SCB73F-101
SCB73F-101
    SIGNAL
    非标准
    固定电感器 Nonstandard 100µH ±20% 620mA 950mΩ
SCB73F-101 数据手册
SCB73F SMD POWER INDUCTORS XXX MARKING ● Features Inductance Test (uH) Frequency DC Resistance (Ω MAX) (2) (1) Saturation(3) Temperature (4) Current Current (A) (A) 1.2 1KHZ 25m 2.88 5.50 SCB73F-1R5 1.5 1KHZ 26m 2.67 5.00 SCB73F-2R2 2.2 1KHZ 32m 2.40 4.40 SCB73F-3R3 3.3 1KHZ 45m 2.08 3.80 SCB73F-4R7 4.7 1KHZ 56m 1.92 3.00 SCB73F-6R8 6.8 1KHZ 67m 1.62 2.52 SCB73F-100 10 1KHZ 96m 1.41 2.10 SCB73F-120 12 1KHZ 0.10 1.28 1.90 SCB73F-150 15 1KHZ 0.13 1.12 1.75 SCB73F-180 18 1KHZ 0.16 1.00 1.64 SCB73F-220 22 1KHZ 0.18 0.93 1.58 SCB73F-270 27 1KHZ 0.24 0.80 1.34 33 SCB73F-390 39 SCB73F-470 47 BS SCB73F-330 O SCB73F-1R2 1KHZ 0.29 0.72 1.21 1KHZ 0.34 0.66 1.10 1KHZ 0.41 0.59 0.92 SCB73F-560 56 1KHZ 0.48 0.55 0.78 SCB73F-680 68 1KHZ 0.60 0.49 0.72 SCB73F-820 82 1KHZ 0.71 0.44 0.68 SCB73F-101 100 1KHZ 0.95 0.38 0.62 O SCB73F Inductance decrease BCB73F I nduct ance decr ease byby curcurrent r ent 1000 100 101 180 10 1 0. 1 10 100 1000 1R2 10000 100000 DCcurrent cur r ent(mA) ( mA) DC SCB73F Temperature byr ent current BCB73F Tem per at ur e r i se rise by cur Temperature Tem per at ur erise r i °C se ℃ Part NumSer I Inductance nduct ance( uH) (µH) ELECTRICAL CHARACTERISTICS LE TE 1. Open frame construction 2 Excellent Power Density 3 Engineered to Provide High Efficiency 80 70 60 101 50 180 1R2 40 30 20 10 0 1000 2000 3000 4000 5000 6000 7000 8000 9000 DC cur ent ( mA) DCrcurrent (mA) (1). Inductance tolerance±20% tested at 0.25V, 0ADC and 25℃. (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 10% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ ambient. Click here for QUANTITY PER REEL & PACKING INFORMATION © 2019 Signal Transformer –Specification subject to change without notice. 12.19 Custom versions available upon request. belfuse.com/signal 95 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com
SCB73F-101
1. 物料型号:SCB73F系列,包括多种型号,例如SCB73F-1R2、SCB73F-1R5等,每个型号具有不同的电感值。
2. 器件简介:SCB73F系列电感器具有开放式框架结构,优秀的功率密度,并且设计用于提供高效率。
3. 引脚分配:文档中没有提供具体的引脚分配信息,但通常SMD电感器会有指定的引脚用于焊接。
4. 参数特性:包括电感值、测试频率、直流电阻、饱和电流和温度电流等。例如,SCB73F-1R2型号的电感值为1.2微亨,在1kHz测试频率下的直流电阻为25毫欧,饱和电流为2.88安培。
5. 功能详解:文档提供了电感值随直流电流变化的图表,以及电流引起的温升图表,帮助用户了解电感器在不同工作条件下的性能。
6. 应用信息:虽然文档没有明确列出应用信息,但SCB73F系列电感器适用于需要高效率和功率密度的应用场合。
7. 封装信息:文档没有提供具体的封装尺寸信息,但提到了卷装和包装信息,用户可以根据需求定制版本。
SCB73F-101 价格&库存
很抱歉,暂时无法提供与“SCB73F-101”相匹配的价格&库存,您可以联系我们找货
