MPI4012V2-R33-R
MPI4012V2-R33-R
    EATON(伊顿)
    SMD,4.1x4.4mm
    固定电感器 Nonstandard, 2 Lead 330nH ±20% 7.5A 13.5mΩ 128MHz
MPI4012V2-R33-R 数据手册
Technical Data 10651 Effective April 2017 MPI40-V2 High current, low profile, miniature power inductors Applications • Handheld/mobile devices • Portable media players • Notebook/netbook/laptop regulators • Tablets/smartbooks • Battery operated devices • LED drivers • LCD displays • Point-of-load (POL) converters Environmental data Product features • High current carrying capacity • Magnetically shielded, Low EMI • Rugged flexible construction • Self resonant frequency (SRF) greater than 9.5 MHz • Inductance range from 0.1 μH to 22 μH • Current range from 1.2 A to 22 A • 4.75 mm x 4.45 mm footprint surface mount package in 1.2 mm, 1.5 mm, and 2.0 mm heights • Moisture Sensitivity Level (MSL): 1 • Storage temperature range (Component): -55 °C to +125 °C • Operating temperature range: -55 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant • Halogen free, lead free, RoHS compliant HALOGEN Pb HF FREE MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Product specifications OCL1 (μH) ±20% Part marking designator Irms2 (A) Isat3 (A) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C SRF (MHz) typical K-factor4 MPI4012V2-R33-R 0.33 A 7.5 11 11 13.5 128 2480 MPI4012V2-R47-R 0.47 B 5.6 6.8 19 23 106 2470 MPI4012V2-R68-R 0.68 C 4.5 6.7 28 33.5 98 2223 MPI4012V2-1R0-R 1.0 D 4.3 6.5 38.5 46.5 64 1477 MPI4012V2-1R5-R 1.5 E 3.3 4.3 55 66 63 1264 MPI4012V2-2R2-R 2.2 F 2.9 4.2 75 90 35 1143 MPI4012V2-4R7-R 4.7 G 1.8 2.8 175 210 29 890 MPI4015V2-R22-R 0.22 A 10.5 14 6.0 7.5 153 2649 MPI4015V2-R33-R 0.33 B 9.5 11 7.0 8.5 120 2158 MPI4015V2-R47-R 0.47 C 7.8 9.0 11 14 98 1991 MPI4015V2-R56-R 0.56 D 7.5 8.3 12 14 84 1942 MPI4015V2-R68-R 0.68 E 6.8 8.0 16 19 81 1437 MPI4015V2-1R0-R 1.0 F 5.5 6.0 23 27 56 1382 MPI4015V2-1R5-R 1.5 G 4.2 4.6 48 58 48 1468 MPI4015V2-2R2-R 2.2 H 2.9 4.5 65 78 42 920 MPI4015V2-3R3-R 3.3 I 3.0 3.2 77 92 31 854 MPI4015V2-4R7-R 4.7 J 2.2 3.0 108 130 22 791 MPI4015V2-6R8-R 6.8 K 2.0 2.3 172 207 21 609 MPI4015V2-100-R 10 L 1.8 2.1 245 294 14 766 MPI4020V2-R10-R 0.10 A 16 22 3.5 4.5 343 2692 MPI4020V2-R22-R 0.22 B 13 17 5.5 6.6 165 2036 MPI4020V2-R33-R 0.33 C 9.5 12 7.5 9.0 113 1268 MPI4020V2-R47-R 0.47 D 8.5 11 10.5 13 95 1219 MPI4020V2-R56-R 0.56 E 8.0 10 12 15 87 1205 MPI4020V2-R68-R 0.68 F 7.5 9.0 12.5 16 80 1201 MPI4020V2-1R0-R 1.0 G 6.5 7.0 20 24 65 1168 MPI4020V2-1R2-R 1.2 H 6.5 6.8 23 28 52 1110 MPI4020V2-1R5-R 1.5 I 5.0 6.0 25 30 45 1038 MPI4020V2-2R2-R 2.2 J 3.8 5.5 40 48 33 711 MPI4020V2-3R3-R 3.3 K 3.3 4.0 71 85 25 643 MPI4020V2-4R7-R 4.7 L 2.7 3.2 98 118 24 453 MPI4020V2-6R8-R 6.8 M 2.0 2.6 167 192 23 482 MPI4020V2-100-R 10 N 1.7 2.2 245 281 17 307 MPI4020V2-150-R 15 O 1.5 1.8 320 384 13 257 MPI4020V2-220-R 22 P 1.2 1.65 350 402 9.5 215 Part Number 5 1.2 mm height 1.5 mm height 2.0 mm height 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 1.0 Vrms, 0.0 Adc, +25 °C. 2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 3. Isat : Peak current for approximately 30% rolloff @ +25 °C. 2 www.eaton.com/electronics 4. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p :(Gauss), K: (K-factor from table), L: (Inductance in uH), ΔI (Peak to peak ripple current in Amps). 5. Part Number Definition: MPI40xxV2-xxx-R MPI40 = Product code xx= Height indicator V2=Version indicator xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Dimensions (mm) Dimension A MPI4012V2 1.00 ±0.20 MPI4015V2 1.30 ±0.20 MPI4020V2 1.80 ±0.20 Part marking: 2xx (2 = version, x = inductance value per “Part marking designator” listed in Product specification table, x = bi-weekly date code) All soldering surfaces to be coplanar within 0.10 millimeters Tolerances are ±0.3 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise Do not route traces or vias underneath the inductor Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging , 3000 parts per 13” diameter reel KO MPI4012V2 1.4 MPI4015V2 1.8 MPI4020V2 2.5 www.eaton.com/electronics 3 MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Core loss vs Bp-p MPI4012V2-R33-R 100 MPI4012V2-R47-R 100 500 kHz 300 kHz 10 500 kHz 300 kHz 10 1 Core Loss (mW) Core Loss (mW) 100 kHz 50 kHz 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 10 100 1000 10000 0.001 Bp-p (Gauss) MPI4012V2-R68-R 100 10 500 kHz 300 kHz 1 50 kHz 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 10 100 1000 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.001 10000 10 100 500 kHz 300 kHz Core Loss (mW) 100 kHz 25 kHz 3.5 MHz 3.0 MHz 0.1 500 kHz 300 kHz 10 50 kHz 1 2.0 MHz 10000 MPI4012V2-2R2-R 100 10 1000 Bp-p (Gauss) MPI4012V2-1R5-R 100 Core Loss (mW) 10000 500 kHz 300 kHz Bp-p (Gauss) 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 1.0 MHz 700 kHz 0.01 0.01 10 100 1000 Bp-p (Gauss) 4 1000 0.01 0.01 0.001 Bp-p (Gauss) MPI4012V2-1R0-R 1.0 MHz 700 kHz 0.001 100 10 100 kHz 0.1 10 100 Core Loss (mW) Core Loss (mW) 25 kHz 3.5 MHz 0.01 0.01 0.001 100 kHz 50 kHz 1 www.eaton.com/electronics 10000 0.001 10 100 1000 Bp-p (Gauss) 10000 MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Core loss vs Bp-p MPI4012V2-4R7-R 100 500 kHz 300 kHz 100 kHz 50 kHz 1 500 kHz 300 kHz 10 Core Loss (mW) Core Loss (mW) 10 25 kHz 3.5 MHz 3.0 MHz 0.1 MPI4015V2-R22-R 100 2.0 MHz 100 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 1.0 MHz 700 kHz 0.01 0.01 0.001 0.001 10 100 Bp-p (Gauss) 1000 10000 MPI4015V2-R33-R 100 10 100 Bp-p (Gauss) 1000 MPI4015V2-R47-R 100 500 kHz 300 kHz 10 500 kHz 300 kHz 10 1 Core Loss (mW) Core Loss (mW) 100 kHz 50 kHz 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.001 100 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 10 100 Bp-p (Gauss) 1000 0.001 10000 MPI4015V2-R56-R 100 10 100 Bp-p (Gauss) 1000 500 kHz 300 kHz 500 kHz 300 kHz 10 100 kHz Core Loss (mW) 100 kHz Core Loss (mW) 10000 MPI4015V2-R68-R 100 10 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.001 10000 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 10 100 1000 Bp-p (Gauss) 10000 0.001 10 100 Bp-p (Gauss) 1000 www.eaton.com/electronics 10000 5 MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Core loss vs Bp-p MPI4015V2-1R0-R 100 500 kHz Core Loss (mW) Core Loss (mW) 300 kHz 100 kHz 100 kHz 50 kHz 1 500 kHz 10 300 kHz 10 25 kHz 3.5 MHz 3.0 MHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 2.0 MHz 0.1 0.01 1.0 MHz 700 kHz 0.01 MPI4015V2-1R5-R 100 10 100 Bp-p (Gauss) 1000 10000 0.001 MPI4015V2-2R2-R 100 10 100 Bp-p (Gauss) 1000 MPI4015V2-3R3-R 100 500 kHz 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 0.01 0.001 300 kHz 10 Core Loss (mW) Core Loss (mW) 500 kHz 300 kHz 10 0.01 10 100 Bp-p (Gauss) 1000 10000 0.001 10 MPI4015V2-4R7-R 100 100 Bp-p (Gauss) 1000 500 kHz 100 kHz 50 kHz 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 100 kHz 50 kHz 1 0.01 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 1.0 MHz 700 kHz 0.01 10 100 1000 Bp-p (Gauss) 6 300 kHz 10 Core Loss (mW) Core Loss (mW) 500 kHz 300 kHz 1 10000 MPI4015V2-6R8-R 100 10 0.001 10000 www.eaton.com/electronics 10000 0.001 10 100 1000 Bp-p (Gauss) 10000 MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Core loss vs Bp-p MPI4015V2-100-R MPI4020V2-R10-R 100 100 500 kHz 300 kHz 500 kHz 10 50 kHz Core Loss (mW) Core Loss (mW) 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 100 Bp-p (Gauss) 1000 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 10000 100 kHz Core Loss (mW) 25 kHz 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 1000 100 kHz 50 kHz 25 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 0.01 0.01 0.001 10 100 Bp-p (Gauss) 1000 10000 MPI4020V2-R47-R 100 10 100 Bp-p (Gauss) 1000 100 kHz 500 kHz 300 kHz 50 kHz 25 kHz 1 3.5 MHz 0.1 1.0 MHz 700 kHz 100 kHz 10 Core Loss (mW) Core Loss (mW) 10 3.0 MHz 2.0 MHz 0.01 10000 MPI4020V2-R56-R 100 500 kHz 300 kHz 0.001 10000 500 kHz 300 kHz 10 50 kHz 3.5 MHz 100 MPI4020V2-R33-R 100 500 kHz 300 kHz 1 10 Bp-p (Gauss) MPI4020V2-R22-R 10 Core Loss (mW) 1 0.001 10 100 0.001 25 kHz 3.5 MHz 0.01 0.01 0.001 100 kHz 10 300 kHz 50 kHz 25 kHz 1 3.5 MHz 0.1 1.0 MHz 700 kHz 3.0 MHz 2.0 MHz 0.01 10 100 Bp-p (Gauss) 1000 10000 0.001 10 100 Bp-p (Gauss) 1000 www.eaton.com/electronics 10000 7 MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Core loss vs Bp-p MPI4020V2-R68-R 100 500 kHz 300 kHz 100 kHz 10 MPI4020V2-1R0-R 100 500 kHz 300 kHz 10 100 kHz 25 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 50 kHz Core Loss (mW) Core Loss (mW) 50 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.01 0.001 0.001 25 kHz 1 10 100 Bp-p (Gauss) 1000 100 1000 MPI4020V2-1R5-R 100 500 kHz 300 kHz 500 kHz 300 kHz 10 100 kHz 50 kHz Core Loss (mW) Core Loss (mW) 10 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 100 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.01 0.001 10 100 Bp-p (Gauss) 1000 0.001 10000 MPI4020V2-2R2-R 100 10 100 Bp-p (Gauss) 1000 10 500 kHz 300 kHz 10 100 kHz 100 kHz 50 kHz 25 kHz Core Loss (mW) Core Loss (mW) 50 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 1 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.01 0.001 10000 MPI4020V2-3R3-R 100 500 kHz 300 kHz 0.001 10 100 1000 Bp-p (Gauss) 8 10000 Bp-p (Gauss) MPI4020V2-1R2-R 100 10 10000 www.eaton.com/electronics 10000 10 100 1000 Bp-p (Gauss) 10000 MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Core loss vs Bp-p MPI4020V2-4R7-R MPI4020V2-6R8-R 100 100 500 kHz 300 kHz 10 100 kHz 50 kHz 25 kHz 3.5 MHz 1 Core Loss (mW) Core Loss (mW) 10 500 kHz 300 kHz 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 0.01 0.001 100 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 10 100 Bp-p (Gauss) 1000 10000 0.001 MPI4020V2-100-R 100 10 100 Bp-p (Gauss) 1000 MPI4020V2-150-R 100 500 kHz 300 kHz 500 kHz 300 kHz 50 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 25 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.01 0.001 100 kHz 10 100 kHz Core Loss (mW) Core Loss (mW) 10 10000 0.001 10 100 1000 10000 Bp-p (Gauss) 10 100 1000 10000 Bp-p (Gauss) MPI4020V2-220-R 100 500 kHz 300 kHz 100 kHz 10 Core Loss (mW) 50 kHz 25 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 0.01 0.001 10 100 1000 10000 Bp-p (Gauss) www.eaton.com/electronics 9 MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Inductance vs. Frequency MPI4012V2-R47-R 0.8 0.4 0.7 0.35 0.6 0.3 Inductance (µH) Inductance (µH) MPI4012V2-R33-R 0.45 0.25 0.2 0.15 0.5 0.4 0.3 0.2 0.1 0.1 0.05 0 0 0.1 1 10 100 1000 0.1 1 10 MPI4012V2-R68-R 2 1 1.8 0.9 1.6 Inductance (µH) Inductance (µH) 0.8 0.7 0.6 0.5 0.4 0.3 1.4 1.2 1 0.8 0.6 0.2 0.4 0.1 0.2 0.1 1 10 100 0 1000 Frequency (MHz) 0.1 1 MPI4012V2-1R5-R MPI4012V2-2R2-R 2.7 2.4 2.4 Inductance (µH) 2.1 Inductance (µH) 100 3 2.7 1.8 1.5 1.2 0.9 2.1 1.8 1.5 1.2 0.9 0.6 0.6 0.3 0 10 Frequency (MHz) 3 0.3 0.1 1 10 Frequency (MHz) 10 1000 MPI4012V2-1R0-R 1.1 0 100 Frequency (MHz) Frequency (MHz) www.eaton.com/electronics 100 0 0.1 1 10 Frequency (MHz) 100 MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Inductance vs. Frequency MPI4012V2-4R7-R MPI4015V2-R22-R 11 0.35 10 0.3 8 Inductance (µH) Inductance (µH) 9 7 6 5 4 0.2 0.15 0.1 3 2 0.05 1 0 0.25 0.1 1 10 0 100 0.1 1 10 Frequency (MHz) MPI4015V2-R33-R 0.9 0.45 0.8 0.7 0.35 Inductance (µH) Inductance (µH) 0.4 0.3 0.25 0.2 0.15 0.6 0.5 0.4 0.3 0.1 0.2 0.05 0.1 0.1 1 10 100 0 1000 Frequency (MHz) 0.1 1 10 1000 MPI4015V2-R68-R MPI4015V2-R56-R 1.2 1 1.1 0.9 1 0.8 0.9 Inductance (µH) Inductance (µH) 100 Frequency (MHz) 1.1 0.7 0.6 0.5 0.4 0.3 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.2 0.1 0 1000 MPI4015V2-R47-R 0.5 0 100 Frequency (MHz) 0.1 0.1 1 Frequency (MHz) 10 100 0 0.1 1 Frequency (MHz) 10 www.eaton.com/electronics 100 11 MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Inductance vs. Frequency MPI4015V2-1R5-R MPI4015V2-1R0-R 2.2 3.2 2 2.8 1.6 Inductance (µH) Inductance (µH) 1.8 1.4 1.2 1 0.8 0.6 2 1.6 1.2 0.8 0.4 0.4 0.2 0 2.4 0.1 1 10 0 100 0.1 1 Frequency (MHz) 10 100 Frequency (MHz) MPI4015V2-2R2-R MPI4015V2-3R3-R 8 5.5 5 7 4 Inductance (µH) Inductance (µH) 4.5 3.5 3 2.5 2 1.5 5 4 3 2 1 1 0.5 0 6 0.1 1 10 0 100 0.1 1 Frequency (MHz) 10 10 Inductance (µH) Inductance (µH) 12 8 6 4 2 8 6 4 2 0.1 1 10 Frequency (MHz) 12 100 MPI4015V2-6R8-R MPI4015V2-4R7-R 12 0 10 Frequency (MHz) www.eaton.com/electronics 100 0 0.1 1 10 Frequency (MHz) 100 MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Inductance vs. Frequency MPI4020V2-R10-R 24 0.12 20 0.1 Inductance (µH) Inductance (µH) MPI4015V2-100-R 16 12 8 0.06 0.04 0.02 4 0 0.08 0.1 1 10 0 100 0.1 1 10 Frequency (MHz) 100 1000 0.5 0.45 Inductance (µH) 0.3 Inductance (µH) 1000 MPI4020V2-R33-R MPI4020V2-R22-R 0.35 0.25 0.2 0.15 0.4 0.35 0.3 0.25 0.2 0.15 0.1 0.1 0.05 0 100 Frequency (MHz) 0.05 0.1 1 10 100 0 1000 0.1 1 10 Frequency (MHz) Frequency (MHz) MPI4020V2-R47-R MPI4020V2-R56-R 1 1.2 1 0.8 0.7 Inductance (µH) Inductance (µH) 0.9 0.6 0.5 0.4 0.3 0.2 0.8 0.6 0.4 0.2 0.1 0 0.1 1 10 Frequency (MHz) 100 1000 0 0.1 1 10 100 Frequency (MHz) www.eaton.com/electronics 13 MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Inductance vs. Frequency MPI4020V2-1R0-R MPI4020V2-R68-R 2.2 1.4 2 1.8 1.6 1 Inductance (µH) Inductance (µH) 1.2 0.8 0.6 0.4 1.2 1 0.8 0.6 0.4 0.2 0 1.4 0.2 0.1 1 Frequency (MHz) 10 0 100 0.1 10 100 4 3.5 Inductance (µH) 2.4 Inductance (µH) 100 MPI4020V2-1R5-R MPI4020V2-1R2-R 2 1.6 1.2 0.8 3 2.5 2 1.5 1 0.4 0.5 0 0.1 1 Frequency (MHz) 10 100 0.1 1 Frequency (MHz) MPI4020V2-2R2-R MPI4020V2-3R3-R 2.4 4 3.5 Inductance (µH) 2 Inductance (µH) 10 Frequency (MHz) 2.8 0 1 1.6 1.2 0.8 3 2.5 2 1.5 1 0.4 0 0.5 0.1 1 10 Frequency (MHz) 14 www.eaton.com/electronics 100 0 0.1 1 Frequency (MHz) 10 100 MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Inductance vs. Frequency MPI4020V2-6R8-R MPI4020V2-4R7-R 16 12 14 10 Inductance (µH) Inductance (µH) 12 8 6 4 10 8 6 4 2 0 2 0 0.1 1 10 100 0.1 1 MPI4020V2-100-R 28 24 Inductance (µH) 20 Inductance (µH) 100 MPI4020V2-150-R 24 16 12 8 20 16 12 8 4 0 10 Frequency (MHz) Frequency (MHz) 4 0.1 1 10 100 Frequency (MHz) 0 0.1 1 10 100 www.eaton.com/electronics 15 Frequency (MHz) MPI4020V2-220-R 70 Inductance (µH) 60 50 40 30 20 10 0 0.1 1 10 100 Frequency (MHz) MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Inductance and temperature rise vs. Current 100 0.45 80 0.4 80 70 0.35 70 60 0.2 50 0.15 40 30 Temperature Rise 0.05 0 2 4 6 8 10 12 14 16 18 0.3 60 0.25 50 0.2 40 0.15 30 20 0.1 10 0.05 0 0 Idc (A) MPI4012V2-R68-R 70 60 0.4 50 0.3 40 30 0.2 Inductance (µH) Temperature Rise (°C) Inductance (µH) 0.5 4 6 6 8 10 12 1.4 90 80 0.7 70 0.6 60 0.5 50 0.4 40 30 Temperature Rise 0 1 2 3 4 5 50 40 30 Temperature Rise 20 0.2 7 8 9 0 MPI4012V2-2R2-R 2.4 100 90 Inductance Inductance (µH) 60 0.6 6 2 Temperature Rise (°C) Inductance (µH) 70 0.8 20 10 90 1 100 Idc (A) 80 80 70 1.6 60 1.2 50 40 0.8 30 Temperature Rise 20 0.4 10 0 1 2 3 4 Idc (A) 16 0 0.8 0 0 1.2 0 12 0.1 100 Inductance 0.4 10 MPI4012V2-1R0-R Idc (A) MPI4012V2-1R5-R 1.6 8 Inductance 0.2 10 2 4 0.3 20 Temperature Rise 0 2 0.9 90 Inductance 80 0 0 1 100 0.1 10 Idc (A) 0.7 0.6 20 Temperature Rise www.eaton.com/electronics 5 6 7 8 Temperature Rise (°C) 0 90 0 10 0 0 1 2 3 4 Idc (A) 5 6 7 0 Temperature Rise (°C) 0.1 Inductance (µH) Inductance (µH) 0.25 100 Inductance 90 Temperature Rise (°C) Inductance 0.3 MPI4012V2-R47-R 0.5 Temperature Rise (°C) MPI4012V2-R33-R 0.35 MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Inductance and temperature rise vs. Current MPI4012V2-4R7-R 0.2 80 0.18 70 3 60 2.5 50 2 40 30 Temperature Rise 2.5 3 3.5 4 4.5 5 30 0.06 0.02 2 40 0.08 10 1.5 50 0.1 0.5 1 60 0.12 0.04 0.5 70 0.14 20 0 80 0.16 1 0 0 0 Temperature Rise 0 2 4 6 8 10 100 18 0 20 100 Inductance 0.2 50 0.15 40 30 Temperature Rise 60 0.3 50 40 0.2 30 20 0.05 80 70 Inductance (µH) 60 90 0.4 Temperature Rise (°C) Inductance (µH) 70 0.1 Temperature Rise 0.1 20 10 0 2 4 6 8 10 12 14 16 10 0 0 Idc (A) 100 Inductance 60 50 0.3 40 0.2 30 Temperature Rise 10 Idc (A) 10 12 14 MPI4015V2-R68-R 0 10 12 14 0 100 90 80 0.5 70 60 0.4 50 0.3 40 30 0.2 Temperature Rise 20 0.1 8 8 0.6 Inductance (µH) 0.4 6 6 Inductance Temperature Rise (°C) 70 4 4 0.7 80 2 2 90 0.5 0 0 Idc (A) MPI4015V2-R56-R 0.6 Inductance (µH) 16 0.5 90 Inductance 0.25 0 14 Idc (A) 80 0 12 MPI4015V2-R47-R MPI4015V2-R33-R 0.3 20 10 Idc (A) 0.35 90 Temperature Rise (°C) 1.5 100 Inductance 20 0.1 0 Temperature Rise (°C) Inductance (µH) 3.5 90 MPI4015V2-R22-R Temperature Rise (°C) Inductance 4 0.22 Inductance (µH) 4.5 100 Temperature Rise (°C) 5 10 0 2 4 6 8 10 12 0 Idc (A) www.eaton.com/electronics 17 MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Inductance and temperature rise vs. Current MPI4015V2-1R0-R MPI4015V2-1R5-R 1.4 60 0.6 50 0.5 40 0.4 30 Temperature Rise 0.2 1 2 3 4 5 6 7 8 9 10 60 50 40 0.6 30 0.4 0 0 10 0 1 2 3 4 MPI4015V2-2R2-R 90 Inductance 60 1.2 50 1 40 0.8 30 Temperature Rise 20 0 1 2 3 4 5 6 7 70 60 2 50 1.5 40 30 1 20 Temperature Rise 0.5 10 0 0 0 0.5 1 1.5 MPI4015V2-4R7-R 100 4.5 2 2.5 Inductance 60 2.5 50 2 40 Temperature Rise 30 1 20 0.5 10 1 1.5 2 2.5 Idc (A) www.eaton.com/electronics 3 3.5 4 4.5 5 0 Inductance (µH) 3 0.5 4 4.5 5 5.5 6 0 100 90 6 Temperature Rise (°C) 70 0 3.5 6.5 80 3.5 1.5 3 MPI4015V2-6R8-R 7 90 4 Inductance (µH) 80 Idc (A) 5 18 100 Inductance Idc (A) 0 0 10 0.2 0 8 2.5 Inductance (µH) Inductance (µH) 1.4 Temperature Rise (°C) 70 1.6 0.4 7 90 3 80 1.8 0.6 6 MPI4015V2-3R3-R 3.5 100 2.2 2 5 Idc (A) Idc (A) 2.4 20 Temperature Rise 0.2 10 0 70 0.8 20 0.1 80 Inductance 5.5 80 5 70 4.5 60 4 3.5 50 3 40 2.5 2 30 Temperature Rise 1.5 20 1 10 0.5 0 0 0.5 1 1.5 2 Idc (A) 2.5 3 3.5 4 0 Temperature Rise (°C) 0.3 90 Inductance 1 Inductance (µH) 70 0.7 100 1.2 Temperature Rise (°C) Inductance (µH) 90 80 0.8 0 1.6 Temperature Rise (°C) Inductance 1 0.9 100 Temperature Rise (°C) 1.1 MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Inductance and temperature rise vs. Current 80 7 70 6 60 5 50 4 40 30 Temperature Rise Inductance 0.07 70 0.06 60 0.05 50 0.04 40 Temperature Rise 0.03 30 2 20 0.02 20 1 10 0.01 10 0 0.5 1 1.5 2 2.5 3 3.5 0 0 0 5 10 15 20 Idc (A) 100 50 0.12 40 Temperature Rise 30 Inductance (µH) 60 Temperature Rise (°C) 70 10 15 20 25 30 80 0.25 70 60 0.2 50 0.15 40 30 Temperature Rise 20 0.05 0 0 10 0 2 4 6 8 10 12 14 16 18 20 MPI4020V2-R47-R MPI4020V2-R56-R 0.6 100 100 90 90 0.5 50 0.3 40 0.2 30 Temperature Rise 20 0.1 Inductance (µH) Inductance (µH) 60 Temperature Rise (°C) 70 0.4 Inductance 0.5 80 Inductance 80 70 0.4 60 0.3 50 40 0.2 30 Temperature Rise 20 0.1 10 10 0 0 2 4 6 8 10 Idc (A) 0 Idc (A) Idc (A) 0.6 100 0.1 10 5 0 Inductance 20 0.04 0 40 90 0.3 80 0.16 0 35 MPI4020V2-R33-R 0.35 90 Inductance 0.2 0.08 30 Idc (A) MPI4020V2-R22-R 0.24 25 Temperature Rise (°C) 0 Inductance (µH) 80 12 14 16 18 0 0 0 2 4 6 8 10 12 14 16 0 Idc (A) www.eaton.com/electronics 19 Temperature Rise (°C) 3 90 0.08 Inductance (µH) 8 100 0.09 90 Inductance Temperature Rise (°C) Inductance (µH) 9 MPI4020V2-R10-R 0.1 100 Temperature Rise (°C) MPI4015V2-100-R 10 MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Inductance and temperature rise vs. Current Inductance 90 1 60 0.4 50 0.3 40 Temperature Rise 30 0.2 Inductance (µH) 70 Temperature Rise (°C) 80 0.5 Inductance 80 70 0.8 60 0.6 50 40 0.4 30 Temperature Rise 20 0.1 2 4 6 8 10 12 14 10 0 0 Idc (A) 1.6 90 1.4 60 0.8 50 0.6 40 30 Temperature Rise 0.2 12 1 2 3 4 5 I dc (A) 6 7 8 9 10 MPI4020V2-2R2-R 90 Inductance 80 70 60 50 0.8 40 0.6 30 Temperature Rise 20 0.2 0 0 10 60 1.2 50 40 0.8 30 Temperature Rise 3 4 5 6 7 8 9 MPI4020V2-3R3-R 90 Inductance 80 70 2.5 60 2 50 40 1.5 30 Temperature Rise 1 20 20 0.4 10 1 2 3 4 Idc (A) www.eaton.com/electronics 5 6 7 8 0 0 100 3 Temperature Rise (°C) 70 2 3.5 80 1.6 1 4 100 Inductance 0 Idc (A) 90 0 0 100 0.4 Inductance (µH) 0 2 Inductance (µH) 10 10 2.4 20 8 1 20 0 6 1.2 Inductance (µH) 70 Temperature Rise (°C) Inductance (µH) 100 80 Inductance 1 0 4 Idc (A) 1.2 0.4 2 MPI4020V2-1R5-R MPI4020V2-1R2-R 1.4 0 Temperature Rise (°C) 0 20 0.2 10 0.5 0 10 0 0.5 1 1.5 2 2.5 3 Idc (A) 3.5 4 4.5 5 5.5 6 0 Temperature Rise (°C) 0 100 90 0.6 Inductance (µH) MPI4020V2-1R0-R 1.2 100 Temperature Rise (°C) MPI4020V2-R68-R 0.7 MPI40-V2 High current, low profile, miniature power inductors Technical Data 10651 Effective April 2017  Inductance and temperature rise vs. Current MPI4020V2-4R7-R MPI4020V2-6R8-R 90 80 3.5 70 3 60 2.5 50 2 40 1.5 30 Temperature Rise 1 20 0.5 10 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 80 5 70 60 4 50 3 40 2 30 Temperature Rise 20 1 0 0 Idc (A) 10 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 0 Idc (A) MPI4020V2-100-R 12 Inductance MPI4020V2-150-R 100 16 100 90 10 50 6 40 4 30 Temperature Rise 0 0.5 1 1.5 2 2.5 3 3.5 4 MPI4020V2-220-R 50 40 6 Temperature Rise 30 2 0 0 20 10 0 0.4 0.8 1.2 1.6 2 2.4 0 100 90 80 Inductance 16 70 14 60 12 50 10 40 8 6 30 Temperature Rise 4 20 2 10 0 0.4 0.8 1.2 1.6 2 2.4 2.8 Temperature Rise (°C) 18 Inductance (µH) 60 8 Idc (A) 20 0 70 10 10 Idc (A) 22 80 4 20 2 90 Inductance 12 Inductance (µH) 60 Temperature Rise (°C) Inductance (µH) 70 8 0 14 80 Inductance Temperature Rise (°C) 0 90 6 Inductance (µH) Inductance 4 Temperature Rise (°C) Inductance (µH) 4.5 100 7 100 Temperature Rise (°C) 5 0 Idc (A) www.eaton.com/electronics 21 MPI40-V2 High current, low profile, miniature power inductors  Technical Data 10651 Effective April 2017 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb Solder (Tc) Package Thickness Volume mm3
MPI4012V2-R33-R
物料型号:MPI40-V2系列,包括不同高度和电感值的型号。
器件简介:这是一系列高电流、低轮廓的微型功率电感器,适用于手持移动设备、便携式媒体播放器、笔记本电脑电源、平板电脑、电池操作设备、LED驱动器、LCD显示器、点对点(POL)转换器等。
引脚分配:文档中未明确提供引脚分配信息,但提供了推荐的焊盘布局。
参数特性: - 存储温度范围:-55°C 至 +125°C - 工作温度范围:-55°C 至 +125°C(环境温度加上自温升) - 自谐振频率(SRF)大于9.5 MHz - 符合J-STD-020标准的焊接回流温度 - 无卤、无铅、符合RoHS标准 - 电感范围从0.1 μH到22 μH - 电流范围从1.2 A到22 A - 4.75 mm x 4.45 mm的焊盘尺寸,有1.2 mm、1.5 mm和2.0 mm高度的表面贴装封装 - 湿度敏感等级(MSL):1
功能详解:电感器具有高电流承载能力、磁屏蔽、低电磁干扰(EMI)、坚固的柔性结构。
应用信息:适用于多种便携式和电池供电设备,以及LED驱动和LCD显示等。
封装信息:提供1.2 mm、1.5 mm和2.0 mm三种不同高度的封装选项,每种封装都有特定的尺寸和焊盘布局要求。
此外,文档还包含了详细的产品规格、尺寸、推荐焊盘布局、原理图、包装信息、核心损耗与磁感应强度(Bp-p)的关系图、电感与频率的关系图、电感与温度升高和电流的关系图,以及焊接回流曲线图。
MPI4012V2-R33-R 价格&库存
很抱歉,暂时无法提供与“MPI4012V2-R33-R”相匹配的价格&库存,您可以联系我们找货
MPI4012V2-R33-R
  • 3000+5.53768
  • 12000+4.63086
库存:24000
MPI4012V2-R33-R
  • 1+6.600871+0.82776
  • 10+5.4414610+0.68237
  • 100+4.47251100+0.56087
  • 1000+3.678181000+0.46125
库存:2756
