85093-F0
85093-F0
    NEWAVA
    固定电感器 Nonstandard 900nH ±25% 400mΩ
85093-F0 数据手册
LTCC High Temperature Inductors 0.15x0.15 inch (3.8x3.8 mm) NASCENTechnology, Inc. has developed a series of high temperature, RoHS compliant inductors using low temperature co-fired ceramic (LTCC) ferrite usable to 300°C that feature low profile, rugged packaging, and self shielding characteristics. See individual data sheets for part dimensions. Electrical Parameters at 25 °C unless otherwise noted Part No. 85093 85092 85091 85078 85079 85080 No Load Inductance† µH 0.9 5.5 7 8.5 35 80 100 mA Inductance µH 0.9 4.7 6 7 26 50 100 mA Tolerance 25 % 25% 25 % 25 % 25% 25 % Nominal DC Resistance ohms 0.4 1 0.5 0.25 1.4 3.75 Rated Current†† mA - Saturation Current* mA 275 225 225 275 250 225 † Tolerance for no load inductance is ±25 % Current will cause a 35 °C temperature rise over ambient (measured 20 to 55 °C) * Saturation Current is the current that results in a 35% decrease in inductance over the 100 mA Inductance. Thickness varies by part; the range is 0.032-0.100 in [0.8-2.54 mm] †† Common termination options (please add option to the end of the part number when inquiring): -A0 Thick film AgPt with side terminations, solderable -C0 Thick film Au, Au wirebonding -D0 Au over Ni, solderable -D1 Au over Ni, Al wirebonding For additional information, contact: Daryl Schofield, General Manager Phone: 605-882-8513, Fax: 605-884-2450, E-mail: dschofield@nascentechnology.com NASCENTechnology Manufacturing, Inc. 1404 9th Ave. SW, Watertown, SD 57201 www.nascentechnology.com This product is protected under US Patent #6054914, #6198374 and other international patents. Specifications subject to change without notice. 04/17
85093-F0
物料型号为85093、85092、85091、85078、85079和85080。
这些是NASCEN Technology公司开发的高温LTCC(低温共烧陶瓷)电感器,适用于高达300°C的环境,具有低轮廓、坚固的封装和自屏蔽特性。
器件简介:这些电感器符合RoHS标准,具有低轮廓、坚固的封装和自屏蔽特性,适用于高温环境。
引脚分配:提供常见的端接选项,包括厚膜AgPt带侧端接、可焊的(-A0)、厚膜Au、Au线键合(-C0)、Au上覆Ni、可焊的(-D0)和Au上覆Ni、Al线键合(-D1)。
参数特性:包括无负载电感值、100mA下的电感值、100mA公差、标称直流电阻、额定电流和饱和电流。
例如,型号85093的无负载电感为0.9μH,100mA下为0.9μH,公差为25%,标称直流电阻为0.4Ω,额定电流未给出,饱和电流为275mA。
功能详解:这些电感器在25°C下的性能参数被列出,除非另有说明。
电流通过电感器会导致环境温度上升35°C(在20°C至55°C下测量)。
饱和电流是指电感值下降35%的电流。
应用信息:这些电感器适用于需要在高温环境下工作的电子设备。
封装信息:电感器的厚度会根据不同型号而变化,范围在0.032-0.100英寸(0.8-2.54毫米)之间。
如需更多信息,可联系Daryl Schofield,电话605-882-8513,传真605-884-2450,电子邮件dschofield@nascentechnology.com。
产品受美国专利#6054914、#6198374及其他国际专利保护。
规格如有变更,恕不另行通知。
版本日期为04/17。
85093-F0 价格&库存
很抱歉,暂时无法提供与“85093-F0”相匹配的价格&库存,您可以联系我们找货
