Test description
- Modify Bending Test description
- Increase large reel packaging code
- modify 2010 Embossed Plastic Tape B
Specification
- modify Soldering Condition (IPC/JEDEC
J-STD-020)
Version B5 Mar 10, 2021
www.viking.com.tw
- Standard Electrical Specifications updated
- Remove Material Description
- Modify Storage Temperature
- Increase IEC 62368-1 & IEC 60950-1 Safety
Certificate Scope
8
Edition: REV.B5
很抱歉,暂时无法提供与“HVR05FTEW3903”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48750
- 100+0.29180
- 1000+0.19890
- 5000+0.13260
- 10000+0.12200
- 50000+0.11270
