SL2026B-R07LHF
SL2026B-R07LHF
    ITG
    固定电感器 Nonstandard 70nH ±15% 53A 0.27mΩ
SL2026B-R07LHF 数据手册
SL2026 Series 1. Features of SL2026 Series: • • • • • • • • • • Ferrite based SMD inductor with lower core loss. Inductance range: 37.0 nH to 200.0 nH , custom values are welcomed. High current output chokes , up to 83.0 Amp with approx. 20% roll off. Low Profile 6.60mm max height . 5.20 x 5.50 mm Foot Print. Ideal for Buck Converter, VRM & High Density Board Design. Operating frequency of up to 5.0MHz. Operating temperature range of -55°C to + 130°C. RoHS & HF compliant. T & R Qty’s: 800pcs, 13'' Reel. 2. Electrical Characteristics of SL2026 Series: Part Number SL2026B-R05LHF SL2026-R055LHF SL2026B-R07LHF SL2026-R08LHF SL2026B-R08LHF SL2026-R10MHF SL2026B-R10MHF SL2026B-R11MHF SL2026-R15MHF SL2026B-R15MHF SL2026B-R20MHF Inductance (nH) DCR (mΩ) Isat1 (A) Isat2 (A) Isat3 (A) Irms4 (A) ±15% or 20% ± 7.0% @25℃ @45℃ @100℃ @25℃ 50 , 15% 55 , 15% 70 , 15% 80 , 15% 80 , 15% 100 , 20% 100 , 20% 110 , 20% 150 , 20% 150 , 20% 200 , 20% 0.27 0.47 0.27 0.47 0.27 0.47 0.27 0.27 0.47 0.27 0.27 72.00 68.00 60.00 52.00 52.00 35.00 35.00 32.00 22.00 22.00 16.00 70.00 66.00 54.00 50.00 50.00 32.00 32.00 30.00 20.00 20.00 15.00 66.00 63.00 50.00 43.00 43.00 29.00 29.00 26.00 17.00 17.00 12.00 53.00 40.00 53.00 40.00 53.00 40.00 53.00 53.00 40.00 53.00 53.00 Fig 2 1 2 1 2 1 2 2 1 2 2 3. Mechanical Dimension ( Uint : mm) : Series Name A Max. B Max. C Max. D Max. E Nom. F Nom. G Nom. SL2026 5.00 5.00 6.60 5.20 2.40 2.00 1.20 SL2026B 5.00 5.00 6.60 5.20 2.40 2.00 1.40 D B D B C F A Marking E C F A 2X G 5.50 2X2.60 Marking E 2X G 5.50 2X1.85 a b Suggested Pad Layout Fig 1 2X 2.60 2X1.85 a b Suggested Pad Layout Fig 2 Notes: 1. Open Circuit Inductance (OCL) test condition: 100KHz, 0.1Vrms, 0A DC at 25Ԩ. 2. L @ Isat and L @ Irms Test condition: 100KHz, 0.1Vrm (Ta=25Ԩ). 3. The nominal DCR is measured from point “a” to point “b” as shown above in the mechanical drawing (Ta=25Ԩ). 4. Isat1, Isat2 & Isat3: DC current that will cause inductance to drop approximately by 20%. 5. Irms: DC current for an approximate temperature rise of 40Ԩ without core loss. 6. Derating is necessary for AC currents. PCB pad layout , trace thickness and width , air-flow and proximity of other heat generating components will affect the temperature rise. 6. It is recommended the part temperature not exceed 130°C under worst case operating conditions as verified in the end application. ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision G.1: January 16 , 2018 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SL2026 Series 4. Inductance Characteristics of SL2026 Series (Inductance vs Current): SL2026x-R05LHF 0.0576 0.0504 0.0432 0.0360 0.0288 0.0216 0.0144 0.0072 0.0000 L (uH) 25Ԩ 45Ԩ 100Ԩ 0 20 40 50 58 60 62 64 66 68 Direct Current (A) 70 72 74 76 78 80 SL2026x-R055LHF 0.0624 0.0546 0.0468 0.0390 0.0312 0.0234 0.0156 0.0078 0.0000 25Ԩ L (uH) 45Ԩ 100 Ԩ 0 20 40 50 52 54 56 58 60 62 64 Direct Current (A) 66 68 70 72 74 76 SL2026x-R07LHF 0.080 0.070 0.060 0.050 0.040 0.030 0.020 0.010 0.000 L (uH) 25Ԩ 45Ԩ 100Ԩ 0 10 20 30 40 50 52 54 56 58 60 Direct Current (A) 62 64 66 68 70 72 SL2026x-R08LHF 0.090 0.080 0.070 0.060 0.050 0.040 0.030 0.020 0.010 0.000 L (uH) 25Ԩ 45Ԩ 100Ԩ 0 ● 10 20 30 35 40 41 42 43 44 45 46 47 Direct Current (A) 48 49 50 51 52 53 54 55 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision G.1: January 16 , 2018 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SL2026 Series SL2026x-R10MHF 0.110 0.100 0.090 0.080 0.070 0.060 0.050 0.040 0.030 0.020 0.010 0.000 L (uH) 25Ԩ 45Ԩ 100 Ԩ 0 5 10 15 20 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 Direct Current (A) SL2026x-R11MHF 0.138 0.127 0.115 0.104 0.092 0.081 0.069 0.058 0.046 0.035 0.023 0.012 0.000 L (uH) 25Ԩ 45Ԩ 100 Ԩ 0 5 10 15 20 25 26 27 28 29 30 31 Direct Current (A) 32 33 34 35 36 37 38 SL2026x-R15MHF 0.168 0.154 0.140 0.126 0.112 0.098 0.084 0.070 0.056 0.042 0.028 0.014 0.000 L (uH) 25Ԩ 45Ԩ 100 Ԩ 0 5 10 15 16 17 18 19 20 21 22 23 Direct Current (A) 24 25 26 27 28 29 SL2026x-R20MHF 0.25 0.20 L (uH) 30 25c 0.15 45c 0.10 100c 0.05 0.00 0.0 ● 2.0 4.0 6.0 8.0 10.0 12.0 Direct Current (A) 14.0 16.0 18.0 20.0 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision G.1: January 16 , 2018 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
SL2026B-R07LHF 价格&库存
很抱歉,暂时无法提供与“SL2026B-R07LHF”相匹配的价格&库存,您可以联系我们找货
