Technical Data 4310
Effective July 2017
Supersedes December 2007
LD
Metalized drum core power inductors
Applications
SMD Device
Environmental data
Product features
Metalized drum core design utilizes board
space
Current Range from 0.52 A to 4.46 A
Inductance range from 1.0 µH to 470 µH
Ferrite core material
Buck or boost inductor
Noise filtering and output filter chokes
Computers
Power supplies
Test equipment instrumentation
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Technical Data 4310
Effective July 2017
Product specifications
Part
Number
LD1-1R0-R
LD1-1R4-R
LD1-1R8-R
LD1-2R2-R
LD1-2R7-R
LD1-3R3-R
LD1-3R9-R
LD1-4R7-R
LD1-5R6-R
LD1-6R8-R
LD1-8R2-R
LD1-100-R
LD1-120-R
LD1-150-R
LD1-180-R
LD1-220-R
LD1-270-R
LD1-330-R
LD1-390-R
LD1-470-R
LD1-560-R
LD1-680-R
LD1-820-R
LD1-101-R
LD1-151-R
LD1-221-R
LD1-331-R
LD2-100-R
LD2-120-R
LD2-150-R
LD2-180-R
LD2-220-R
LD2-270-R
LD2-330-R
LD2-390-R
LD2-470-R
LD2-560-R
LD2-680-R
LD2-820-R
LD2-101-R
LD2-121-R
LD2-151-R
LD2-181-R
LD2-221-R
LD2-271-R
LD2-331-R
LD2-391-R
LD2-471-R
Rated
Inductance
(µH)
1.0
1.4
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
10
12
15
18
22
27
33
39
47
56
68
82
100
150
220
330
10
12
15
18
22
27
33
39
47
56
68
82
100
120
150
180
220
270
330
390
470
OCL(1)
Nominal
Irms(2)
(A)
Isat(3)
(A)
1.00
1.40
1.80
2.20
2.70
3.30
3.90
4.70
5.60
6.80
8.20
10.0
12.0
15.0
18.0
22.0
27.0
33.0
39.0
47.0
56.0
68.0
82
100
150
220
330
10.0
12.0
15.0
18.0
22.0
27.0
33.0
39.0
47.0
56.0
68.0
82
100
120
150
180
220
270
330
390
470
2.66
2.47
2.35
2.22
2.11
2.00
1.75
1.57
1.51
1.41
1.32
1.13
1.05
0.99
0.83
0.78
0.67
0.66
0.63
0.52
0.50
0.46
0.43
0.36
0.29
0.26
0.22
3.83
3.57
3.38
3.19
3.13
2.81
2.70
2.42
2.25
1.96
1.88
1.63
1.53
1.43
1.23
1.15
1.00
0.94
0.83
0.78
0.74
4.46
3.41
3.05
2.76
2.52
2.32
2.14
2.00
1.75
1.56
1.41
1.28
1.18
1.05
0.98
0.89
0.87
0.75
0.68
0.61
0.57
0.52
0.50
0.45
0.40
0.33
0.30
3.45
3.20
2.85
2.60
2.45
2.10
2.01
1.85
1.64
1.50
1.35
1.28
1.15
1.09
0.95
0.87
0.79
0.73
0.64
0.58
0.55
Notes:
1) Open Circuit Inductance Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc
+/-20% except for LD1-330-R to LD1-331-R and LD2-470-R to LD2-471-R which is +/-10%
2) RMS current for an approximate ∆T of 40°C. It is recommended that the temperature of the
part not exceed +125 °C
3) Peak current for an approximate 10% rolloff at +20 °C
2
www.eaton.com/electronics
4) DCR limits @ +20 °C
5) Part number definition: LDx-yyy-R
LDx = product code and size, -yyy = inductance value in µH,
R = decimal point. If no R is present, third character = # of zeros
-R suffix = RoHS compliant
DCR(4)
(Ω)
(Max.)
0.0330
0.0380
0.0420
0.0470
0.0520
0.0580
0.0760
0.0940
0.1010
0.1170
0.1320
0.1820
0.2100
0.2350
0.3380
0.3780
0.5220
0.5400
0.5870
0.8440
0.9370
1.12
1.28
1.72
2.68
3.42
4.70
0.0700
0.0800
0.0900
0.1000
0.1100
0.1200
0.1300
0.1600
0.1800
0.2400
0.2800
0.3700
0.4300
0.4700
0.6400
0.7100
0.9600
1.11
1.26
1.77
1.96
LD
Technical Data 4310
Effective July 2017
Dimensions- mm
Recommended Pad Layout
Top View
A
Bottom View
Front View
Schematic
H
1
C
B
xxx
I
Marking
G
2
I
Component Side
Marking:
xxx=inductance value per family chart
Do not route traces or vias underneath the inductor
Dimensions
A
+/-0.3
B
+/-0.3
C
+/-0.3
G
ref
H
ref
I
ref
LD1
4.5
4.0
3.2
1.5
4.5
1.75
LD2
7.8
7.0
5.0
2.0
7.5
3.0
Packaging information- mm
Packaging Information
8.0
LD1 Series
Supplied in tape and reel packaging,
2000 parts per reel, 13" diameter reel.
ACTUAL SIZE
LD1
xxx
xxx
xxx
xxx
12.0
User Direction Feed
LD2 Series
12.0
1000 parts per reel, 13" diameter reel.
ACTUAL SIZE
LD2
xxx
xxx
xxx
xxx
16.0
User Direction Feed
Inductance characteristics
OCL vs Isat
LD2
100
100
90
90
80
80
70
70
OCL (%)
OCL (%)
OCL vs Isat
LD1
60
50
40
60
50
40
30
30
10
40
50
60
% of Isat
70
80
90
100
110
120
40
50
60
70
80
90
100
110
120
% of Isat
3
LD
Technical Data 4310
Effective July 2017
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4310 BU-SB07325
July 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“LD2-101-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13.386181+1.72939
- 10+10.9911510+1.41997
- 100+9.03828100+1.16768
- 国内价格 香港价格
- 1000+7.506921000+0.96984
- 2000+7.079672000+0.91464
- 3000+6.841343000+0.88385
- 5000+6.552925000+0.84659
- 7000+6.369777000+0.82293
- 10000+6.2857910000+0.81208
- 国内价格
- 1+1.60143
- 200+0.61982
- 500+0.59800
- 1000+0.58720
