Technical Data 10408
Effective June 2015
FP1008R1 and FP1008R2
High frequency, high current power inductors
N
FP ot r
re 10 ec
FP pla 08 om
re 10 ce R1 me
pa 0 m
nd
r
e
8
e
lc R n c e
e m 2 t i om d
en rec s F m for
t i om P1 en ne
s
FP me 008 ded w d
es
10 nd R5
ig
08 ed .
ns
R
6
Applications
Servers
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
Desktop VRMs and EVRDs
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Load modules
DCR Sensing circuits
Environmental data
Product description
High current carrying capacity
Low core loss
Controlled DCR for sensing circuits
Inductance range from 120nH to 300nH
Current range from 38 to 112 amps
10.8 x 8.0 mm footprint surface mount package
in an 8.0 mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range
(Component): -40°C to +125 °C
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
Effective June 2015
Product specifications
OCL1
(nH)±10%
FLL2
(nH) minimum
Irms3
(amps)
Isat14
(amps)
Isat25
(amps)
Isat36
(amps)
DCR (mΩ)
±5% @ 20°C
K-factor7
FP1008R1-R120-R
120
86
79
112
92
84
0.17
342
FP1008R1-R150-R
150
108
79
90
72
67
0.17
342
FP1008R1-R180-R
180
130
79
74
60
54
0.17
342
FP1008R1-R220-R
220
158
79
56
44
42
0.17
342
FP1008R1-R270-R
270
194
79
44
34
32
0.17
342
FP1008R1-R300-R
300
216
79
38
30
28
0.17
342
FP1008R2-R120-R
120
86
74
112
92
84
0.18
342
FP1008R2-R150-R
150
108
74
90
72
67
0.18
342
FP1008R2-R180-R
180
130
74
74
60
54
0.18
342
Part Number9
N
FP ot r
re 10 ec
FP pla 08 om
re 10 ce R1 me
pa 0 m
nd
r
e
8
e
lc R n c e
e m 2 t i om d
en rec s F m for
t i om P1 en ne
s
FP me 008 ded w d
es
10 n d R5
ig
08 ed .
ns
R
6
R1 version
R2 version
FP1008R2-R220-R
220
158
74
56
44
42
0.18
342
FP1008R2-R270-R
270
194
74
44
34
32
0.18
342
FP1008R2-R300-R
300
216
74
38
30
28
0.18
342
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.1Vrms, 0.0Adc, +25°C
2. Full Load Inductance (FLL) Test Parameters: 100kHz, 0.1Vrms, Isat1, +25°C
3. Irms: DC current for an approximate temperature rise of 40ºC without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating
components will affect the temperature rise. It is recommended that the temperature of the part
not exceed 125°C under worst case operating conditions verified in the end application.
4. Isat1: Peak current for approximately 20% rolloff @ +25ºC
5. Isat2: Peak current for approximately 20% rolloff @ +100ºC
6. Isat3: Peak current for approximately 20% rolloff @ +125ºC
7. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K * L * ∆I * 10-3. Bp-p:(Gauss), K: (K-factor from table),
L: (Inductance in nH), ∆I (Peak-to-peak ripple current in Amps).
8. Part Number Definition: FP1008Rx-Rxxx-R
FP1008 R= Product code and size
x = DCR indicator
Rxxx = Inductance value in μH, R = decimal point
- R suffix = RoHS compliant
Dimensions (mm)
Recommended Pad Layout
a
FP1008Rx
Rxxx
wwllyy R
10.8
max
3.0
2.5
2.5
b
8.0
max
2
www.eaton.com/elx
4.06
5.0
0.2
min
3.56
8.0
max
Part marking: FP1008Rx (x= DCR indicator), Rxxx (xxx=inductance value in uH, R=decimal point),
wwllyy = date code, R = revision level
Tolerances are ±0.15 millimeters unless stated otherwise
PCB tolerances are ±0.1 millimeters unless stated otherwise
All soldering surfaces to be coplanar within 0.1 millimeter
DCR measured from point “a” to point “b”
Do not route traces or vias underneath the inductor
Schematic
Effective June 2015
Packaging information (mm)
Supplied in tape and reel packaging, 500 parts per 13” diameter reel.
1.5 dia
4.0
1.5 dia
2.0
N
FP ot r
re 10 ec
FP pla 08 om
re 10 ce R1 me
pa 0 m
nd
r
e
8
e
lc R n c e
e m 2 t i om d
en rec s F m for
t i om P1 en ne
s
FP me 008 ded w d
es
10 n d R5
ig
08 ed .
ns
R
6
1.75
8.3
11.5
24
±0.3
FP1008Rx
Rxxx
wwllyy R
11.0
8.2
16.0
User direction of feed
Temperature rise vs. total loss
FP1008R2
60
50
50
Temperature Rise (°C)
FP1008R1
60
40
30
0.2
0.4
0.6
0.8
1.0
Total Loss (W)
1.2
1.4
1.6
40
30
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
Total Loss (W)
www.eaton.com/elx
3
Effective June 2015
Core loss vs. Bp-p
1
Core Loss (W)
N
FP ot r
re 10 ec
FP pla 08 om
re 10 ce R1 me
pa 0 m
nd
r
e
8
e
lc R n c e
e m 2 t i om d
en rec s F m for
t i om P1 en ne
s
FP me 008 ded w d
es
10 n d R5
ig
08 ed .
ns
R
6
0.1
0.01
0.001
0.0001
100
1000
10000
Bp-p (Gauss)
Inductance characteristics
FP1008R1/R2-R120-R
100%
100%
80%
80%
60%
25°C
40%
FP1008R1/R2-R150-R
120%
% of OCL
% of OCL
120%
60%
25°C
40%
-40°C
-40°C
20%
100°C
20%
100°C
125°C
0%
125°C
0%
60
80
IDC (A)
4
www.eaton.com/elx
100
120
140
60
IDC (A)
80
100
120
Effective June 2015
FP1008R1/R2-R180-R
FP1008R1/R2-R220-R
120%
100%
100%
80%
80%
% of OCL
N
FP ot r
re 10 ec
FP pla 08 om
re 10 ce R1 me
pa 0 m
nd
r
e
8
e
lc R n c e
e m 2 t i om d
en rec s F m for
t i om P1 en ne
s
FP me 008 ded w d
es
10 n d R5
ig
08 ed .
ns
R
6
% of OCL
120%
60%
25°C
40%
100°C
-40°C
100°C
20%
125°C
0%
25°C
40%
-40°C
20%
60%
IDC (A)
60
80
0%
100
125°C
120%
100%
100%
80%
80%
60%
25°C
40%
100°C
40
IDC (A)
50
60
70
80
25°C
-40°C
100°C
20%
125°C
0%
50
60%
40%
-40°C
20%
40
IDC (A)
FP1008R1/R2-300-R
120%
% of OCL
% of OCL
FP1008R1/R2-R270-R
30
60
70
0%
125°C
IDC (A)
40
50
www.eaton.com/elx
60
5
Effective June 2015
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
25°C
Preheat
A
T smax
t
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP1008R2-R300-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.515851+1.34931
- 10+8.6702410+1.11249
- 100+7.12663100+0.91443
- 国内价格 香港价格
- 500+6.27647500+0.80535
- 1000+5.918641000+0.75943
- 1500+5.719001500+0.73382
- 2500+5.477202500+0.70279
- 3500+5.323783500+0.68310
- 5000+5.165895000+0.66285
