Technical Data 10247
Effective June 2014
MPI5451
High current, low profile power inductors
Applications
Handheld/mobile devices
Portable media players
MP3 Players
Battery operated devices
Notebook/netbook
Tablets/smartbooks
LCD Displays
LED Drivers
e
v
i
t
c
e
l
f
i
f
t
E
n
u
d
r
e
o
u
6
n
i
1
t
n
2
d
o
e
c
t
1
s
i
e
l
y
D
r
p
a
e
u
d
r
s
b
i
d
y
e
Fe
r
d
o
e
n
t
l
e
n
b
e
a
m
l
i
v
a
n
m
Pb HF
i
v
o
a
c
t
e
r
n
No ceme
a
l
p
re
Environmental data
Product description
Halogen free, lead free, RoHS compliant
125°C maximum total temperature
operation
5.74 x 5.43 footprint surface mount
package with either 1.2 or 2.0mm
heights
Magnetically shielded, low EMI
Rugged construction
Inductance range from 0.33µH to 15µH
Current range from 1.1 to 11.5 amps
Storage temperature range (Component):
-40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise)
Solder reflow temperature:
J-STD-020D compliant
Packaging
Supplied in tape and reel packaging on a 13”
diameter reel
HALOGEN
FREE
MPI5451
Effective June 2014
Product specifications
OCL1
(μH) ± 20%
Part Number5
Irms2
(Amps)
Isat3
(Amps)
DCR (mΩ)
@ 25°C ± 20%
K-Factor4
R1 - 1.2mm height
MPI5451R1-R33-R
0.33
6.5
11.5
13
1244
MPI5451R1-R47-R
0.47
6.1
10.9
18
995
MPI5451R1-1R0-R
1.0
4.2
7.2
30
622
MPI5451R1-1R5-R
1.5
3.4
6.1
48
498
MPI5451R1-2R2-R
2.2 ± 15%
2.6
4.8
70
452
MPI5451R1-3R3-R
3.3 ± 15%
2.3
3.8
95
355
MPI5451R1-4R7-R
4.7 ± 15%
2.1
3.5
120
293
MPI5451R1-5R6-R
5.6 ± 15%
1.9
3.1
145
249
MPI5451R1-6R8-R
6.8 ± 15%
1.7
2.8
175
237
MPI5451R1-100-R
10.0 ± 15%
1.3
2.5
290
199
MPI5451R1-150-R
15.0 ± 15%
1.1
2.2
400
155
MPI5451R3-R47-R
0.47
6.0
9.0
8.8
1244
MPI5451R3-R68-R
0.68
5.9
8.0
9.5
995
MPI5451R3-1R0-R
1.0
5.1
6.6
14
711
MPI5451R3-1R5-R
1.5
5.0
5.8
16
553
MPI5451R3-2R2-R
2.2
4.1
5.0
24
452
MPI5451R3-3R3-R
3.3
3.7
4.2
33
383
MPI5451R3-4R7-R
4.7
3.0
3.8
50
293
MPI5451R3-6R8-R
6.8
2.6
3.0
70
249
MPI5451R3-100-R
10.0
2.1
2.4
110
207
e
v
i
t
c
e
l
f
i
f
t
E
n
u
d
r
e
o
u
6
n
i
1
t
n
2
d
o
e
c
t
1
s
i
e
l
y
D
r
p
a
e
u
d
r
s
b
i
d
y
e
Fe
r
d
o
e
n
t
l
e
n
b
e
a
m
l
i
v
a
n
m
i
v
o
a
c
t
re
n
e
o
N
m
e
c
a
l
rep
R3 - 2.0mm height
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.1Vrms, 0.0Adc,
25°C
2. Irms: DC current for an approximate temperature rise of 40°C without core
loss. Derating is necessary for AC currents. PCB layout, trace thickness and
width, air-flow, and proximity of other heat generating components will affect
the temperature rise. It is recommended that the temperature of the part
not exceed 125°C under worst case operating conditions verified in the end
application.
3. Isat: Peak current for approximately 20% rolloff at +25°C
Dimensions - mm
2
4. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I.
Bp-p:(Gauss), K: (K-factor from table), L: (Inductance in µH), ∆I (Peak to peak
ripple current in Amps).
5. Part Number Definition: MPI5451Rx-yyy-R
- MPI5451Rx = Product code and size
- yyy= Inductance value in uH, R = decimal point, if no R is present then third
character = number of zeros
- “-R” suffix = RoHS compliant
MPI5451
Effective June 2014
Packaging information - mm
e
v
i
t
c
e
l
f
i
f
t
E
n
u
d
r
e
o
u
6
n
i
1
t
n
2
d
o
e
c
t
1
s
i
e
l
y
D
r
p
a
e
u
d
r
s
b
i
d
y
e
Fe
r
d
o
e
n
t
l
e
n
b
e
a
m
l
i
v
a
n
m
i
v
o
a
c
t
re
n
e
o
N
m
e
c
a
l
rep
Supplied in tape and reel packaging,
MPI5451R1 4000 parts per 13” diameter reel
MPI5451R3 3000 parts per 13” diameter reel
Core loss
www.eaton.com/elx
3
Effective June 2014
MPI5451
Inductance characteristics / temperature rise
e
v
i
t
c
e
l
f
i
f
t
E
n
u
d
r
e
o
u
6
n
i
1
t
n
2
d
o
e
c
t
1
s
i
e
l
y
D
r
p
a
e
u
d
r
s
b
i
d
y
e
Fe
r
d
o
e
n
t
l
e
n
b
e
a
m
l
i
v
a
n
m
i
v
o
a
c
t
re
n
e
o
N
m
e
c
a
l
rep
4
MPI5451
Effective June 2014
e
v
i
t
c
e
l
f
i
f
t
E
n
u
d
r
e
o
u
6
n
i
1
t
n
2
d
o
e
c
t
1
s
i
e
l
y
D
r
p
a
e
u
d
r
s
b
i
d
y
e
Fe
r
d
o
e
n
t
l
e
n
b
e
a
m
l
i
v
a
n
m
i
v
o
a
c
t
re
n
e
o
N
m
e
c
a
l
rep
www.eaton.com/elx
5
Effective June 2014
MPI5451
e
v
i
t
c
e
l
f
i
f
t
E
n
u
d
r
e
o
u
6
n
i
1
t
n
2
d
o
e
c
t
1
s
i
e
l
y
D
r
p
a
e
u
d
r
s
b
i
d
y
e
Fe
r
d
o
e
n
t
l
e
n
b
e
a
m
l
i
v
a
n
m
i
v
o
a
c
t
re
n
e
o
N
m
e
c
a
l
rep
6
MPI5451
Effective June 2014
e
v
i
t
c
e
l
f
i
f
t
E
n
u
d
r
e
o
u
6
n
i
1
t
n
2
d
o
e
c
t
1
s
i
e
l
y
D
r
p
a
e
u
d
r
s
b
i
d
y
e
Fe
r
d
o
e
n
t
l
e
n
b
e
a
m
l
i
v
a
n
m
i
v
o
a
c
t
re
n
e
o
N
m
e
c
a
l
rep
www.eaton.com/elx
7
MPI5451
Effective June 2014
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Package
Thickness
Temperature
TL
25°C
Preheat
A
T smax
Table 1 - Standard SnPb Solder (T c)
t
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
Package
Thickness
2.5mm
ts
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020D
Profile Feature
Preheat and Soak
100°C
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support
systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to
result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update,
without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
www.eaton.com/elx
© 2014 Eaton
All Rights Reserved
Publication No. 10247 — BU-SB14346
June 2014
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“MPI5451R1-6R8-R”相匹配的价格&库存,您可以联系我们找货
