Technical Data 4343
Effective December 2015
Supersedes September 2008
FP0807
High frequency, high current power inductors
Applications
Multi-phase and Vcore regulators
Voltage Regulator Module (VRM)
Desktop and server VRMs and EVRDs
Data networking and storage systems
Graphics cards and battery power systems
Point-of-load modules
Environmental Data
Product description
High current carrying capacity
Low core losses
Inductance range from 70nH to 220nH
Current range from 35 to 108 amps
Frequency range up to 2MHz
7.4 x 7.6 footprint surface mount package in a
7.0mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range: -40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
FP0807
Technical Data 4343
Product Specifications
Isat14 (amps)
I sat25
(amps)
DCR (mΩ)
±6% @ 20°C
K-factor6
45
108
79
0.50
520
45
77
55
0.50
520
86
45
66
48
0.50
520
160
115
45
48
36
0.50
520
180
129
45
42
32
0.50
520
FP0807R1-R20-R
200
144
45
38
28
0.50
520
FP0807R1-R22-R
220
158
45
35
25
0.50
520
Part Number7
OCL1 (nH) ±10%
FLL2 (nH) min
FP0807R1-R07-R
70
50
FP0807R1-R10-R
100
72
FP0807R1-R12-R
120
FP0807R1-R16-R
FP0807R1-R18-R
Irms3 (amps)
R1 version
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.10Vrms, 0.0Adc @25°C
2. Full Load Inductance (FLL) Test Parameters: 100kHz, 0.1Vrms, Isat1 @25°C
3. Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is necessary for AC
currents. PCB pad layout, trace thickness and width, air-flow and proximity of other heat generating components will
affect the temperature rise. It is recommended the part temperature not exceed 125°C under worst case operating
conditions verified in the end application.
4. Isat1: Peak current for approximately 20% rolloff at +25°C.
5. Isat2: Peak current for approximately 20% rolloff at +125°C.
6. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I * 10-3, Bp-p : (Gauss), K: (K-factor from
table), L: (inductance in nH), ∆I (peak-to-peak ripple current in amps).
7. Part Number Definition: FP0807Rx-Rxx-R
• FP0807R = Product code and size
• x is the version indicator
• -Rxx= Inductance value in μH, R = decimal point
• “-R” suffix = RoHS compliant
Dimensions (mm)
R ecom m ended P ad Layout
7.4
m ax
7.0
m ax
0807Rx
Rxx
wwllyy R
2.0
b
1
7.6
max
S chem atic
2.6
3.3
typ.
1
2.7
2
2.0
+/-0.2
2
a
2
1.55
+/-0.2
2.6
Part marking: 0807Rx (x= version indicator )
Rxx (xx=inductance value in uH, R= decimal point)
wwllyy = date code, R = revision level
DCR measured from point “a” to point “b”
Do not route traces or vias underneath the inductor
Packaging information (mm)
Supplied in tape-and-reel packaging, 600 parts per reel, 13” diameter reel.
4.0
1.5 dia.
2.0
1.5 dia.
1.75
A
1
0807Rx
Rxx
wwllyy R
9.5
2
7.7
Section A-A
2
www.eaton.com/elx
7.0
7.5
16.0
User direction of feed
A
7.5
16.0
+/-0.3
FP0807
Technical Data 4343
Temperature rise vs.total loss
50
Tem perature R ise(°C )
40
30
0.4
0.6
0.8
1
1.2
1.4
1.6
1.8
2
T otal Loss (W )
Core loss
C o re L o s s v s . B p -p
1M H z
10
200kH z
1
C o re L o s s (W )
500kH z
300kH z
100kH z
0.1
0.01
0.001
0.0001
0.00001
100
1000
10000
B p -p (G a u s s )
Inductance characteristics
% of O C L v s. % of I s a t 1
100%
90%
80%
-40°C
% of OCL
70%
+25°C
60%
+125°C
50%
40%
30%
20%
10%
0%
0%
20%
40%
60%
80%
100%
120%
140%
160%
% of I s a t 1
www.eaton.com/elx
3
FP0807
Technical Data 4343
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP0807R1-R10-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+19.531711+2.52643
