S34547
S34547
    NEWAVA
    IND_21.59X20.06MM_TM
    固定电感器 Radial, Horizontal, 8 Leads 150µH 180mΩ 950KHz
S34547 数据手册
EP10 LM259X Inductor 150 uHy 0.500 Max 5 6 7 8 NEWAVA S34547 YYWW 0.470 Max 4 3 2 All Pins: 0.061 Sq. 1 0.120 Min 0.450 Max 0.295 +/- 0.020 0.100 Typ ELECTRICAL SPECS: 1,2,3,4 Jumper Terminals on PC board 1: INDUCTANCE: @ 10 kHz, 0.1 Vrms (1 thru 4 to 5 thru 8) = 150 - 195 uHy 5,6,7,8 Jumper Terminals on PC board 2: DCRs: (1 thru 4 tp 5 thru 8) = 0.180 Ohms Max. 3: SRF: 950 kHz Min 2/28/03 A 4: HIPOT: 500 VDC Winding to core (2 Sec., 5 mA Max) REV. + - All pins may not be used. Specifications at room temperature of 25 C. .XXX - KAM DATE ECN BY TOLERANCES ON ANGLE .XX + + - - Production Release DESCRIPTION Newava Tech. Watertown, SD 57201 150 uHy Inductor 605-886-0264 DATE DRAWN: SCALE CHECKED: APPROVED: - KAM NEXT ASSY: THIS PRINT MUST NOT BE COPIED IN WHOLE OR IN PART MODEL DRAWING NO. S34547 OR USED DETRIMENTALLY TO OUR INTEREST REV. A SHEET 1 OF 1
S34547 价格&库存
很抱歉,暂时无法提供与“S34547”相匹配的价格&库存,您可以联系我们找货
