SWR12JTEA1600
SWR12JTEA1600
    VIKING(光颉)
    贴片电阻 2512 160Ω ±5% 1.5W ±100ppm/℃
SWR12JTEA1600 数据手册
Data Sheet Customer: Product: Surge Withstanding Chip Resistor - SWR Series Size: 0402/0603/0805/1206/1210/2010/2512 Issued Date: 10-Mar-21 Edition: REV. B4 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 10-Mar-21 10-Mar-21 10-Mar-21 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) 【SWR Series】 Surge Withstanding Chip Resistor Surge Withstanding Chip Resistor – SWR Series ■Features -High power rating -Excellent surge withstanding & pulse withstanding performance -Improved working voltage ratings -Standard package sizes of 0402~2512 -AEC-Q200 Compliance ■Applications -Metering (Testing/Measurement) -Medical Devices -Power supply -Charger -Inverter L -LCD Video Monitors D1 W  Alumina Substrate  Bottom Electrode  Top Electrode  Edge Electrode  Barrier Layer     T    D2      External Electrode Resistor Layer Primary Overcoat Secondary Overcoat ■Dimensions Type Size (Inch) L (mm) W (mm) T (mm) D1 (mm) D2 (mm) Weight (g) (1000pcs) SWR02 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.64 SWR03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 SWR05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 SWR05(1/2W) 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 5.049 SWR06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 SWR06(3/4W) 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 9.541 SWR13 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 SWR10 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 SWR12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 SWR12(2W) 2512 6.35±0.20 3.15±0.15 Derating Curve 0.60±0.10 0.60±0.25 0.60±0.20 42 100 Power ratio(%) . ■Derating Curve 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) www.viking.com.tw For detail questions, contact : sales@viking.com.tw 1 Edition : REV.B4 Revision: 10-Mar-2021 【SWR Series】 Surge Withstanding Chip Resistor ■Part Numbering SWR Product Type 05 Dimensions 02: 0402 03: 0603 05: 0805 06: 1206 13: 1210 10: 2010 12: 2512 J T E Resistance Tolerance J: ±5% K: ±10% M: ±20% Packaging Code TCR (PPM/°C) T: 7”Taping Reel V:10”Taping Reel W:13”Taping Reel E: ±100 F: ±200 G: ±300 4: ±350 V 1001 Power Rating A: 1.5W T: 1W Q: 3/4W U: 1/2W G: 2/5W O: 1/3W V: 1/4W W: 1/8W P: 1/5W S: 2W Marking Resistance 1001: 1KΩ 1004: 1MΩ 1005: 10MΩ : Standard Marking N: No Marking ■Standard Electrical Specifications Item Type Power Rating at 70°C Operating Max. Operating Max. Overload Temp. Range Voltage Voltage SWR02 (0402) 1/5W -55 ~ +155C 50V 100V SWR03 (0603) 1/8W -55 ~ +155C 50V 100V SWR05 (0805) 1/4W -55 ~ +155C 150V 300V SWR06 (1206) 1/3W -55 ~ +155C 200V 400V SWR13 (1210) 1/2W -55 ~ +155C 200V 400V SWR10 (2010) 3/4W SWR12 (2512) 1.5W -55 ~ +155C -55 ~ +155C 400V Resistance Range(E24) ±5% ±20% 1Ω - 20Ω ±300 22Ω - 1MΩ ±100 10Ω - 270Ω ±200 300Ω - 1MΩ ±100 1Ω - 270Ω ±200 300Ω - 20MΩ ±100 1Ω - 20Ω ±200 22Ω - 20MΩ ±100 1Ω - 20Ω ±200 22Ω - 20MΩ ±100 1Ω - 20Ω ±200 22Ω - 20MΩ ±100 1Ω - 20Ω ±200 22Ω - 20MΩ ±100 Resistance Range (E24) TCR (PPM/°C) 800V 500V ±10% TCR (PPM/°C) 1000V ■High Power & Ultra High Power Rating Electrical Specifications Item Type Power Rating at 70°C SWR03 (0603) 1/4W Operating Max. Operating Max. Overload Temp. Range Voltage Voltage -55 ~ +155C 75V 150V SWR05 (0805) 2/5W -55 ~ +155C 150V 300V SWR05 (0805) 1/2W * -55 ~ +155C 400V 600V SWR06 (1206) 1/2W -55 ~ +155C 200V 400V SWR06 (1206) 3/4W * -55 ~ +155C 500V 1000V SWR13 (1210) 3/4W -55 ~ +155C 200V 400V www.viking.com.tw ±5% For detail questions, contact : sales@viking.com.tw 2 ±10% ±20% 10Ω - 270Ω ±200 300Ω - 1MΩ ±100 1Ω - 270Ω ±200 300Ω - 1MΩ ±100 1Ω - 270Ω ±200 300Ω - 1MΩ ±100 1Ω - 20Ω ±200 22Ω - 1MΩ ±100 1Ω - 20Ω ±200 22Ω - 1MΩ ±100 1Ω - 20Ω ±200 Edition : REV.B4 Revision: 10-Mar-2021 【SWR Series】 Surge Withstanding Chip Resistor Item Type Power Rating at 70°C Operating Max. Operating Max. Overload Temp. Range Voltage Voltage SWR10 (2010) 1W -55 ~ +155C 400V 800V SWR12 (2512) 2W * -55 ~ +155C 500V 1000V Resistance Range (E24) ±5% ±10% ±20% TCR (PPM/°C) 22Ω - 1MΩ ±100 1Ω - 20Ω ±200 22Ω - 1MΩ ±100 1Ω - 10Ω 11Ω – 200KΩ ±350 ±100 *: Ultra High Power: double side printed resistor element Operating Voltage=√(P*R) or Max. Operating Voltage listed above, whichever is lower. Overload Voltage=2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower. The power rating depends on the maximum temperature of the resistive element. Due to the power dissipation of the resistor, the temperature of the resistive element will rise depending on the condition of heat dissipation from PCB. The maximum power rating in application only applies if the temperature of the resistive element is not exceed 155 ° C. ■ Viking is capable of manufacturing the optional spec based on customer’s requirement. ■Soldering Condition (IPC/JEDEC J-STD-020) ■Environmental Characteristics Item Requirement Temperature Coefficient of Resistance (T.C.R.) As Spec. Short Time Overload (1.0%+0.05Ω) Insulation Resistance 10G Endurance (3.0%+0.05Ω) Damp Heat with Load (3.0%+0.05Ω) Dry Heat (3.0%+0.05Ω) www.viking.com.tw Test Method JIS-C-5201-1 4.8 IEC-60115-1 4.8 At 25C/-55C and 25C/+125C, 25C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds JIS-C-5201-1 4.6 IEC-60115-1 4.6 Max. Overload Voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.24 IEC-60115-1 4.24 402C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hr “ON” and 0.5 hrs “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +155C for 1000 hrs For detail questions, contact : sales@viking.com.tw 3 Edition : REV.B4 Revision: 10-Mar-2021 【SWR Series】 Surge Withstanding Chip Resistor Item Requirement Bending Strength (1.0%+0.05Ω) Solderability 95% min. coverage Resistance to Soldering Heat (1.0%+0.05Ω) Voltage Proof Test Method JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending once for 60 seconds 2010, 2512 sizes: 2mm Other sizes: 3mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 2455C for 3 seconds JIS-C-5201-1 4.18 IEC-60115-1 4.18 2605C for 10 seconds JIS-C-5201-1 4.7 IEC-60115-1 4.7 No breakdown or flashover Leaching Rapid Change of Temperature 1.42 times Max. Operating Voltage for 1 minute Individual leaching area ≦5% JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 Total leaching area ≦ 10% 2605C for 30 seconds JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55C to +155C, 5 cycles (1.0%+0.05Ω) RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■Storage Temperature: 15~28C; Humidity < 80%RH ■Packaging Reel Specifications & Packaging Quantity Type SWR02 Paper SWR03 SWR05 SWR06 Paper SWR13 SWR10 SWR12 Tape Width Reel Diameter ΦA (mm) 10K 8mm 7 inch 178.5±1.5 20K 8mm 10 inch 254±1.0 40K 8mm 13 inch 330±1.0 Packaging Quantity Embossed Paper Tape Specifications ΦB (mm) ΦC (mm) W (mm) T (mm) 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 13.0±0.2 9.0±0.5 12.5±0.5 60 +1/-0 5K 8mm 7 inch 178.5±1.5 10K 8mm 10 inch 254±1.0 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 20K 8mm 13 inch 330±1.0 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 4K 12mm 7 inch 178.5±1.5 +1/-0 13.0±0.5 13.0±0.5 15.5±0.5 8K 12mm 10 inch 250±1.0 62±0.5 13.0±0.5 12.5±0.5 16.5±0.5 Bottom Tape Top Tape 60 +1/-0 60 ψ D0 E A F B T Paper Tape www.viking.com.tw P1 Resistor P2 P0 For detail questions, contact : sales@viking.com.tw 4 W Direction of unreeling Edition : REV.B4 Revision: 10-Mar-2021 【SWR Series】 Surge Withstanding Chip Resistor A (mm) Type B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) P2 (mm) ΦD0 (mm) T (mm) SWR02 0.65±0.10 1.15±0.10 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.1 SWR03 1.10±0.10 1.90±0.1 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.1 SWR05 1.60±0.10 2.40±0.2 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.1 SWR06 1.90±0.10 3.50±0.2 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.1 SWR13 2.90±0.10 3.50±0.2 8.00±0.2 1.75±0.1 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.1 Embossed Plastic Tape Specifications Top Tape ψ D0 E A F B W ψD11.5+0.25,-0 T P1 Resistor P2 P0 Direction of unreeling Embossed Tape ΦD0 (mm) Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) P2 (mm) T (mm) SWR10 2.80±0.10 5.40±0.20 12.0±0.3 1.75±0.1 5.5±0.05 4.00±0.10 4.00±0.1 2.00±0.05 1.50+0.1, -0 1.2 +0 SWR12 3.50±0.10 6.70±0.10 12.0±0.3 1.75±0.1 5.5±0.05 4.00±0.10 4.00±0.1 2.00±0.05 1.50+0.1, -0 1.2 +0 ■Marking No Marking for 0402 0805~2512 4 digits marking for Example Resistance 100Ω 2.2KΩ 10KΩ 100KΩ 1MΩ Marking 1000 2201 1002 1003 1004 0603: 3 digits marking in E24 st Example: 101=100Ω 102=1KΩ (1 and 2 E24 code 10 11 12 13 15 16 nd 18 rd are E24 code and 3 code is multiplier) 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 ■Recommend Land Pattern SWR02 A (mm) 0.50 B (mm) 0.45 C (mm) 0.60 SWR03 0.90 0.60 0.90 SWR05 1.20 0.70 1.30 SWR06 2.00 0.90 1.60 SWR13 2.00 0.90 2.80 SWR10 3.80 0.90 2.80 SWR12 4.90 1.00 3.40 Type C B A www.viking.com.tw For detail questions, contact : sales@viking.com.tw 5 Edition : REV.B4 Revision: 10-Mar-2021 【SWR Series】 Surge Withstanding Chip Resistor ■Lightning Surge Resistors are tested in accordance with IEC 60115-1 using both 1.2/50us and 10/700 pulse shapes. The limit of acceptance is a shift in resistance of less than 1% from the initial value. SWR Series 1.2/50us Lightning Surge Peak Voltage (V) 10000 2512 2010 1210 1206 0805 0603 1000 100 10 1 10 100 1000 10000 100000 1000000 Resistance(Ω) SWR Series 10/700us Lightning Surge Peak Voltage (V) 10000 2512 2010 1210 1206 0805 0603 1000 100 10 1 10 100 1000 10000 100000 1000000 Resistance(Ω) www.viking.com.tw For detail questions, contact : sales@viking.com.tw 6 Edition : REV.B4 Revision: 10-Mar-2021 【SWR Series】 Surge Withstanding Chip Resistor ■Pulse withstanding capacity The limit of acceptance was a shift in resistance of less than 1% from the initial value. The power applied was subject to the restrictions of the maximum permissible impulse voltage graph shown. www.viking.com.tw For detail questions, contact : sales@viking.com.tw 7 Edition : REV.B4 Revision: 10-Mar-2021 【SWR Series】 Surge Withstanding Chip Resistor ■Continuous Pulse The continuous load graph was obtained by applying repetitive rectangular pulses where the pulse period was adjusted so that the average power dissipated in the resistor was equal to its rated power at 70C. Again the limit of acceptance was a shift in resistance of less than 1% from the initial value. www.viking.com.tw For detail questions, contact : sales@viking.com.tw 8 Edition : REV.B4 Revision: 10-Mar-2021 【SWR Series】 Surge Withstanding Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version A8 Jun 03, 2014 - - Environmental Characteristics updated Version A9 Jul 15, 2016 - - Remove Material Description - Modify Storage Temperature Version B Oct 13, 2017 - - Increase High Power Specifications Version B1 Jul 27, 2018 - - Increase 0402 size Electrical Specifications - Increase 0805/1206 Ultra High Power Electrical Specifications Version B2 May 20, 2019 - - Modify TCR Test description Version B3 Jan 31, 2020 - - Increase SWR2512 2W Version B4 Mar 10, 2021 www.viking.com.tw - Modify Bending Test description - Increase large reel packaging code - Modify 2010 Embossed Plastic Tape B Specification - Modify Soldering Condition (IPC/JEDEC J-STD-020) - For detail questions, contact : sales@viking.com.tw 9 Edition : REV.B4 Revision: 10-Mar-2021
SWR12JTEA1600
物料型号:SWR系列 器件简介:SWR系列电阻器具有高功率等级、优秀的浪涌和脉冲耐受性能、改进的工作电压等级,并且符合AEC-Q200标准。 引脚分配:文档中提供了不同尺寸的电阻器的尺寸和重量,例如SWR02(0402尺寸)、SWR03(0603尺寸)等,直至SWR12(2512尺寸)。 参数特性:包括功率等级、工作温度范围、最大操作电压、最大过载电压、电阻范围、温度系数(TCR)。 功能详解:文档详细描述了电阻器的物理结构,包括氧化铝基板、外部电极、底电极、电阻层、顶电极、边缘电极、主覆盖层、次覆盖层和障碍层。 应用信息:SWR系列电阻器适用于测量设备、医疗设备、电源、充电器、逆变器和液晶视频监视器。 封装信息:提供了不同尺寸的电阻器的封装信息,包括尺寸、重量等。
此外,文档还包含了电阻器的派生型号、电气规格、高功率和超高功率电气规格、环境特性、弯曲强度、焊接性、耐焊热性、电压证明、浸出和快速温度变化等测试方法和要求。还提供了焊接条件、存储温度、湿度要求、包装规格和标记信息。最后,文档还包含了浪涌测试和脉冲耐受能力的数据图表。
SWR12JTEA1600 价格&库存
很抱歉,暂时无法提供与“SWR12JTEA1600”相匹配的价格&库存,您可以联系我们找货
