Technical Data 4325
Effective January 2016
Supersedes May 2008
FP0705
High frequency, high current power inductors
Applications
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
• Server and desktop
Central processing unit (CPU)
Graphics processing unit (GPU)
Application specific integrated circuit (ASIC)
High power density
Data networking and storage systems
Graphics cards and battery power systems
Portable electronics
Point-of-Load modules
Product description
High current carrying capacity
Environmental data
Low core loss
Inductance Range from 72 nH to 220 nH
Storage temperature range (Component):
-40 °C to +125 °C
Current range from 20 A to 65 A
7.0 mm x 7.0 mm footprint surface mount
package in a 4.95 mm height
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Ferrite core material
Solder reflow temperature:
J-STD-020D compliant
Halogen free, lead free, RoHS compliant
HALOGEN
Pb HF
FREE
FP0705
Technical Data 4325
Product specifications
OCL1
(nH) ±10%
FLL2
(nH) minimum
Irms3
(A)
Isat14
(A)
Isat25
(A)
DCR (mΩ)
@ 20°C
K-factor7
FP0705R1-R07-R
72
51
43
65
50
0.25 ± 10%
826
FP0705R1-R10-R
105
78
43
44
34
0.25 ± 10%
826
FP0705R1-R12-R
120
86
43
37
30
0.25 ± 10%
826
FP0705R1-R15-R
150
108
43
30
24
0.25 ± 10%
826
FP0705R1-R18-R
180
130
43
25
0.25 ± 10%
826
FP0705R1-R22-R
226
159
43
0.25 ± 10%
826
FP0705R2-R07-R
72
51
38
65
50
0.32 ± 9.4%
826
FP0705R2-R10-R
105
78
38
44
34
0.32 ± 9.4%
826
FP0705R2-R12-R
120
86
38
37
30
0.32 ± 9.4%
826
FP0705R2-R15-R
150
108
38
30
24
0.32 ± 9.4%
826
FP0705R2-R18-R
180
130
38
25
0.32 ± 9.4%
826
FP0705R2-R22-R
226
159
38
0.32 ± 9.4%
826
FP0705R3-R07-R
72
51
32
65
50
0.46 ± 6.5%
826
FP0705R3-R10-R
105
78
32
44
34
0.46 ± 6.5%
826
FP0705R3-R12-R
120
86
32
37
30
0.46 ± 6.5%
826
FP0705R3-R15-R
150
108
32
30
24
0.46 ± 6.5%
826
FP0705R3-R18-R
180
130
32
25
0.46 ± 6.5%
826
FP0705R3-R22-R
226
159
32
0.46 ± 6.5%
826
Part Number7
R1 version
R2 version
R2 version
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.1 Vrms, Isat1, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part
not exceed 125 °C under worst case operating conditions verified in the end application.
4. Isat1: Peak current for approximately 20% rolloff @ +25 °C
5. Isat2: Peak current for approximately 20% rolloff @ +125 °C
6. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K * L * ∆I * 10-3. Bp-p:(Gauss), K: (K-factor from table),
L: (Inductance in nH), ∆I (Peak to peak ripple current in Amps).
7. Part Number Definition: FP0705Rx-Rxx-R
FP0705= Product code and size
Rx= Version indicator
-Rxx= Inductance value in μH, R= decimal point
-R suffix = RoHS compliant
Dimensions (mm)
Part marking: 0705Rx (Rx = version indicator), Rxx = Inductance value in uH, R = decimal point,
wwllyy = date code, R = revision level
Tolerances are ±0.25 millimeters unless stated otherwise
PCB tolerances are ±0.1 millimeters unless stated otherwise
All soldering surface to be coplanar within 0.1016 millimeters
DCR measured between point “a” and point “b”
Do not route traces or vias underneath the inductor
2
www.eaton.com/elx
FP0705
Technical Data 4325
Packaging information (mm)
Supplied in tape and reel packaging , 950 parts per 13” diameter reel
2.0
4.0
1.5
dia.
1.75
A
7.5
1
0705Rx
Rxx
wwllyyR
16.00
±0.30
6.5 7.1
2
1.5
dia
12.0
A
B
B
5.1
SECTION A-A
7.1
3.5
SECTION B-B
User direction of feed
Temperature rise vs. total loss
www.eaton.com/elx
3
FP0705
Technical Data 4325
Core loss vs. Bp-p
Inductance characteristics
OCL vs. Isat1
100%
% of OCL
80%
60%
40%
+125 °C
20%
0%
4
+25 °C
-40 °C
0%
www.eaton.com/elx
20%
40%
60%
% of Isat1
80%
100%
120%
FP0705
Technical Data 4325
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP0705R3-R18-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 70+6.81933
- 350+6.73469
- 700+6.54124
