■ Application
Laptop, desktop and server applications
High current power supplies
Battery powered devices
PMIC
■ Features
RoHS compliant & halogen free
Low resistance and high current rating
Magnetic core made by high performance magnetic metal powder
■ Product Identification
①
②
③ ④
⑤
MMD - 10DZ - 2R2 M - X1
① Product Code
② Dimensions
③ Inductance: 2R2 = 2.2μH
④ Tolerance: M = ±20%
⑤ Series Type: X1 Type
Note: Please refer to the “Product Dimension” for detail dimensions.
MAG.LAYERS
MMD-10DZ-SERIES-X1
■ Electrical Performance
Rdc
(mΩ)
Inductance
±20%@0A
(μH)
Max.
Heat rating
current (Idc)1
DC amps (A)
Saturation
current (Isat)2
DC amps (A)
Typ.
MMD-10DZ-R15M-X1
0.15
0.5
0.65
40
75
MMD-10DZ-R36M-X1
0.36
1.05
1.2
30
60
MMD-10DZ-R41M-X1
0.41
1.1
1.3
30
60
MMD-10DZ-R45M-X1
0.45
1.1
1.3
25
27
MMD-10DZ-R47M-X1
0.47
1.6
1.8
26
40
MMD-10DZ-R56M-X1
0.56
1.6
1.8
25
40
MMD-10DZ-R68M-X1
0.68
2.4
2.7
22
39
MMD-10DZ-R88M-X1
0.88
2.7
3.0
MMD-10DZ-1R0M-X1
1.0
2.9
3.3
18
36
MMD-10DZ-1R5M-X1
1.5
3.8
4.2
16
33
MMD-10DZ-2R2M-X1
2.2
6.6
7.0
12
27
MMD-10DZ-4R7M-X1
4.7
15.0
16.5
9.5
17
MMD-10DZ-100M-X1
10.0
27.5
30
6.0
6.0
Part number
Test frequency: 100 KHz, 0.25V.
Test instruments: Inductance/saturation current: Keysight 4285A or equivalent.
Rdc: ADEX AX1152D or equivalent.
Notes:
1. The heat rating current (Idc) will cause temperature rise approximate 40oC.
2. The saturation current (Isat) will cause initial inductance drop approximate 20%.
3. All test data is referenced at 25oC ambient.
4. Operating temperature range -55oC to +125oC.
5. The part temperature (ambient + temp rise) should not exceed 125oC under the worst
condition.
6. The temperature of component is affected by application conditions, e.g. circuit design,
copper thickness of PCB and cooling conditions, the actual component temperature
should be tested in the end application.
MAG.LAYERS
MMD-10DZ-SERIES-X1
■ Electtrical Characte
eristics
MMD-10DZ-R15M-X
X1
MMD
D-10DZ-R3
36M-X1
MMD-10DZ-R41M-X
X1
MMD
D-10DZ-R4
45M-X1
MMD-10DZ-R47M-X
X1
MMD
D-10DZ-R5
56M-X1
MMD-10DZ-R68M-X
X1
MMD
D-10DZ-R8
88M-X1
MA
AG.LAYE
ERS
MMD
D-10DZ-SE
ERIES-X1
MMD-10DZ-1R0M-X1
MMD-10DZ-1R5M-X1
MMD-10DZ-2R2M-X1
MMD-10DZ-4R7M-X1
MMD-10DZ-100M-X1
MAG.LAYERS
MMD-10DZ-SERIES-X1
■ Product Dimension
Dimension
Part number
MMD-10DZ-R36M-X1-RI
A
B
C
D
E
11.5 Max
10.0 ± 0.3
4.0 Max
2.5 ~ 3.5
2.2 ± 0.3
Unit: mm
Please refer individual part number data sheet for specific dimensions.
MAG.LAYERS
MMD-10DZ-SERIES-X1
■ Recommended PCB Layout
A
B
C
Type
10DZ
A
4.1
B
5.4
C
13.6
Unit: mm
Safety precaution
1. Do not make any through holes and copper pattern in the dotted line area. Except a
copper pattern to the electrode.
2. Don’t design/mount any components in contact with this product.
This power choke coil itself does not have any protective function in abnormal
condition such as overload, short circuit, open conditions and etc, it shall be confirmed as
the end product that there is no risk of smoking, fire, dielectric withstand voltage, insulation
resistance and etc. in abnormal conditions to provide protective devices and/or protection
circuit in the end product.
MAG.LAYERS
MMD-10DZ-SERIES-X1
■ Pack
kaging
Pee
el-off force
165° TO 180°
TOP COVER TA
APE
BASE TAPE
T
The peel off force of
o cover ta
ape is 10 to
o 70 gramss in the arro
ow directio
on.
Dimensions
s
F
A
B
C
D
Type
e
A
B
C
D
E
F
330mm
m
330
±2
100
±1
±0.5
13
±1.0
24.2
2
+2
2.0/-0
29.2
±2
E
Unit: mm
TYPE
MMD
SIZ
ZE
10D
DZ
A
B
W
P1
K
10
0.4±0.1
11.5±0.1
24.0±0.3
16.0±
±0.1
4.5
5±0.1
P0
P2
D
E
T
4.0±0.1
2.0±0.1
1.5±0.1
1
1.75±
±0.1
0.35
5±0.05
Unit: mm
MA
AG.LAYE
ERS
MMD
D-10DZ-SE
ERIES-X1
Taping quantity
Series
10DZ
PCS/Reel
500
Carton box
342mm
40mm
Middle packaging: 2 reels/box
LABEL
40mm
70m
m
336mm
40mm
External packaging: 5 boxes/carton
415mm
LABEL
40mm
380mm
mm
380
MAG.LAYERS
MMD-10DZ-SERIES-X1
MMD-10DZ-R45M-X1-RU 价格&库存
很抱歉,暂时无法提供与“MMD-10DZ-R45M-X1-RU”相匹配的价格&库存,您可以联系我们找货
