SL1616A-R06LHF
SL1616A-R06LHF
    ITG
    SMD,4x4mm
    固定电感器 Nonstandard 65nH ±15% 19A 0.32mΩ
SL1616A-R06LHF 数据手册
SL1616 Series 1. Features of SL1616 Series: • • • • • • • • • • Ferrite based SMD inductor with lower core loss. Inductance range: 50.0nH to 100.0 nH, custom values are welcomed. High current output chokes , up to 29.0 Amp with approx. 20% roll off. Low profile 4.00 mm Max. height. 4.00 x 4.00 mm Foot Print. Ideal for Buck Converter, VRM & High Density Board Design. Operating frequency of up to 1.0MHz. Operating temperature range of -55°C to + 130°C. RoHS & HF compliant. T & R Qty’s: 2000pcs, 13'' Reel. 2. Electrical Characteristics of SL1616 Series: Inductance DCR Isat1 Isat2 Isat3 Irms (nH) (mΩ) (A) (A) (A) (A) ±15% / 20% ±9.0%/16% @25℃ @45℃ @100℃ @25℃ SL1616A-R05LHF 50 , 15% 0.32,9.0% 29.00 28.00 26.00 19.00 SL1616B-R05LHF 50 , 15% 1.00,16% 29.00 28.00 26.00 11.00 SL1616A-R06LHF 65 , 15% 0.32,9.0% 26.00 25.00 22.00 19.00 SL1616B-R06LHF 65 , 15% 1.00,16% 26.00 25.00 22.00 11.00 Part Number SL1616A-R08MHF 80 , 20% 0.32,9.0% 22.00 21.00 17.00 19.00 SL1616B-R08MHF 80 , 20% 1.00,16% 22.00 21.00 17.00 11.00 SL1616A-R10MHF 100 , 20% 0.32,9.0% 17.00 15.00 13.00 19.00 SL1616B-R10MHF 100 , 20% 1.00,16% 17.00 15.00 13.00 11.00 3. Mechanical Dimension(Unit: mm): D B A B C D E F G Max. Max. Max. Max. Nom. Nom. Nom. 4.00 3.90 4.00 4.00 1.30 1.40 1.30 C F A 2xG E 0.9 Marking 2x1.9 2x1.7 Suggested Pad Layout a b Part Marking: Rxx x: xx is inductance value in uH(R:decimal point), x is special code. Notes: 1. Open Circuit Inductance (OCL) test condition: 100KHz, 0.1Vrms, 0A DC at 25Ԩ. 2. Full Load Inductance (FLL) Test condition:100KHz,0.1Vrms , Isat ;(Ta=25 Ԩ). 3. Isat1,Isat2 & Isat3: DC current that will cause inductance to drop approximately by 20% ;(Ta=25Ԩ). 4. Irms : DC current for an approximate temperature rise of 40Ԩ without core loss. Derating is necessary for AC currents. Verify and check PCB pad layout, trace thickness, width, air-flow and proximity of other heat generating components as it will have an effect on the temperature rise. It is recommended the part temperature not exceed 130°C under worst case operating conditions verified in the end application. 6. The nominal DCR is measured from point "a" to point "b“ , as shown above on the mechanical drawing. ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Tokyo 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: February 21, 2019 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SL1616 Series L (nH) 4. Inductance Characteristics of SL1616 Series (Inductance vs Current): SL1616x-R05LHF 55.0 50.0 45.0 40.0 35.0 30.0 25.0 20.0 15.0 10.0 5.0 0.0 25Ԩ 45Ԩ 100Ԩ 0 5 10 15 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 Direct Current (A) SL1616x-R06LHF 70.0 65.0 60.0 55.0 50.0 45.0 40.0 35.0 30.0 25.0 20.0 15.0 10.0 5.0 0.0 L (nH) 25Ԩ 45Ԩ 100Ԩ 0 5 10 15 20 21 22 23 24Direct 25 Current 26 27 (A) 28 29 30 31 32 33 34 35 SL1616x-R08MHF 88.0 80.0 72.0 64.0 56.0 48.0 40.0 32.0 24.0 16.0 8.0 0.0 L (nH) 25Ԩ 45Ԩ 100Ԩ 0 5 10 15 16 17 18 19 20 21 22 Direct Current (A) 23 24 25 26 27 28 29 SL1616x-R10MHF 110.0 100.0 90.0 80.0 70.0 60.0 50.0 40.0 30.0 20.0 10.0 0.0 L (nH) 25Ԩ 45Ԩ 100Ԩ 0 ● 5 10 11 12 13 14 15 16 17 Direct Current (A) 18 19 20 21 22 23 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Tokyo 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision D.1: February 21, 2019 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
SL1616A-R06LHF 价格&库存
很抱歉,暂时无法提供与“SL1616A-R06LHF”相匹配的价格&库存,您可以联系我们找货
