Technical Data 4449
Effective July 2017
Supersedes June 2012
HCM1103
High current power inductors
Applications
Product features
11.5 x 10.3 x 3.0 mm maximum surface
mount package
Iron powder core material
Magnetically shielded, low EMI
High current carrying capacity, low core losses
Inductance range from 0.12 µH to 22.0 µH
Current range from 3.0 A to 75 A
Halogen free, lead free, RoHS compliant
Voltage Regulator Module (VRM)
Multi-phase regulators
Point-of-load modules
Desktop and server VRMs and EVRDs
Base station equipment
Notebook and laptop regulators
Battery power systems
Graphics cards
Data networking and storage systems
Environmental Data
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
Technical Data 4449
Effective July 2017
Product Specifications
Part
Number6
HCM1103-R12-R
HCM1103-R36-R
HCM1103-R47-R
HCM1103-R68-R
HCM1103-1R0-R
HCM1103-2R2-R
HCM1103-3R3-R
HCM1103-4R7-R
HCM1103-8R2-R
HCM1103-100-R
HCM1103-150-R
HCM1103-220-R
OCL1
±20% (µH)
0.12
0.36
0.47
0.68
1.0
2.2
3.3
4.7
8.2
10.0
15.0
22.0
FLL min.2
(µH)
0.07
0.26
0.33
0.38
0.56
1.2
1.9
2.6
4.6
5.6
8.4
12.3
Irms3
(A)
30
23
15
13
9.0
7.0
5.0
5.0
4.0
3.0
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc @
+25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat @ +25 °C.
3. Irms: DC current for an approximate temperature rise of 40 °C without core
loss. Derating is necessary for AC currents. PCB layout, trace thickness and
width, air-flow and proximity of other heat generating components will affect
the temperature rise. It is recommended that the temperature of the part not
exceed +125 °C under worst case operating conditions verified in the end
application.
Isat4 @ +25 °C
(A)
75
28
26
23
21
16
14
13
8.5
7.5
6.0
5.0
DCR (mΩ) @
+20 °C Typical
DCR (mΩ) @
+20 °C Maximum
0.55
1.10
1.50
2.90
5.50
8.40
14.5
20.5
35.0
40.0
59.0
90.0
0.61
1.30
2.00
3.40
6.00
9.00
16.0
22.5
38.5
44.0
65.0
99.0
K-Factor5
1200
711
515
510
377
264
230
205
153
141
114
91
4. Isat: Peak current for approximately 30% rolloff at +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p
= K * L * ∆I. Bp-p:(Gauss), K: (K-factor from table),
L: (Inductance in µH), ∆I (peak-to-peak ripple current in Amps).
6. Part Number Definition: HCM1103-xxx-R
HCM1103 = Product code and size
xxx= Inductance value in µH, R = decimal point,
if no R is present then third character = number of zeros.
-R suffix = RoHS compliant
Dimensions (mm)
Top View
HCM1103-R36-R &
HCM1103-R47-R
Top View
HCM1103-R12-R &
HCM1103-R68-R to
HCM1103-220R
Side View
Bottom View
wlyy R
wlyy R
Part Marking: xxx = Inductance value in uH, R = decimal point, if no R is present then third character = # of zeros.
wlyy = (Date code), R = Revision Level
All soldering surfaces to be coplanar within 0.10 millimeters.
Tolerances are ±0.3 millimeters unless stated otherwise.
HCM1103-R36-R and HCM1103-R47-R Color: Top Grey
HCM1103-R12-R and HCM1103-R68-R to HCM1103-220-R Color : Top Grey
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
Recommended Pad Layout
Schematic
HCM1103
Technical Data 4449
Effective July 2017
Packaging information (mm)
wlyy R
Supplied in tape and reel packaging, 1000 parts per 13” diameter reel.
wlyy R
Temperature rise vs. total loss
6 0 .0
Temperature Rise (°C)
5 0 .0
4 0 .0
HCM1103-R12-R
HCM1103-R36-R
HCM1103-R47-R
3 0 .0
HCM1103-R68-R
HCM1103-1R0-R
HCM1103-2R2-R
HCM1103-3R3-R
2 0 .0
HCM1103-4R7-R
HCM1103-8R2-R
HCM1103-100-R
HCM1103-150-R
1 0 .0
HCM1103-220-R
0 .0
0 .0
0 .2
0 .4
0 .6
0 .8
1 .0
1 .2
1 .4
1 .6
Total Loss (W)
3
Technical Data 4449
Effective July 2017
Core loss vs. Bp-p
HCM1103-; R36-R and R47-R
10000
300K
1000
200K
100K
Core Loss (mW)
50K
100
25K
10
1
0.1
10
100
1000
10000
Bp-p (Gauss)
HCM1103-; R12-R, R68-R through 220-R
10000.0
500K
300K
200K
1000.0
100K
Core Loss (mW)
50K
25K
100.0
10.0
1.0
0.1
10
100
1000
Bp-p (Gauss)
4
10000
HCM1103
Technical Data 4449
Effective July 2017
Inductance characteristics
HCM1103-; R36-R, R47-R
HCM1103-R12-R
100%
100%
90%
90%
80%
80%
% of OCL
110%
% of OCL
110%
70%
70%
60%
60%
50%
50%
40%
40%
30%
40
50
60
70
HCM1103-R36-R
HCM1103-R47-R
30%
80
Idc (A)
5
10
15
HCM1103-; R68-R, 1R0-R
35
40
45
100%
90%
90%
80%
80%
% of OCL
% of OCL
30
110%
100%
70%
60%
70%
60%
50%
50%
HCM1103-R68-R
40%
HCM1103-2R2-R
40%
HCM1103-1R0-R
HCM1103-3R3-R
5
10
15
30
35
40
30%
Idc(A)
4
6
8
10
HCM1103-4R7-R
14
16
18
24
26
HCM1103-; 8R2-R, 100-R
110%
100%
100%
90%
80%
80%
% of OCL
90%
70%
70%
60%
60%
50%
50%
HCM1103-8R2-R
40%
40%
HCM1103-100-R
30%
30%
12
Idc (A)
110%
% of OCL
25
HCM1103-; 2R2-R, 3R3-R
110%
30%
Idc (A)
4
6
8
Idc (A)
10
12
14
16
18
4
8
6
10
12
14
Idc (A)
5
Technical Data 4449
Effective July 2017
110%
100%
90%
% of OCL
80%
70%
60%
50%
HCM1103-150-R
40%
30%
HCM1103-220-R
4
6
Idc (A)
6
8
10
12
Technical Data 4449
Effective July 2017
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1103-1R0-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+10.445521000+1.35564
- 2000+9.851572000+1.27856
- 3000+9.520363000+1.23557
- 5000+9.119395000+1.18353
- 7000+9.069847000+1.17710
- 国内价格 香港价格
- 1+18.621811+2.41677
- 10+15.2933610+1.98480
- 100+12.57447100+1.63194
