Technical Data 10553
Effective September 2016
HCM1A1707
Automotive grade
High current power inductors
Applications
Product features
Body electronics
• Central body control module
Headlamps, tail lamps and interior lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system/ Car black
box system
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
Digital instrument cluster
In-vehicle infotainment (IVI) and navigation
AEC-Q200 Grade 1 qualified
High current carrying capacity
Magnetically shielded, low EMI
Frequency range up to 1 MHz
Chassis and safety electronics
• Airbag control unit
Inductance range from 1.0 μH to 68 μH
Electronic stability control system (ESC)
Current range from 5.2 A to 48 A
Electric parking brake
17.5 mm x 17.2 mm footprint surface mount
package in a 7.0 mm height
Electronic power steering (EPS)/
Anti-locking braking system (ABS)
Moisture Sensitivity Level (MSL): 1
Alloy powder core material
Engine and Powertrain Systems
• Electric pumps, motor control and auxiliaries
Halogen free, lead free, RoHS compliant
Powertrain control module (PCU)/
Engine Control unit (ECU)
Transmission Control Unit (TCU)
Environmental Data
Storage temperature range (Component):
-55 °C to +155 °C
Operating temperature range: -55 °C to +155 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCM1A1707
Automotive grade high current power inductors
Product Specifications
Part Number6
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
K-factor5
HCM1A1707-1R0-R
1.0
0.64
33
48
1.4
1.55
133
HCM1A1707-1R5-R
1.5
0.96
25.5
46
2.05
2.25
94
HCM1A1707-2R2-R
2.2
1.41
24
28
2.4
2.65
105
HCM1A1707-3R3-R
3.3
2.11
21
22
3.1
3.40
103
HCM1A1707-4R7-R
4.7
3.01
18
4.72
85
HCM1A1707-6R8-R
6.8
4.35
12
18
6.55
7.55
79
HCM1A1707-8R2-R
8.2
5.25
12
16
8.1
8.70
45
HCM1A1707-100-R
10
6.4
12
14
9.3
10
49
HCM1A1707-150-R
15
9.6
9.0
14
14.5
15.5
30
HCM1A1707-220-R
22
14.1
8.0
11
20.5
23
27
HCM1A1707-330-R
33
21.1
6.0
9.0
35.1
37
HCM1A1707-470-R
47
30.1
5.5
8.0
41
47
17
HCM1A1707-680-R
68
43.5
5.2
6.0
51
60
17
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C
3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 155 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM1A1707-xxx-R
HCM1A1707 = Product code and size
xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Part marking: HCM1A1707, XXX=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros.
xxxx=Lot code
All soldering surfaces to be coplanar within 0.1 millimeters
DCR measured from point “a” to point “b”
Color: Grey
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
HCM1A1707
Packaging information (mm)
Drawing not to scale
Supplied in tape and reel packaging, 200 parts per 13” diameter reel
Core loss vs Bp-p
HCM1A1707-1R0-R
10000
1 MHz
HCM1A1707-1R5-R
10000
500 kHz
1 MHz
300 kHz
300 kHz
1000
100 kHz
Core Loss (mW)
Core Loss (mW)
1000
50 kHz
25 kHz
100
100 kHz
50 kHz
25 kHz
100
10
10
1
500 kHz
100
1000
Bp-p (Gauss)
10000
1
100
1000
Bp-p (Gauss)
10000
3
HCM1A1707
Core loss vs Bp-p
HCM1A1707-2R2-R
10000
500 kHz
1 MHz
100 kHz
50 kHz
100
25 kHz
10
100
1000
HCM1A1707-4R7-R
1 MHz
50 kHz
25 kHz
1000
Bp-p (Gauss)
10000
HCM1A1707-6R8-R
1 MHz
1000
100 kHz
100
100
500 kHz
300 kHz
500 kHz
300 kHz
100 kHz
50 kHz
100
25 kHz
10
100
1000
Bp-p (Gauss)
1 MHz
1
10000
HCM1A1707-8R2-R
10000
1000
1 MHz
Core Loss (mW)
25 kHz
10
500 kHz
300 kHz
1000
50 kHz
10000
B p-p(Gauss)
HCM1A1707-100-R
500 kHz
100 kHz
100
100
10000
300 kHz
1000
Core Loss (mW)
25 kHz
10000
Core Loss (mW)
Core Loss (mW)
1
10
4
50 kHz
100
10000
Bp-p (Gauss)
1000
1
100 kHz
10
10000
1
500 kHz
300 kHz
1000
Core Loss (mW)
Core Loss (mW)
1 MHz
300 kHz
1000
1
HCM1A1707-3R3-R
10000
100 kHz
50 kHz
25 kHz
100
10
100
1000
Bp-p (Gauss)
10000
1
100
1000
Bp-p (Gauss)
10000
HCM1A1707
Core loss vs Bp-p
HCM1A1707-150-R
10000
1 MHz
500 kHz
1 MHz
300 kHz
1000
300 kHz
Core Loss (mW)
Core Loss (mW)
50 kHz
25 kHz
100
10
100 kHz
50 kHz
25 kHz
100
10
100
1000
Bp-p (Gauss)
1 MHz
1
10000
HCM1A1707-330-R
10000
100
1000
HCM1A1707-470-R
10000
500 kHz
1 MHz
1000
Core Loss (mW)
100 kHz
Core Loss (mW)
500 kHz
300 kHz
1000
50 kHz
25 kHz
100
10
1
10000
Bp-p (Gauss)
300 kHz
100 kHz
50 kHz
25 kHz
100
10
100
1000
10000
Bp-p (Gauss)
HCM1A1707-680-R
10000
1 MHz
1
100
1000
Bp-p (Gauss)
10000
500 kHz
300 kHz
1000
Core Loss (mW)
500 kHz
1000
100 kHz
1
HCM1A1707-220-R
10000
100 kHz
50 kHz
25 kHz
100
10
1
100
1000
Bp-p (Gauss)
10000
5
HCM1A1707
Inductance and temperature rise vs. current
1.4
80
60
0.6
50
40
0.4
30
40
Idc (A)
50
60
HCM1A1707-2R2-R
2.5
70
1.0
60
0.8
50
40
0.6
30
10
0.0
80
0.4
90
1.2
Inductance (µH)
70
0.8
100
0.0
10
Idc (A)
30
40
50
HCM1A1707-3R3-R
3.5
100
90
1.5
60
50
1.0
40
30
0.5
10
15
Idc (A)
30
35
40
45
2
40
30
1
6
10
15
Idc (A)
30
35
HCM1A1707-6R8-R
10
15
Idc (A)
30
35
80
5
70
60
4
50
3
40
30
2
Inductance (µH)
50
Temperature Rise (°C)
Inductance (µH)
60
30
6
80
3
40
7
90
70
50
1.5
0.0
100
4
60
2.0
0.5
HCM1A1707-4R7-R
5
70
1.0
10
0.0
80
2.5
Inductance (µH)
70
90
3.0
80
Inductance (µH)
2.0
90
HCM1A1707-1R5-R
1.6
Inductance (µH)
1.0
100
10
10
Idc (A)
15
HCM1A1707-1R0-R
1.2
HCM1A1707
30
2
70
6
60
50
4
40
30
2
10
4
6
8
10
12
14
Idc (A)
16
18
16
HCM1A1707-150-R
100
4
6
8
10
Idc (A)
12
14
16
18
HCM1A1707-220-R
24
90
8
50
40
6
30
4
Inductance (µH)
70
10
80
12
80
70
16
60
12
50
40
8
30
10
10
2
4
6
8
Idc (A)
10
12
14
16
18
HCM1A1707-330-R
35
30
25
45
90
40
80
35
60
50
15
40
30
10
5
4
6
Idc (A)
8
10
12
14
70
Inductance (µH)
90
14
40
3
80
50
Inductance (µH)
4
Inductance (µH)
60
1
Inductance (µH)
8
70
5
Inductance (µH)
90
80
6
90
7
HCM1A1707-100-R
10
100
2
4
6
8
10
Idc (A)
12
14
16
HCM1A1707-470-R
100
90
80
70
30
60
25
50
15
10
5
HCM1A1707-8R2-R
8
4
6
Idc (A)
8
10
12
HCM1A1707
HCM1A1707-680-R
70
100
90
60
80
70
60
40
50
30
40
30
10
2
3
4
5
Idc (A)
6
7
8
9
10
Inductance (µH)
50
HCM1A1707
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1A1707-150-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+38.83331200+5.04821
- 400+36.62452400+4.76107
- 600+35.39270600+4.60094
- 1000+33.901251000+4.40706
- 1400+33.307041400+4.32981
- 国内价格 香港价格
- 1+57.414211+7.46366
- 10+47.2315310+6.13995
- 25+43.6915425+5.67976
- 50+41.1989450+5.35573
- 100+38.84829100+5.05016
