Technical Data 11042
Effective March 2020
DRAP127
Automotive grade high power density, shielded drum core
power inductors
Applications
Product features
Body electronics
• LED lighting (interior and exterior)
Central body control module
Vehicle access control module
Headlamps, tail lamps and interior lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• Adaptive cruise control (ACC)
AEC-Q200 qualified
Automatic parking control
Secure four terminal mounting ideal for severe
vibration environments up to 30 g.
Collision avoidance system/ Car black
box system
Rugged construction for high shock conditions
Magnetically shielded-reduces EMI
Inductance range from 0.41 μH to 999 μH
Digital instrument cluster
Current range from 0.6 A to 56 A
In-vehicle infotainment (IVI) and navigation
12.5 mm x 12.5 mm x 8.1 mm surface mount
package
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
Chassis and safety electronics
Electronic stability control system (ESC)
Electric parking brake
Electronic power steering (EPS) / Anti-locking
braking system (ABS)
Ferrite core material
Weight: 4.46 grams typical
Moisture Sensitivity Level: 1
Engine and powertrain systems
• Electric pumps, motor control and auxiliaries
Powertrain control module (PCU)/
Engine control unit (ECU)
Transmission control unit (TCU)
Environmental compliance and general
specifications
Storage temperature range (Component):
-40 °C to +165 °C
Operating temperature range: -40 °C to +165 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
DRAP127
shielded drum core power inductors
Product specifications
Part number6
OCL1 (µH)
±20%
Irms2
(A)
Isat13
(A)
Isat24
(A)
DCR (Ω)
typical @ +25 °C
DCR (Ω)
maximum @ +25 °C
K Factor5
DRAP127-R47-R
0.41
15.9
56
44.8
0.0024
0.0030
120
DRAP127-1R0-R
0.77
13.6
40
32
0.0034
0.0040
85.7
DRAP127-1R5-R
1.27
12.2
31
24.9
0.0043
0.0051
66.7
DRAP127-2R2-R
1.92
12.5
25.5
20.4
0.0040
0.0048
54.6
DRAP127-3R3-R
3.51
8.54
18.7
14.9
0.0086
0.0104
40
DRAP127-4R7-R
4.58
8.14
16.5
13.2
0.0094
0.011
35.3
DRAP127-6R8-R
6.72
6.52
13.3
10.7
0.015
0.018
28.6
DRAP127-8R2-R
8.33
6.33
12.2
9.74
0.016
0.019
26.1
DRAP127-100-R
9.63
6.02
11.2
8.96
0.017
0.021
24.0
DRAP127-150-R
14.90
4.83
9.03
7.23
0.027
0.032
19.4
DRAP127-220-R
21.5
3.98
7.57
6.05
0.040
0.047
16.2
DRAP127-330-R
32.0
3.22
6.22
4.98
0.060
0.072
13.3
DRAP127-470-R
47.9
2.62
5.09
4.07
0.091
0.110
10.9
DRAP127-680-R
68.2
2.33
4.18
3.34
0.115
0.138
9.0
DRAP127-820-R
83.9
2.01
3.84
3.07
0.155
0.186
8.2
DRAP127-101-R
101
1.89
3.46
2.77
0.175
0.210
7.4
DRAP127-151-R
151
1.52
2.83
2.26
0.269
0.320
6.1
DRAP127-221-R
220
1.25
2.35
1.88
0.398
0.480
5.0
DRAP127-331-R
328
1.01
1.93
1.54
0.612
0.730
4.1
DRAP127-471-R
475
0.827
1.62
1.29
0.910
1.10
3.5
DRAP127-681-R
677
0.736
1.33
1.06
1.15
1.39
2.8
DRAP127-821-R
825
0.637
1.22
0.978
1.54
1.85
2.6
DRAP127-102-R
999
0.598
1.10
0.878
1.75
2.10
2.4
1. Open circuit inductance (OCL) test parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part
not exceed +165 °C under worst case operating conditions verified in the end application.
3. Isat1: Peak current for approximately 30% rolloff @ +25 °C
4. Isat2: Peak current for approximately 40% rolloff @ +125 °C
2
www.eaton.com/electronics
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p:(Gauss), K:
(K-factor from table), L: (Inductance in μH), ΔI (Peak-to-peak ripple current in Amps).
6. Part Number Definition: DRAP127-xxx-R
DRAP127= Product code and size
xxx= Inductance value in μH, R= decimal point, If no R is present last character equals number of
zeros
-R suffix = RoHS compliant
DRAP127
Dimensions (mm)
Recommended pad layout
Epoxy
2.00±0.10
0.20±0.10
DRAP127
xxx
xxxx R
Schematic
1
dummy
12.50 Max
5.40±0.10
#2
#1
CL
13.00±0.10
6.80±0.10
2
Epoxy
12.5 Max
dummy
0.20±0.10
CL
8.1 Max
6.80±0.10
13.00±0.10
Refer to the notes for epoxy/flashing
protrusion specification
Epoxy
1.60
2.50
5.00
Epoxy
#2
#1
12.00
7.00 Ref.
Pin1 Indicator
7.00 Ref.
2.50
12.00
Part marking: DRAP127, xxx= inductance value in uH, R= decimal point,
if no R is present last character equals number of zeros
xxxx=lot code, R= Revision level
All soldering surface to be coplanar within 0.1 millimeters
Tolerances are ±0.2 millimeters unless stated otherwise
Special Characteristic epoxy protrusion or any flashing from the plastic on the header/base can be
below the terminal surface and must not exceed 0.08 mm beyond the bottom surface of the
terminal.
Terminal pads shall protrude the plastic base 0.00~0.08 mm
Traces or vias underneath the inductor is not recommended
Packaging information (mm)
Supplied in tape and reel packaging , 350 parts per 13” diameter reel
3
DRAP127
Temperature rise vs. total loss
80
Temperature rise (°C)
70
60
50
40
30
0.2 0.3
0.4 0.5
0.6
0.7
0.8 0.9
1.0
1.1 1.2
1.3
1.4 1.5
Total loss (W)
Core loss vs. Bp-p
1
10
Hz
M
z
50
kH
30
z
kH
z
kH
z
kH
Core loss (W)
1
0.1
0.01
0.001
100
1000
10000
Bp-p (Gauss)
Inductance characteristics
120%
110%
100%
% of OCL
90%
80%
70%
-40 °C
60%
50%
+25 °C
40%
30%
+85 °C
20%
+125 °C
10%
0%
0%
10%
20%
30% 40%
50% 60% 70% 80% 90% 100% 110% 120% 130% 140% 150% 160%
% of Isat1
4
DRAP127
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“DRAP127-2R2-R”相匹配的价格&库存,您可以联系我们找货
