Technical Data 4373
Effective May 2023
Supersedes June 2019
FP0404
High frequency, high current power inductors
Applications
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
Server and desktop VRMs and EVRDs
Laptop and notebook regulators
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Load modules
Environmental data
Product features
High current carrying capacity
Low core loss
DC-DC converter applications up to 2 MHz
Filtering applications see inductance vs
frequency and impedance vs frequency curves
on page 5
Inductance Range from 22 nH to 170 nH
Current range up to 40 A
4.0 mm x 4.0 mm footprint surface mount
package in 3.0 mm and 4.0 mm heights
Moisture sensitivity level (MSL): 1
Ferrite core material
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
HALOGEN
Pb HF
FREE
FP0404
Technical Data 4373
Effective May 2023
Product specifications
Part number5
OCL1
(nH) ±15%
FLL2
(nH) minimum
Irms3
(A)
Isat14
(A)
Isat25
(A)
Isat36
(A)
DCR (mΩ)
@ +20 °C
±25%
K-factor7
FP0404R1-R022-R
22 ±20%
15
40
40
34
32
0.32 ± 15%
2351
FP0404R1-R065-R
65
44
40
24
22
2248
FP0404R1-R080-R
80
54
40
19.5
18
16
0.32
2248
FP0404R1-R100-R
100
68
40
15.6
14
13
0.32
2248
FP0404R1-R110-R
110
74.5
40
14.2
13
11.8
0.32
2248
FP0404R1-R170-R
170
116
40
9.0
7.8
7.6
0.32
2248
4. Isat1 : Peak current for approximately 20% rolloff @ +25 °C
5. Isat2 : Peak current for approximately 20% rolloff @ +100 °C
6. Isat3 : Peak current for approximately 20% rolloff @ +125 °C
7. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I * 10-3. Bp-p:(Gauss), K: (K-factor from
table), L: (Inductance in nH), ∆I (Peak to peak ripple current in Amps).
8. Part Number Definition: FP0404Rx-Rxxx-R
FP0404 = Product code and size
Rx= DCR indicator
Rxxx=Inductance value in μH, R=decimal point
-R suffix = RoHS compliant
1. Open Circuit Inductance (OCL) Test parameters: 100 kHz (1 MHz for R022), 0.1 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test parameters: 100 kHz (1 MHz for R022), 0.1 Vrms, Isat1, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C underworst case operating
conditions verified in the end application.
Dimensions (mm)
R065, R080, R100, R110, R170
R022
B
B
1
1
Rxxx
4.3
0.9
R022
A
Recommended pad layout
wly
wly
2
2
4.2
A
1.7
1.9
C
b
a
C
a
b
SCHEMATIC
D
D
1
E
E
F
2
F
Part number
A
B
C
D
E
F
R022-R
4.0 maximum
4.0 maximum
3.0 maximum
1.4 ±0.20
1.2 ±0.2.
1.4 ±0.3
R065-R
3.7 ±0.30
3.7 ±0.30
3.5 ±0.50
1.4 ±0.20
1.2 ±0.2
1.4 ±0.3
R080-R
3.7 ±0.30
3.7 ±0.30
3.5 ±0.50
1.4 ±0.20
1.2 ±0.2
1.4 ±0.3
R100-R
3.7 ±0.30
3.7 ±0.30
3.5 ±0.50
1.4 ±0.20
1.2 ±0.2
1.4 ±0.3
R110-R
3.7 ±0.30
3.7 ±0.30
3.5 ±0.50
1.4 ±0.20
1.2 ±0.2
1.4 ±0.3
R170-R
3.7 ±0.30
3.7 ±0.30
3.5 ±0.50
1.4 ±0.20
1.2 ±0.2
1.4 ±0.3
Part marking: Rxxx xxx=inductance value in uH, R=decimal point, wly= lot code
All soldering surfaces to be coplanar within 0.1 millimeters
DCR is measured from point “a” to point “b”
Traces or vias underneath the inductor is not recommended
2
www.eaton.com/electronics
1.7
Technical Data 4373
FP0404
Effective May 2023
Packaging information (mm)
FP0404R1-R022-R
Supplied in tape and reel packaging, 1,800 parts per 13” diameter reel
4.0
1.5 dia
1.5 dia
2.0
1.75
5.5
12.0
±0.3
4.0
8
3.0
3.9
Direction of feed
FP0404R1-R065-R, R080-R, R100-R, R110-R, R-170
4.0
1.5 dia
1.5 dia
2.0
1.75
7.5
16.0
±0.3
4.2
8
4.0
4.1
Direction of feed
Temperature rise vs. total loss
FP0404R1-R065-R, R080-R, R100-R, R110-R, R170
70
60
60
Temperature rise (°C)
FP0404R1-R022-R
70
50
40
30
50
40
30
10
0.1
0.2
0.3
0.4
0.5
0.6
Total loss (W)
0.7
0.8
0.9
1.0
0.0
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
Total loss (W)
3
FP0404
Technical Data 4373
Effective May 2023
Core loss vs Bp-p
FP0404R1-R022-R
10
1 MHz
1
500 kHz
300 kHz
200 kHz
Core loss (W)
0.1
100 kHz
0.01
0.001
0.0001
100
1000
10000
B p-p (Gauss)
10
1 MHz
500 kHz
1
300 kHz
200 kHz
Core loss (W)
0.1
100 kHz
0.01
0.001
0.0001
100
1000
B p-p (Gauss)
4
10000
Technical Data 4373
FP0404
Effective May 2023
Inductance vs frequency
FP0404R1-R065-R
FP0404R1-R022-R
75
65
Inductance (nH)
Inductance (nH)
25
15
10
5
45
35
25
15
5
-5
0.1
1
10
100
1000
0.1
1
10
Frequency (MHz)
FP0404R1-R100-R
95
Inductance (nH)
Inductance (nH)
115
75
55
35
15
-5
0.1
1
10
100
1000
0.1
1
10
Frequency (MHz)
1000
FP0404R1-R0170-R
115
200
95
160
Inductance (nH)
180
75
55
35
140
120
100
80
60
40
15
-5
100
Frequency (MHz)
FP0404R1-R110-R
Inductance (nH)
1000
Frequency (MHz)
FP0404R1-R080-R
95
85
75
65
55
45
35
25
15
5
-5
100
1
10
Frequency (MHz)
100
1000
1
10
100
1000
Frequency (MHz)
5
FP0404
Technical Data 4373
Effective May 2023
Impedance vs frequency
FP0404R1-R022-R
FP0404R1-R065-R
30
25
Impedance (Ohm)
25
Impedance (Ohm)
10
5
200
300
400
500
15
10
5
Frequency (MHz)
10
5
500
600
500
600
15
10
5
200
300
400
500
200
Frequency (MHz)
400
FP0404R1-R170-R
35
25
30
Impedance (Ohm)
30
10
5
Frequency (MHz)
FP0404R1-R110-R
Impedance (Ohm)
400
FP0404R1-R100-R
25
Impedance (Ohm)
Impedance (Ohm)
FP0404R1-R080-R
25
10
5
200
300
Frequency (MHz)
6
300
Frequency (MHz)
25
400
500
600
200
300
400
Frequency (MHz)
500
600
Technical Data 4373
FP0404
Effective May 2023
Inductance characteristics
FP0404R1-R022-R
FP0404R1-R065-R
120%
120%
100%
100%
-40°C
80%
+25°C
60%
+100 °C
40%
% of OCL
% of OCL
80%
-40°C
60%
+25°C
40%
+125 °C
20%
20%
+125 °C
0%
0%
50
60
70
80
90
100
10
15
FP0404R1-R080-R
120%
100%
100%
60%
+100°C
40%
+25°C
15
+25°C
30
+125 °C
20%
0%
10
40
-40°C
60%
40%
+125°C
5
35
80%
-40°C
% of OCL
% of OCL
80%
FP0404R1-R100-R
120%
0%
25
I dc (A mps)
I dc (A mps)
20%
+100 °C
35
10
I dc (A mps)
+100 °C
15
30
I dc (A mps)
FP0404R1-R110-R
FP0404R1 -R170-R
120%
100%
100%
80%
-40°C
60%
+25°C
40%
60%
-40 °C
40%
+100 °C
+25 °C
+125 °C
20%
20%
0%
% of OCL
% of OCL
80%
+100 °C
+125 °C
4
6
8
10
12
I dc (A mps)
14
16
18
24
0%
4
6
8
10
12
14
16
18
Idc (Amps)
7
Technical Data 4373
FP0404
Effective May 2023
Solder reflow profile
TP
TC -5 °C
tP
Max. ramp up rate = 3 °C/s
Max. ramp down rate = 6 °C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“FP0404R1-R065-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1800+7.266681800+0.94129
- 3600+6.853603600+0.88778
- 5400+6.623235400+0.85794
- 9000+6.364069000+0.82437
- 12600+6.0038412600+0.77771
- 国内价格 香港价格
- 1+12.125691+1.57070
- 10+10.0320410+1.29950
- 100+8.46181100+1.09610
- 250+7.85117250+1.01700
- 500+7.41499500+0.96050
- 1000+7.066051000+0.91530
- 1800+6.717111800+0.87010
- 3600+6.368173600+0.82490
- 5400+6.193705400+0.80230
- 9000+5.931999000+0.76840
- 国内价格 香港价格
- 1+13.598931+1.76154
- 10+11.1833610+1.44864
- 100+9.19519100+1.19110
