Technical Data 4324
Effective June 2017
Supersedes June 2008
FP1105
High current power inductors
Applications
SMD Device
Multi-phase regulators
Voltage Regulator Module (VRM)
Portable electronics
Servers and workstations
Data networking and storage systems
Notebook and desktop computers
Graphics cards and battery power systems
DCR sensing
Environmental data
Product features
11.0 x 8.0 x 4.90mm surface mount package
Ferrite core material
High current carrying capacity
Low core losses
Controlled DCR tolerance for sensing circuits
Inductance range from 101nH to 226nH
Current range from 39 to 81Amps
Frequency range up to 2MHz
Halogen free, lead free, RoHS compliant
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4324
Effective June 2017
Product Specifications
Part Number
FP1105R1-R10-R
FP1105R1-R12-R
FP1105R1-R15-R
FP1105R1-R20-R
FP1105R1-R22-R
OCL1 ± 10% (nH) FLL2 Min. (nH)
100
72
120
86
150
109
192
138
226
163
Irms3 (Amps) Isat14 @ 25°C (Amps) Isat25 @ 125°C (Amps) DCR (mΩ) @ 20°C K-factor6
81
63
467
66
50
467
46
54
42
0.35 ± 8.6%
467
42
34
467
39
28
467
1 Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.10Vrms, 0.0Adc
2 Full Load Inductance (FLL) Test Parameters: 100kHz, 0.1Vrms, Isat1
4 Isat1: Peak current for approximately 20% rolloff at +25°C.
5 Isat2: Peak current for approximately 20% rolloff at +125°C.
3 Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is
necessary for AC currents. PCB pad layout, trace thickness and width, air-flow and proximity of
other heat generating components will affect the temperature rise. It is recommended the part
temperature not exceed 125°C under worst case operating conditions verified in the end
application.
6 K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI * 10-3, Bp-p : (Gauss),
K: (K-factor from table), L: (inductance in nH), ΔI (peak-to-peak ripple current in amps).
7 Part Number Definition: FP1105Rx-Rxx-R
• FP1105 = Product code and size
• Rx is the DCR indicator
• Rxx= Inductance value in μH, R = decimal point • “-R” suffix = RoHS compliant
Dimensions- mm
A = 11.0 Max.
B = 8.0 Max.
Top View
Left View
B
C
1
C = 4.9 Max.
Bottom View
D = 2.4 ± 0.2
Recommended Pad Layout
D
b
E = 2.3 ± 0.3
F = 6.2 Typ.
Schematic
2.8
E
1
2.8
1105Rx A
Rxx
wwllyy R
F
5.8
2
2
Nominal DCR is measured from point “a” to point “b.”
Part Marking:
1105Rx (Rx = DCR indicator)
a
Rxx = inductance value in μH (R = decimal point)
wwllyy = date code
R = revision level
Packaging information - mm
Packaging Information - mm
1.5 dia
1.5 dia
4.0
2.0
A
1.75
SECTION A-A
1
11.5
24.0
+/-0.3
1105Rx
Rxx
wwllyy R
11.3
2
8.2
12.0
Supplied in tape-and-reel packaging, 900 parts per reel, 13” diameter reel.
2
www.eaton.com/electronics
A
User direction of feed
5.2
Technical Data 4324
FP1105
Effective June 2017
Temperature rise vs. total loss
50
Temperature rise(°C )
40
30
0.4
0.6
0.8
1
1.2
1.4
1.6
Total loss (W)
Core Loss vs Bp-p
1MHz
10
500kHz
300kHz
200kHz
Core Loss (W)
1
100kHz
0.1
0.01
0.001
0.0001
100
1000
10000
Bp-p (Gauss)
Inductance characteristics
OCL vs. I sat1
100%
% of OCL
80%
60%
40%
+125°C
20%
+25°C
-40°C
0%
0%
20%
40%
60%
% of I s at1
80%
100%
120%
3
FP1105
Technical Data 4324
Effective June 2017
Solder Reflow Profile
TP
TC -5°C
Temperature
TL
25°C
Preheat
A
T smax
Table 1 - Standard SnPb Solder (Tc)
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
t
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4324 BU-SB08211
May 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“FP1105R1-R10-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 900+9.52771
- 15300+7.16997
- 国内价格 香港价格
- 900+6.28657900+0.78835
- 1800+5.928481800+0.74345
- 2700+5.728772700+0.71840
- 4500+5.487024500+0.68809
- 6300+5.333536300+0.66884
- 9000+5.175659000+0.64904
- 国内价格 香港价格
- 1+10.690031+1.34055
- 10+8.7702810+1.09981
- 100+7.21403100+0.90466
- 国内价格 香港价格
- 900+8.49748900+1.06560
- 国内价格 香港价格
- 900+9.55967900+1.19880
- 国内价格
- 1+10.15290
- 10+8.39083
- 55+7.38393
- 100+7.13220
- 350+6.46094
- 500+6.37703
- 900+6.29312
