Technical Data 4084
Effective September 2015
Supersedes November 2009
SD3118
Low profile power inductors
Applications
Mobile/smart phones
Tablets/e-readers
Media players
Digital cameras
Small LED driver and LCD displays
Handheld/mobile equipment
Environmental Data
Description
Low profile shielded drum core
Compact footprint utilizes less board space
Inductance Range from 1.0μH to 1,000μH
Current range from 0.083 to 2.94 amps
3.2 x 3.2mm footprint surface mount package
in a 1.8mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range (Component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
SD3118
Technical Data 4084
Product Specifications
Part Number6
OCL1
(μH)
Part marking
designator
Irms2
(amps)
Isat3
(amps)
DCR (Ω) typical
@ +20°C
K-factor4
SD3118-1R0-R
1.04±30%
A
2.01
3.07
0.041
84
SD3118-1R5-R
1.44±30%
B
1.81
2.42
0.051
68
SD3118-2R2-R
2.12±30%
C
1.50
2.00
0.074
57
SD3118-3R3-R
3.36±30%
D
1.22
1.59
0.11
56
SD3118-4R7-R
4.90±30%
E
1.02
1.31
0.16
39
SD3118-6R8-R
6.72±30%
F
0.85
1.12
0.23
32
SD3118- 8R2-R
8.10±30%
G
0.81
1.02
0.26
29
SD3118- 100-R
10.4±30%
H
0.75
0.90
0.30
26
SD3118-150-R
14.9±30%
I
0.62
0.75
0.44
21
SD3118-220-R
22.5±30%
J
0.50
0.61
0.68
18
SD3118-330-R
33.1±30%
K
0.41
0.51
0.99
14
SD3118-470-R
47.5±30%
L
0.37
0.42
1.2
12
SD3118-221-R
222±20%
M
0.182
0.177
4.8
6
SD3118-331-R
330±20%
N
0.146
0.145
7.4
5
SD3118-471-R
470±20%
O
0.130
0.122
9.2
4
SD3118-681-R
680±20%
P
0.107
0.101
14
3
SD3118-102-R
999±20%
Q
0.087
0.083
21
3
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.1Vrms, 0.0Adc, @ +25°C
2. Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 125°C under worst case operating
conditions verified in the end application.
3. Isat: Peak current for approximately 30% rolloff @ +20°C
4. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (mTesla), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
5. Part Number Definition: SD3118-xxx-R
SD3118 = Product code and size
xxx= Inductance value in uH, R= decimal point, if no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Pin #1 indicator
1.8
max
Recommended Pad Layout
3.9
max
1.5 typ
2.40
Schematic
1
1.70
3.2 max
3.2 max
Part marking: dot for pin 1 indicator (orientation purposes only)
xxx = 3 digit marking (first digit indicates inductance value per letter in
Part marking designator, second digit is bi-weekly date code, third digit is
last digit of year produced)
All soldering surfaces to be coplanar within 0.10 millimeters
PCB tolerances are ±0.1 millimeters unless stated otherwise
Do not route traces or vias underneath the inductor
2
www.eaton.com/elx
0.8
2
SD3118
Technical Data 4084
Packaging information (mm)
Supplied in tape and reel packaging, 4,100 parts per 13” diameter reel
4.00
1.2 Dia.
min.
1.5 Dia.
+0.1/-0.0
2.00
1.75
A
Ao = 4.0mm
A1 = 0.93mm
Bo = 4.20mm
B1 = 1.25mm
Ko = 2.00mm
1
B1
10.25
Bo
5.50
12.0
±0.3
2
3.4
Ko
A1
SECTION A-A
Ao
3.4
A
8.0
Direction of feed
Temperature Rise (°C)
Temperature rise vs. total loss
90
80
70
60
50
40
30
0.1
0.15
0.2
0.25
0.3
0.35
0.4
0.45
Total Loss(W)
www.eaton.com/elx
3
SD3118
Technical Data 4084
Core loss vs. Bp-p
10
Core Loss (W)
1MHz
1
500kHz
0.1
300kHz
200kHz
100kHz
50kHz
0.01
0.001
0.0001
0.00001
10
10
100
1000
Bp-p (mT)
Inductance characteristics
OCL vs. lsat
120%
110%
100%
% of L initial
90%
80%
70%
-40°C
60%
50%
40%
25°C
30%
85°C
20%
10%
0%
0%
10%
20%
30%
40%
50%
60%
70%
80%
% of lsat
4
www.eaton.com/elx
90%
100% 110%
120%
130%
140%
SD3118
Technical Data 4084
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“SD3118-681-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4100+17.544834100+2.26990
