MPI2520R1-R47-R
MPI2520R1-R47-R
    EATON(伊顿)
    固定电感器 1008 470nH ±20% 4.5A 24mΩ
MPI2520R1-R47-R 数据手册
Technical Data 10199 Effective January 2014 MPI2520 High Current, Low Profile, Miniature Power Inductors HALOGEN Pb HF FREE Applications: • Mobile/smart phones • Handheld/mobile equipment • Digital cameras • Media players • GPS • MP3 Players • Tablets/e-readers l e i t v i t n c u e r f f o E 6 , 1 d 0 t e 2 n . u , e d n i 5 e t m t 1 n e e r l o be c p c a l e s ep Di tem is d r p ory ded e S t n n e e v in omm 2 c e R I25-V MP Environmental data: • Storage temperature range (Component): -40°C to +125°C • Operating temperature range: -40°C to +125°C (ambient + self-temperature rise) • Solder reflow temperature: J-STD-020D compliant Packaging: • Product description: • Halogen free, lead free, RoHS compliant • 125°C maximum total temperature operation • 2.7 x 2.2 x 1.0 / 1.2mm maximum surface mount package • Magnetically shielded, low EMI • Inductance range from 0.47µH to 10.0µH • Current range from 1.1 to 4.8 amps Supplied in tape and reel packaging, 3000 parts per 7” diameter reel Technical Data 10199 MPI2520 High Current, Low Profile Miniature Power Inductors Effective January 2014 Product specifications Part Number5 OCL1 (μH)±20% Irms2 (Amps) Isat3 (Amps) DCR (mΩ) @ 25°C typical DCR (mΩ) @ 25°C max K-Factor4 R0 —1.0mm Height MPI2520R0-R47-R 0.47 4.1 4.4 28 34 2887 MPI2520R0-1R0-R 0.9 3.2 3.2 50 60 1925 MPI2520R0-1R5-R 1.5 2.4 2.6 80 96 1444 MPI2520R0-2R2-R 2.2 2.2 2.4 103 124 1283 MPI2520R0-3R3-R 3.3 1.6 1.6 190 228 1050 MPI2520R0-4R7-R 4.7 1.4 1.4 240 288 825 R1 - 1.2mm Height l e i t v i t n c u e r f f o E 6 , 1 d 0 t e 2 n . u , e d n i 5 e t m t 1 n e e r l o be c p c a l e s ep Di tem is d r p ory ded e S t n n e e v in omm 21 c e R I25-V MP MPI2520R1-R47-R 0.47 4.5 4.8 20 24 2310 MPI2520R1-1R0-R 1.0 3.7 4.0 35 42 1925 MPI2520R1-1R5-R 1.5 2.9 3.4 55 66 1444 MPI2520R1-2R2-R 2.2 2.3 2.7 75 90 1255 MPI2520R1-3R3-R 3.3 1.8 2.4 105 126 962 MPI2520R1-4R7-R 4.7 1.6 1.9 150 180 825 MPI2520R1-5R6-R 5.6 1.5 1.5 200 240 679 MPI2520R1-6R8-R 6.8 1.3 1.3 300 360 679 MPI2520R1-100-R 10.0 1.1 1.2 390 468 525 1. Open Circuit Inductance (OCL) Test Parameters: 1MHz, 0.1Vrms, 0.0Adc, 25°C 2. Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 125°C under worst case operating conditions verified in the end application. 3. Isat: Peak current for approximately 30% rolloff at +25°C 2 www.eaton.com/elx 4. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I. Bp-p:(Gauss), K: (K-factor from table), L: (Inductance in µH), ∆I (Peak to peak ripple current in Amps). 5. Part Number Definition: MPI2520Rx-yyy-R - MPI2520Rx = Product code and size - yyy = Inductance value in µH, R = decimal point, if no R is present then third character = number of zeros. - “-R” suffix = RoHS compliant MPI2520 High Current, Low Profile Miniature Power Inductors Technical Data 10199 Effective January 2014 Dimensions - mm l e i t v i t n c u e r f f o E 6 , 1 d 0 t e 2 n . u , e d n i 5 e t m t 1 n e e r l o be c p c a l e s ep Di tem is d r p ory ded e S t n n e e v in omm 2 c e R I25-V MP Packaging information - mm www.eaton.com/elx 3 Technical Data 10199 MPI2520 High Current, Low Profile Miniature Power Inductors Effective January 2014 Temperature rise vs. total loss Temperature Rise (°C) 50 40 30 20 l e i t v i t n c u e r f f o E 6 , 1 d 0 t e 2 n . u , e d n i 5 e t m t 1 n e e r l o be c p c a l e s ep Di tem is d r p ory ded e S t n n e e v in omm 2 c e R I25-V MP 10 MPI2520R0 MPI2520R1 0 0 0.1 0.2 0.3 0.4 0.5 Total Loss (W) Core loss 4 www.eaton.com/elx 0.6 0.7 0.8 0.9 Technical Data 10199 MPI2520 High Current, Low Profile Miniature Power Inductors Effective January 2014 Inductance characteristics MPI2520R0-1R0-R MPI2520R0-1R5-R 0.50 2.00 0.40 1.60 Inductnace (µH) Inductnace (µH) MPI2520R0-R47-R 0.30 0.20 1.20 0.80 l e i t v i t n c u e r f f o E 6 , 1 d 0 t e 2 n . u , e d n i 5 e t m t 1 n e e r l o be c p c a l e s ep Di tem is d r p ory ded e S t n n e e v in omm 2 c e R I25-V MP 0.10 0.40 0.00 0.00 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 0 5 0.5 1 1.5 2.5 3 3.5 4 6 7 Idc (Amps) Idc (Amps) MPI2520R0-2R2-R MPI2520R0-3R3-R MPI2520R0-4R7-R 5.60 2 MPI2520R1-R47-R 0.50 Inductnace (µH) Inductnace (µH) 4.80 4.00 3.20 2.40 1.60 0.40 0.30 0.20 0.10 0.80 0.00 0.00 0 0.5 1 1.5 Idc (Amps) 2 2.5 3 0 1 2 3 4 5 Idc (Amps) www.eaton.com/elx 5 Technical Data 10199 MPI2520 High Current, Low Profile Miniature Power Inductors Effective January 2014 Inductance characteristics MPI2520R1-2R2-R MPI2520R1-3R3-R MPI2520R1-4R7-R MPI2520R1-1R0-R MPI2520R1-1R5-R 4.80 1.60 Inductnace (µH) Inductnace (µH) 4.00 1.20 0.80 1.60 0.80 0.00 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 MPI2520R1-5R6-R MPI2520R1-6R8-R MPI2520R1-100-R 11.00 10.00 9.00 8.00 7.00 6.00 5.00 4.00 3.00 2.00 1.00 0.00 0 0.4 0.8 1.2 Idc (Amps) www.eaton.com/elx 5 0 0.5 1 1.5 Idc (Amps) Idc (Amps) Inductnace (µH) 2.40 l e i t v i t n c u e r f f o E 6 , 1 d 0 t e 2 n . u , e d n i 5 e t m t 1 n e e r l o be c p c a l e s ep Di tem is d r p ory ded e S t n n e e v in omm 2 c e R I25-V MP 0.40 0.00 6 3.20 1.6 2 2 2.5 3 MPI2520 High Current, Low Profile Miniature Power Inductors Technical Data 10199 Effective January 2014 Solder reflow profile TP TC -5°C Temperature Preheat A Volume mm3 220°C 220°C Table 2 - Lead (Pb) Free Solder (T c) Tsmin Package Thickness 2.5mm ts Volume mm3 2000 260°C 245°C 245°C Time Reference JDEC J-STD-020D Profile Feature Preheat and Soak Standard SnPb Solder 100°C • Temperature min. (Tsmin) • Temperature max. (Tsmax) • Time (Tsmin to Tsmax) (ts) Average ramp up rate Tsmax to Tp Liquidous temperature (TL) Time at liquidous (tL) Peak package body temperature (TP)* Time (tp)** within 5 °C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25°C to Peak Temperature Lead (Pb) Free Solder 150°C 150°C 200°C 60-120 Seconds 60-120 Seconds 3°C/ Second Max. 3°C/ Second Max. 183°C 60-150 Seconds 217°C 60-150 Seconds Table 1 Table 2 20 Seconds** 30 Seconds** 6°C/ Second Max. 6°C/ Second Max. 6 Minutes Max. 8 Minutes Max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company . Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/elx © 2014 Eaton All Rights Reserved Publication No. 10199 — BU-SB131200 January 2014 Eaton is a registered trademark. All other trademarks are property of their respective owners. www.eaton.com/elx 7
MPI2520R1-R47-R 价格&库存
很抱歉,暂时无法提供与“MPI2520R1-R47-R”相匹配的价格&库存,您可以联系我们找货
