S34567
S34567
    NEWAVA
    IND_21.59X20.06MM_TM
    固定电感器 Radial, Horizontal, 8 Leads 47µH 3.7A 40mΩ 2MHz
S34567 数据手册
EP17 LM259X Inductor 47 uHy 3.70 ADC 0.850 Max 5 6 7 8 NEWAVA S34567 YYWW 0.79 Max 4 3 2 All Pins: 0.190 Sq. 1 0.090 Min 0.640 Max 0.600 +/- 0.020 0.200 Typ 1,2,3,4 Jumper Terminals on PC board ELECTRICAL SPECS: 1: INDUCTANCE: @ 10 kHz, 0.1 Vrms (1 thru 4 to 5 thru 8) = 47 - 60 uHy 5,6,7,8 Jumper Terminals on PC board 2: DCRs: (1 thru 4 tp 5 thru 8) = 0.040 Ohms Max. 3: SRF: 2.0 MHz Min 3/28/03 A 4: HIPOT: 500 VDC Winding to core (2 Sec., 5 mA Max) REV. + - All pins may not be used. Specifications at room temperature of 25 C. .XXX - KAM DATE ECN BY TOLERANCES ON ANGLE .XX + + - - Production Release DESCRIPTION Newava Tech. Watertown, SD 57201 605-886-0264 DATE DRAWN: SCALE CHECKED: APPROVED: - KAM NEXT ASSY: THIS PRINT MUST NOT BE COPIED IN WHOLE OR IN PART MODEL 47 uHy Inductor 3.70 ADC DRAWING NO. S34567 OR USED DETRIMENTALLY TO OUR INTEREST REV. A SHEET 1 OF 1
S34567 价格&库存
很抱歉,暂时无法提供与“S34567”相匹配的价格&库存,您可以联系我们找货
