SCIH1040HC-R47M
SCIH1040HC-R47M
    SIGNAL
    非标准
    固定电感器 Nonstandard 470nH ±20% 25A 1.6mΩ
SCIH1040HC-R47M 数据手册
SCIH1040HC SMD POWER INDUCTORS MARKING ● Features 1. Lowest DCR/uH in this small package size. 2. Frequency range up to 1.0MHZ. 3. -55℃ to +125℃ operating temperature. 4. Handles high transient current spikes without saturation. 5. Composite construction providing extremely low buzz noise. ELECTRICAL CHARACTERISTICS Part Number Inductance Test (uH) Frequency (1) Saturation Temperature DC Current Current (4) Resistance (3) (Ω MAX) (A) (A) 100 100 SCIH1040HC by current BCIHP1040Inductance Inductancedecrease by current 220 (2) SCIH1040HC-R22N 0.22 200KHZ 0.95m 60.0 35.0 SCIH1040HC-R30M 0.30 200KHZ 1.2m 50.0 31.0 SCIH1040HC-R36M 0.36 200KHZ 1.4m 48.0 30.0 SCIH1040HC-R47M 0.47 200KHZ 1.6m 40.0 25.0 SCIH1040HC-R56M 0.56 200KHZ 1.8m 40.0 25.0 SCIH1040HC-R68M 0.68 200KHZ 2.4m 30.0 22.0 SCIH1040HC-R82M 0.82 200KHZ 3.0m 30.0 22.0 SCIH1040HC-R19N 35.0 SCIH1040HC-1R0M 1.00 200KHZ 3.4m 25.0 20.0 SCIH1040HC-1R2M 1.20 200KHZ 3.8m 25.0 18.0 SCIH1040HC-1R5M 1.50 200KHZ 4.2m 20.0 14.0 10 Inductance Inductance (µH) (uH) 0.8m 60.0 3R3 1.0 R56 0.1 0 100 1000 10000 DC (mA) DCcurrent current(mA) 100000 SCIH1040HC Temperaturerise riseby by current current BCIHP1040 Temperature Temperature rise °C℃ Temperature rise 0.19 200KHZ 80 70 60 50 40 30 20 10 0 220 3R3 R56 5000 10000 15000 20000 25000 30000 35000 40000 DCcurrent(mA) current (mA) DC (1). Inductance tolerance: M±20% / N±30% tested at 0.25V, 0ADC and 25℃ (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 20% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ ambient (*). Part temperature (ambient + temp rise) should not exceed 125℃ under worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provisions may affect the temperature of the part. Part temperature should be verified in the end application. Click here for QUANTITY PER REEL & PACKING INFORMATION © 2019 Signal Transformer –Specification subject to change without notice. 12.19 Custom versions available upon request. 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com belfuse.com/signal 174-A
SCIH1040HC-R47M
1. 物料型号:SCIH1040HC系列,包括不同型号,如SCIH1040HC-R19N、SCIH1040HC-R22N等,每个型号具有不同的电感值。
2. 器件简介:这些电感器具有小尺寸、低直流电阻(DCR)、高频率范围(高达1.0MHz)、宽工作温度范围(-55℃至+125℃)、高瞬态电流承受能力以及低噪音的复合结构。
3. 引脚分配:文档中没有提供具体的引脚分配信息,但通常SMD电感器会有端子或焊盘用于连接。
4. 参数特性:包括电感值、测试频率、最大直流电阻、饱和电流和温度电流特性。例如,SCIH1040HC-R19N型号在200kHz测试频率下的电感值为0.19uH,最大直流电阻为0.8mΩ,饱和电流为60.0A。
5. 功能详解:电感器能够在不饱和的情况下处理高瞬态电流尖峰,并且具有极低的噪音水平。
6. 应用信息:虽然文档中没有直接提及具体应用,但这些电感器适用于需要高频率和高电流承受能力的应用场合。
7. 封装信息:文档中没有提供详细的封装尺寸信息,但提到了“小尺寸”,暗示这些电感器适用于空间受限的应用。
SCIH1040HC-R47M 价格&库存
很抱歉,暂时无法提供与“SCIH1040HC-R47M”相匹配的价格&库存,您可以联系我们找货
