SCIHP0530-1R0
SCIHP0530-1R0
    SIGNAL
    非标准
    固定电感器 Nonstandard 1µH ±20% 7A
SCIHP0530-1R0 数据手册
SCIHP0530 SMD POWER INDUCTORS 1.0±0.3 3.0MAX 7.0 XXX XXX 2.5 1.5±0.3 4.9MAX 5.2MAX 3.0 MARKING ● Features 1. Lowest DCR/uH in this small package size. 2. Frequency range up to 3.0MHZ. 3. -55℃ to +125℃ operating temperature (*). 4. Handles high transient current spikes without saturation. 5. Composite construction providing extremely low buzz noise. ELECTRICAL CHARACTERISTICS DC Saturation Temperature Test Inductance Resistance Current Current Frequency (uH) (mΩ MAX) (A) (3) (A) (4) (1) SCIHP0530-R68 SCIHP0530-1R0 100 (2) 0.68 200KHz 12.0 14.0 8.5 1.00 200KHz 14.0 11.0 7.0 SCIHP0530-1R5 1.50 200KHz 25.0 10.0 6.0 SCIHP0530-2R2 2.20 200KHz 35.0 9.0 5.5 SCIHP0530-3R3 3.30 200KHz 38.0 7.0 5.0 SCIHP0530-4R7 4.70 200KHz 60.0 5.0 3.0 Inductance (uH) Part Number BCIHP0530 Inductance byby current SCIHP0530 Inductancedecrease decrease current 10 4R7 1.0 1R5 R68 0.1 0.01 10 1000 100 100000 10000 Temperature rise℃ DC current(mA) 80 70 60 50 40 30 20 10 0 SCIHP0530 Temperature by current BCIHP0530Temperature Temperaturerise riserise by current SCIHP0530 by current 4R7 1R5 R68 2000 4000 6000 8000 1000012000 140001600018000 DC current(mA) (1). Inductance tolerance ±20% tested at 0.25V, 0ADC and 25℃ (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 20% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ ambient (*). Part temperature (ambient + temp rise) should not exceed 125℃ under worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provisions may affect the temperature of the part. Part temperature should be verified in the end application. Click here for QUANTITY PER REEL & PACKING INFORMATION © 2019 Signal Transformer –Specification subject to change without notice. 12.19 Custom versions available upon request. belfuse.com/signal 199 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com
SCIHP0530-1R0
物料型号:SCIHP0530
器件简介:SMD功率电感器,具有以下特点: 1. 在这种小尺寸封装中具有最低的DCR/uH比。 2. 频率范围高达3.0MHz。 3. 工作温度范围为-55℃至+125℃。 4. 能够处理高瞬态电流尖峰而不饱和。 5. 复合结构提供极低的噪音。
引脚分配:文档中未提供引脚分配信息。
参数特性: - 测试频率:200kHz - 直流电阻(mΩ MAX):不同型号的电感值不同,例如SCIHP0530-R68为12.0mΩ,SCIHP0530-4R7为60.0mΩ。 - 饱和电流(A):不同型号的电感值不同,例如SCIHP0530-R68为14.0A,SCIHP0530-4R7为5.0A。 - 温度电流(A):不同型号的电感值不同,例如SCIHP0530-R68为8.5A,SCIHP0530-4R7为3.0A。
功能详解:文档中未提供详细的功能解释。
应用信息:文档中未提供应用信息
封装信息:文档中未提供封装信息
SCIHP0530-1R0 价格&库存
很抱歉,暂时无法提供与“SCIHP0530-1R0”相匹配的价格&库存,您可以联系我们找货
