Technical Data 4334
Effective January 2016
Supersedes January 2010
FP0708
High frequency, high current power inductors
Applications
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
• Server and desktop
Central processing unit (CPU)
Graphics processing unit (GPU)
Application specific integrated circuit (ASIC)
High power density
Data networking and storage systems
Graphics cards and battery power systems
Portable electronics
Point-of-Load modules
Product description
High current carrying capacity
Environmental data
Low core loss
Frequency range up to 2 MHz
Storage temperature range (Component):
-40 °C to +125 °C
Inductance Range from 72 nH to 200 nH
Current range from 36 A to 90 A
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
7.0 mm x 8.5 mm footprint surface mount
package in a 7.2 mm height
Solder reflow temperature:
J-STD-020D compliant
Ferrite core material
Halogen free, lead free, RoHS compliant
HALOGEN
Pb HF
FREE
FP0708
Technical Data 4334
Product specifications
Part Number7
OCL1
(nH) ±10%
FLL2
(nH) minimum
Irms3
(A)
Isat14
(A)
Isat25
(A)
DCR (mΩ)
± 8.6% @ 20°C
K-factor6
FP0708R1-R07-R
72
52
44
90
72
0.35
557
FP0708R1-R09-R
90
64
44
75
60
0.35
557
FP0708R1-R10-R
105
75
44
68
54
0.35
557
FP0708R1-R12-R
120
86
44
59
47
0.35
557
FP0708R1-R15-R
150
108
44
47
37
0.35
557
FP0708R1-R19-R
190
135
44
37
29
0.35
557
FP0708R1-R20-R
200
144
44
36
27
0.35
557
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0. 1Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.1 Vrms, Isat1, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part
not exceed 125 °C under worst case operating conditions verified in the end application.
4. Isat1: Peak current for approximately 20% rolloff @ +25 °C
5. Isat2: Peak current for approximately 20% rolloff @ +125 °C
6. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K * L * ∆I * 10-3. Bp-p:(Gauss), K: (K-factor from table),
L: (Inductance in nH), ∆I (Peak to peak ripple current in Amps).
7. Part Number Definition: FP0708Rx-Rxx-R
FP0708= Product code and size
Rx= Version indicator
-Rxx= Inductance value in μH, R= decimal point
-R suffix = RoHS compliant
Dimensions (mm)
Part marking: 0708Rx (Rx = version indicator), Rxx = Inductance value in uH, R = decimal point,
wwllyy = date code, R = revision level
Tolerances are ±0.15 millimeters unless stated otherwise
PCB tolerances are ±0.1 millimeters unless stated otherwise
All soldering surface to be coplanar within 0.1016 millimeters
DCR measured between point “a” and point “b”
Do not route traces or vias underneath the inductor
Packaging information (mm)
Supplied in tape and reel packaging , 640 parts per 13” diameter reel
2
www.eaton.com/elx
FP0708
Technical Data 4334
Temperature rise vs. total loss
Core loss vs. Bp-p
www.eaton.com/elx
3
Technical Data 4334
Inductance characteristics
4
www.eaton.com/elx
FP0708
FP0708
Technical Data 4334
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP0708R1-R12-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.88123
- 200+1.11500
- 640+1.07590
- 1280+1.05646
- 国内价格 香港价格
- 640+11.05768640+1.43747
