MSCDRI-127A-220M-RU
MSCDRI-127A-220M-RU
    MAGLAYERS(美磊科技)
    SMD,12x12mm
    固定电感器 Nonstandard 22µH ±20% 3.6A 43.2mΩ
MSCDRI-127A-220M-RU 数据手册
SCOPE: This specification applies to the Pb Free high current type SMD inductors for MSCDRI-127AH0-SERIES Warn : This product series can’t be used in synchronous rectification circuit that is over 24V. PRODUCT INDENTIFICATION MSCDRI - 127A H0 - 100 M ① ② ③ ④ ⑤ ① Product Code ② Dimensions Code ③ AEC-Q200 Code ④ Inductance Code ⑤ Tolerance Code (1) SHAPES AND DIMENSIONS A: 12.0±0.5 mm B: 12.0±0.5 mm C: 8.0 Max. mm (2) ELECTRICAL SPECIFICATIONS SEE TABLE 1 TEST INSTRUMENTS L : HP 4284A PRECISION LCR METER (or equivalent) RDC : CHROMA MODEL 16502 MILLIOHMMETER (or equivalent) (3) CHARACTERISTICS (3)-1 Operate temperature range ...... -40℃~+155℃ (Including self temp. rise) MAG.LAYERS MSCDRI-127AH0-SERIES Page-1/8 TABLE 1 MAGLAYERS Inductance Percent PT/NO. L(μH) Tolerance MSCDRI-127AH0-100□ 10 MSCDRI-127AH0-120□ Test Resistance Rated DC Current Frequency RDC(Ω)Max. Isat(A) Irms(A) M,N 100kHz/0.25V 21.6m 7.8 5.4 100 12 M,N 100kHz/0.25V 24.3m 7.3 4.9 120 MSCDRI-127AH0-150□ 15 M,N 100kHz/0.25V 27.0m 6.5 4.5 150 MSCDRI-127AH0-180□ 18 M,N 100kHz/0.25V 39.2m 6.0 3.9 180 MSCDRI-127AH0-220□ 22 M,N 100kHz/0.25V 43.2m 5.3 3.6 220 MSCDRI-127AH0-270□ 27 M,N 100kHz/0.25V 53.1m 4.8 3.3 270 MSCDRI-127AH0-330□ 33 M,N 100kHz/0.25V 64.8m 4.3 3.0 330 MSCDRI-127AH0-470□ 47 M,N 100kHz/0.25V 0.10 3.8 2.5 470 MSCDRI-127AH0-560□ 56 M,N 100kHz/0.25V 0.11 3.4 2.35 560 MSCDRI-127AH0-680□ 68 M,N 100kHz/0.25V 0.14 3.1 2.10 680 MSCDRI-127AH0-820□ 82 M,N 100kHz/0.25V 0.16 2.7 1.95 820 MSCDRI-127AH0-101□ 100 M,N 100kHz/0.25V 0.22 2.5 1.70 101 MSCDRI-127AH0-121□ 120 M,N 100kHz/0.25V 0.25 2.3 1.60 121 MSCDRI-127AH0-151□ 150 M,N 100kHz/0.25V 0.28 2.0 1.42 151 MSCDRI-127AH0-181□ 180 M,N 100kHz/0.25V 0.35 1.9 1.30 181 MSCDRI-127AH0-221□ 220 M,N 100kHz/0.25V 0.39 1.7 1.16 221 MSCDRI-127AH0-271□ 270 M,N 100kHz/0.25V 0.51 1.6 1.06 271 MSCDRI-127AH0-281□ 280 M,N 100kHz/0.25V 0.51 1.6 1.06 281 MSCDRI-127AH0-331□ 330 M,N 100kHz/0.25V 0.64 1.4 0.95 331 MSCDRI-127AH0-391□ 390 M,N 100kHz/0.25V 0.70 1.3 0.88 391 MSCDRI-127AH0-471□ 470 M,N 100kHz/0.25V 0.98 1.1 0.79 471 Marking ※ □ specify the inductance tolerance,M(±20%),N(±30%) ※ Isat: Based on inductance change (△L/Lo: drop 25% Max.) @ambient temperature 25℃ Irms: Based on temperature rise (△T: 40℃ Typ.) Rated DC Current: The less value which is Isat or Irms. MAG.LAYERS MSCDRI-127AH0-SERIES Page-2/8 (4) RELIABILITY TEST METHOD ELECTRICAL TEST ITEM SPECIFICATION TEST DETAILS Temperature △L/L20℃≦±10% The test shall be performed after the sample has stabilized in characteristics 0~2000 ppm/℃ an ambient temperature of -20 to +85℃,and the value calculated based on the value applicable in a normal temperature and narmal humidity shall be △L/L20℃≦±10%. MECHANICAL TEST ITEM Substrate bending SPECIFICATION TEST DETAILS △L/Lo≦±5% The sample shall be soldered onto the printed circuit board There shall be in figure 1 and a load applied unitil the figure in the arrow no mechanical direction is made approximately 3mm. damage or elec- 60 sec minimum holding time. trical damage. PCB dimension shall the page 7/9 F(Pressurization) Ivy PRESSURE ROD figure-1 Flammability Burning stops within 10 seconds on a vertical specimen; drips of particles allowed as long as they are not inflamed. There shall be no other damage or problems. Terminal Strength With the component mounted on a PCB obtained from the Supplier with the device to be tested,apply a 17.7 N (1.8 Kg) force to the side of a device being tested. This force shall be applied for 60 +1 seconds. There shall be no other damage or problems. Mechanical Shock 100g's/6ms/Half-sine/12.3ft/sec △L/Lo≦±5% There shall be no mechanical damage. MAG.LAYERS MSCDRI-127AH0-SERIES Page-3/8 MECHANICAL TEST ITEM Vibration SPECIFICATION △L/Lo≦±5% 5g's for 20 minutes, 12 cycles each of 3 orientations. Test from 10-2000 Hz. There shall be no mechanical damage. Solderability New solder Flux (rosin, isopropyl alcohol{JIS-K-1522}) shall be coated More than 90% over the whole of the sample before hard, the sample shall then be preheated for about 2 minutes in a temperature of 130~150℃ and after it has been immersed to a depth 0.5mm below for 3±1 seconds fully in molten solder M705 with a temperature of 245±5℃. More than 90% of the electrode sections shall be couered with new solder smoothly when the sample is taken out of the solder bath. There shall be Soldering heat no damage or (reflow soldering) problems. Temperature profile of reflow soldering Sodering temperature (℃) Resistance to 300 soldering (Peak temperature 260±5℃ 10 sec) 250 200 150 30 sec Min (230+0 ℃) Pre-heating Slow cooling (Stored at room temperature) 100 150 ~ 180℃ 50 2 min 10 sec. 2 min. or more Solder temperature : 260 ±5℃ Dip time: 10 ±1 seconds The chip shall not crack. More than 75% of the terminal electrode shall be covered with solder. MAG.LAYERS MSCDRI-127AH0-SERIES Page-4/8 ENVIROMENT CHARACTERISTICS TEST ITEM High temperature SPECIFICATION △L/Lo≦±5% storage 1000hrs.at rated operating temperature (e.g. 155°C part can be stored for 1000hrs.@ 155°C.Same applies for 125°C There shall be and 105°C. Unpowered. Measurement at 24±4 hours after test no mechanical conclusion. damage. △L/Lo≦±5% Temperature 1000cycles (-40°C to +155°C).Note: If 105°C part or 125°C part the 1000cycles will be at that temperature. Cycling Operational Life There shall be Measurement at 24±4hours after test conclusion. 30min no other dama- maximum dwell time at each temperature extreme.1min. ge of problems maximum transition time. △L/Lo≦±5% 1000hrs. @155°C. If 105°C or 125°C part will be Tested at that temperature. Measurement at 24±4 hours after test conclusion There shall be no mechanical damage. Biased Humidity △L/Lo≦±5% 1000hours 85°C/85%RH. Unpowered.Measurement at 24±4hours after test conclusion. There shall be no mechanical damage. Test conditions: The sample shall be reflow soldered onto the printed circuit board in every test. MAG.LAYERS MSCDRI-127AH0-SERIES Page-5/8 (5) LAND DIMENSION (Ref.) PCB: GLASS EPOXY t=1.6mm (5)-1 LAND PATTERN DIMENSIONS (STANDARD PATTERN) Unit:mm 12.6 7.0 2.8 5.4 (5)-2 SUBSTRATE BENDING TEST BENDING TEST BOARD MAG.LAYERS MSCDRI-127AH0-SERIES Page-6/8 (6) PACKAGING (6)-1 CARRIER TAPE DIMENSIONS (mm) (6)-2 TAPING DIMENSIONS (mm) Unreeling Direction MAG.LAYERS MSCDRI-127AH0-SERIES Page-7/8 (6)-3 REEL DIMENSIONS (mm) (6)-4 QUANTITY 500 pcs/Reel The products are packaged so that no damage will be sustained. Please note that the contents may change without any prior notice due to reasons such as upgrading. MAG.LAYERS MSCDRI-127AH0-SERIES Page-8/8
MSCDRI-127A-220M-RU 价格&库存
很抱歉,暂时无法提供与“MSCDRI-127A-220M-RU”相匹配的价格&库存,您可以联系我们找货
