RVC2512FT511R
RVC2512FT511R
    SEI
    贴片电阻 2512 511Ω ±1% 1W ±200ppm/℃
RVC2512FT511R 数据手册
RVC Series Stackpole Electronics, Inc. Medium Voltage Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • Voltage ratings 2 times or more compared to standard chip resistors Values up to 100MΩ Lower resistance values may be available - contact Stackpole Proportionally higher pulse power capability RoHS compliant and halogen free REACH compliant Electrical Specifications Type / Code Power Rating (W) @ 70ºC Max Working Voltage (V) Max Overload Voltage (V) TCR (ppm/ºC) RVC0402 0.063 100 200 ±100 ±200 ±400 RVC0603 0.1 200 400 ±100 ±200 ±400 RVC0805 0.125 400 800 ±100 ±200 ±400 RVC1206 0.25 500 1000 ±100 ±200 ±400 RVC2010 0.5 2000 3000 ±100 ±200 ±400 RVC2512 1 3000 4000 ±100 ±200 ±400 Ohmic Range (Ω) and Tolerance 1% 5% 39K - 1M 1.02M - 10M 1.1M - 20M 22M - 100M 56K - 1M 1.02M - 10M 1.1M - 20M 22M - 100M 100K - 1M 1.02M - 10M 1.1M - 20M 22M - 100M 100K - 1M 1.02M - 10M 1.1M - 20M 22M - 100M 51K- 1M 1.02M - 20M 1.1M - 20M 22M - 100M 30K - 1M 1.02M - 20M 1.1M - 20M 22M - 100M - Working Voltage = √ P*R or maximum working voltage listed above, whichever is lower. Overload Voltage = 2.5* √ P*R or maximum overload voltage listed above, whichever is lower. Mechanical Specifications Type / Code Weight (g) (1000 pc) L Body Length W Body Width H Body Height a Top Termination b Bottom Termination Unit RVC0402 0.620 0.039 ± 0.002 1.00 ± 0.05 0.020 ± 0.002 0.50 ± 0.05 0.014 ± 0.002 0.35 ± 0.05 0.008 ± 0.004 0.20 ± 0.10 0.008 ± 0.004 0.20 ± 0.10 inches mm RVC0603 2.042 0.063 ± 0.004 1.60 ± 0.10 0.031 ± 0.004 0.80 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 inches mm RVC0805 4.368 0.079 ± 0.004 2.00 ± 0.10 0.049 ± 0.004 1.25 ± 0.10 0.020 ± 0.004 0.50 ± 0.10 0.014 ± 0.008 0.35 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 inches mm RVC1206 8.947 0.122 ± 0.004 3.10 ± 0.10 0.061 ± 0.004 1.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.020 ± 0.010 0.50 ± 0.25 0.020 ± 0.008 0.50 ± 0.20 inches mm Rev Date: 01/23/2019 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RVC Series Stackpole Electronics, Inc. Medium Voltage Thick Film Chip Resistor Resistive Product Solutions Mechanical Specifications (cont.) Type / Code Weight (g) (1000 pc) L Body Length W Body Width H Body Height a Top Termination b Bottom Termination Unit RVC2010 24.241 0.197 ± 0.008 5.00 ± 0.20 0.098 ± 0.006 2.50 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.024 ± 0.010 0.60 ± 0.25 0.020 ± 0.008 0.50 ± 0.20 inches mm RVC2512 39.448 0.250 ± 0.008 6.35 ± 0.20 0.126 ± 0.006 3.20 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.024 ± 0.010 0.60 ± 0.25 0.020 ± 0.008 0.50 ± 0.20 inches mm Performance Characteristics Test Test Method Temperature Coefficient of Resistance (TCR) JIS-C-5201-1 4.8 IEC-60115-1 4.8 JIS-C-5201-1 4.13 IEC-60115-1 4.13 JIS-C-5201-1 4.6 IEC-60115-1 4.6 JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 JIS-C-5201- 4.24 IEC-60115-1 4.24 JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 JIS-C-5201-1 4.33 IEC-60115-1 4.33 JIS-C-5201-1 4.17 IEC-60115-1 4.17 JIS-C-5201-1 4.18 IEC-60115-1 4.18 JIS-C-5201-1 4.7 IEC-60115-1 4.7 Short Time Overload Insulation Resistance Endurance Damp Heat with Load Dry Heat Bending Strength Solderability Resistance to Soldering Heat Voltage Proof Test Specification ± 1% ± 5% As specified by Electrical Specification Table ±(1% + 0.05Ω) Test Method -55°C ~ +125°C, 25°C is the reference temperature RCWV * 2.5 or Max. Overload Voltage whichever is lower for 5 seconds ±(2% + 0.05Ω) ≥ 10G Max. Overload voltage for 1 minute 70ºC ± 2°C, RCWV for 1000 hours with 1.5 hour "ON" and 0.5 hour "OFF" 40ºC ± 2°C, 90% ~ 95% R.H., RCWV for 1000 hours with 1.5 hour "ON" and 0.5 hour "OFF" ±(2% + 0. 1Ω) ±(3% + 0.1Ω) ±(2% + 0. 1Ω) ±(3% + 0.1Ω) ±(1% + 0.05Ω) ±(1.5% + 0.1Ω) at +155°C for 1000 hours ±(1% + 0.05Ω) ±(1% + 0.05Ω) Bending once for 5 seconds 2010, 2512 sizes: 2 mm; other sizes: 3 mm 95% min. coverage ±(0.5% + 0.05Ω) 245ºC ± 5°C for 3 seconds ±(1% + 0.05Ω) 260ºC ± 5°C for 10 seconds 0402: 150V for 1 minute 0603: 300V for 1 minute 0805, 1206, 2010, 2512: 500V for 1 minute No breakdown or flashover Individual leaching area ≤ 5% JIS-C-5201-1 4.18 Total leaching area ≤ 10% IEC-60068-2-58 8.2.1 Rapid Change of JIS-C-5201-1 4.19 ±(0.5% + 0.05Ω) ±(1% + 0.05Ω) Temperature IEC-60115-1 4.19 RCWV (Rated continuous working voltage) =√ P*R or Max. Operating Voltage whichever is lower. Storage temperature: 25ºC ± 3°C; humidity < 80% RH Operating temperature range is -55°C to 155°C Leaching 260ºC ± 5°C for 30 seconds -55°C to +155°C, 5 cycles Power Derating Curve: Percent Rated Power (%) 100 -55ºC 70ºC 80 60 40 20 0 -60 155ºC 0 20 40 60 80 100 120 140 160 180 Ambient Temperature (ºC) Rev Date: 01/23/2019 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RVC Series Stackpole Electronics, Inc. Medium Voltage Thick Film Chip Resistor Resistive Product Solutions Recommended Pad Layout Type / Code RVC0402 RVC0603 RVC0805 RVC1206 RVC2010 RVC2512 a b c Unit 0.020 0.50 0.035 0.90 0.047 1.20 0.079 2.00 0.150 3.80 0.193 4.90 0.018 0.45 0.024 0.60 0.028 0.70 0.035 0.90 0.035 0.90 0.063 1.60 0.024 0.60 0.035 0.90 0.051 1.30 0.063 1.60 0.110 2.80 0.138 3.50 inches mm inches mm inches mm inches mm inches mm inches mm Soldering Conditions (1) Time of IR reflow soldering at maximum temperature point 260°C: 10 seconds (2) Time of wave soldering at maximum temperature point 260°C: 10 seconds (3) Time of soldering iron at maximum temperature point 410°C: 5 seconds Rev Date: 01/23/2019 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RVC Series Stackpole Electronics, Inc. Medium Voltage Thick Film Chip Resistor Resistive Product Solutions Reel Specifications Type / Code Tape Width (mm) Reel Diameter (inches) A B C W RVC0402, RVC0603 RVC0805, RVC1206 8 mm 7" 7.028 ± 0.059 178.50 ± 1.50 2.362 ± 0.039 60.00 ± 1.00 0.512 ± 0.008 13.00 ± 0.20 0.354 ± 0.020 9.00 ± 0.50 0.492 ± 0.020 inches 12.50 ± 0.50 mm RVC2010, RVC2512 12 mm 7" 7.028 ± 0.059 178.50 ± 1.50 2.362 ± 0.039 60.00 ± 1.00 0.512 ± 0.020 13.00 ± 0.50 0.512 ± 0.020 13.00 ± 0.50 0.610 ± 0.020 inches 15.50 ± 0.50 mm T Unit Paper Tape Specifications Type / Code RVC0402 RVC0603 RVC0805 RVC1206 A 0.026 0.65 0.043 1.10 0.063 1.60 0.075 1.90 Type / Code RVC0402 RVC0603 RVC0805 RVC1206 ± ± ± ± ± ± ± ± B 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.045 1.15 0.075 1.90 0.094 2.40 0.138 3.50 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 P0 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 P1 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± E 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 P2 Rev Date: 01/23/2019 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.018 0.45 0.028 0.70 0.031 0.80 0.033 0.85 ± ± ± ± ± ± ± ± D ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm T Unit www.seielect.com marketing@seielect.com RVC Series Stackpole Electronics, Inc. Medium Voltage Thick Film Chip Resistor Resistive Product Solutions Embossed Plastic Tape Specifications Type / Code RVC2010 RVC2512 A 0.110 2.80 0.138 3.50 Type / Code RVC2010 RVC2512 ± ± ± ± B 0.004 0.10 0.004 0.10 0.217 5.50 0.264 6.70 0.004 0.10 0.004 0.10 0.157 4.00 0.157 4.00 P0 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± W 0.004 0.10 0.004 0.10 0.472 12.00 0.472 12.00 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 P1 ± ± ± ± E ± ± ± ± 0.012 0.30 0.012 0.30 0.069 1.75 0.069 1.75 0.002 0.05 0.002 0.05 0.059 1.50 0.059 1.50 P2 ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.217 5.50 0.217 5.50 D ± ± ± ± 0.004 0.10 0.004 0.10 ± ± ± ± Unit 0.002 0.05 0.002 0.05 inches mm inches mm T Unit 0.047 1.20 0.047 1.20 inches mm inches mm RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Standard Termination Series RoHS Type Compliant Medium Voltage Thick Film SMD Surface Mount Chip Resistor Note (1): RoHS Compliant by means of exemption 7c-I. RVC YES(1) Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) 100% Matte Sn over Ni Jan-03 03/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Rev Date: 01/23/2019 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RVC Series Stackpole Electronics, Inc. Medium Voltage Thick Film Chip Resistor Resistive Product Solutions Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 R V C 0 8 0 5 J T 1 0 M 0 Product Series RVC Medium Voltage Size Code W 0402 0.063 0603 0.1 0805 0.125 1206 0.25 2010 0.5 2512 1 Tolerance Code Tol Value F 1% E96, E24 J 5% E24 Rev Date: 01/23/2019 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Packaging Code T 6 Description Size Quantity 0402 10000 7" Reel - Paper Tape 0603, 0805, 1206 5000 7" Reel - Plastic Tape 2010, 2512 4000 Resistance Value Four characters with the multiplier used as the decimal holder. 10 ohm = 10R0 10 Kohm = 10K0 1 Mohm = 1M00 100 Mohm = 100M www.seielect.com marketing@seielect.com
RVC2512FT511R
物料型号:RVC系列
器件简介:这是Stackpole Electronics, Inc.提供的中高压厚膜芯片电阻器,具有比标准芯片电阻器更高的电压等级,最高可达100MΩ的阻值。
引脚分配:文档中未明确提供引脚分配信息,但通常这类电阻器为SMD表面贴装形式。
参数特性: - 电压等级:比标准芯片电阻器高2倍以上。 - 脉冲功率能力:相对较高。 - 符合RoHS和REACH标准,无卤素。
功能详解: - 电阻器的工作电压和过载电压有特定的计算公式,确保电阻器在安全范围内工作。 - 提供了详细的电气规格,包括功率等级、最大工作电压、电气规格最大过载、欧姆范围和容差。
应用信息:适用于需要较高电压等级的应用场合。
封装信息: - 提供了详细的机械规格,包括重量、体长、体宽、体高以及端头尺寸。 - 还提供了推荐的焊盘布局和焊接条件。
RVC2512FT511R 价格&库存
很抱歉,暂时无法提供与“RVC2512FT511R”相匹配的价格&库存,您可以联系我们找货
