85085-F0
85085-F0
    NEWAVA
    固定电感器 Nonstandard 21µH ±25% 1.14Ω
85085-F0 数据手册
LTCC High Temperature Inductors 0.2x0.2 inch (5x5 mm) Higher Isat Series NASCENTechnology, Inc. has developed a series of high temperature, RoHS compliant inductors using low temperature co-fired ceramic (LTCC) ferrite usable to 300°C that feature low profile, rugged packaging, and self shielding characteristics. See individual data sheets for part dimensions. Electrical Parameters at 25 °C unless otherwise noted Part No. 85084 85085 85086 No Load Inductance† µH 4.9 21 49 100 mA Inductance µH 4.9 21 46 100 mA Tolerance 25 % 25% 25 % Nominal DC Resistance ohms 0.23 1.14 3 Rated Current†† mA 900 - Saturation Current* mA 1000 550 400 † Tolerance for no load inductance is ±25 % Current will cause a 35 °C temperature rise over ambient (measured 20 to 55 °C) * Saturation Current is the current that results in a 35% decrease in inductance over the 100 mA Inductance. Thickness varies by part; the range is 0.032-0.100 in [0.8-2.54 mm] Part mass 0.6 to 1.2 g †† Common termination options (please add option to the end of the part number when inquiring): -A0 Thick film AgPt with side terminations, solderable -C0 Thick film Au, Au wirebonding -D0 Au over Ni, solderable -D1 Au over Ni, Al wirebonding For additional information, contact: Daryl Schofield, General Manager Phone : 605-882-8513, Fax : 605-884-2450, E-mail : dschofield@nascentechnology.com NASCENTechnology Manufacturing, Inc. 1404 9th Ave. SW, Watertown, SD 57201 www.nascentechnology.com This product is protected under US Patent #6054914, #6198374 and other international patents. Specifications subject to change without notice. 04/17
85085-F0 价格&库存
很抱歉,暂时无法提供与“85085-F0”相匹配的价格&库存,您可以联系我们找货
