SC3308F-100
SC3308F-100
    SIGNAL
    非标准
    固定电感器 Nonstandard 10µH ±20% 2.48A 110mΩ
SC3308F-100 数据手册
SC3308F SMD POWER INDUCTORS XXX MARKING ● Features 1. Open frame construction 2 Excellent Power Density 3 Engineered to Provide High Efficiency ELECTRICAL CHARACTERISTICS DC Resistance (Ω MAX) (2) (1) Saturation(3) Temperature (4) Current Current (A) (A) SC3308F-100 10 100KHZ 0.11 2.4 2.48 SC3308F-150 15 100KHZ 0.15 2.0 2.10 SC3308F-220 22 100KHZ 0.23 1.6 1.64 SC3308F-330 33 100KHZ 0.30 1.4 1.30 SC3308F-470 47 100KHZ 0.39 1.0 1.00 SC3308F-680 68 100KHZ 0.66 0.9 0.82 SC3308F-101 100 100KHZ 0.84 0.7 0.70 SC3308F-151 150 100KHZ 1.2 0.6 0.62 SC3308F-221 220 100KHZ 1.9 0.5 0.48 SC3308F-331 330 100KHZ 2.7 0.4 0.38 SC3308F-471 470 100KHZ 4.0 0.3 0.28 SC3308F-681 680 100KHZ 5.3 0.2 0.24 SC3308F-102 1000 100KHZ 8.4 0.1 0.18 SC3308F Inductance decrease BC3308F I nduct ance decr ease bybycurcurrent r ent 10000 Inductance (µH)uH) I nduct ance( Inductance Test (uH) Frequency 1000 102 100 101 10 100 1 10 100 1000 cur r ent(mA) ( mA) DCDCcurrent 100000 10000 SC3308F Temperature byrcurrent BC3308F Tem per at ur e r i serise by cur ent Temperature riser i°C Tem per at ur e se ℃ Part Number 80 70 60 102 50 101 100 40 30 20 10 0 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 DC cur ent ( m(mA) A) DC rcurrent (1). Inductance tolerance±20% tested at 0.25V, 0ADC and 25℃. (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 10% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ ambient. . Click here for QUANTITY PER REEL & PACKING INFORMATION © 2019 Signal Transformer –Specification subject to change without notice. 12.19 Custom versions available upon request. belfuse.com/signal 79 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com
SC3308F-100
- 物料型号:SC3308F系列 - 器件简介:SC3308F系列是SMD功率电感,具有以下特点: 1. 开放框架结构 2. 出色的功率密度 3. 设计用于提供高效率 - 引脚分配:文档中未提供具体的引脚分配信息。 - 参数特性:列出了不同型号的电感值、测试频率、最大直流电阻、饱和电流及在特定电流下的温度上升情况。 - 功能详解:文档中未提供详细的功能解析,但提供了电感值随直流电流变化的图表。 - 应用信息:文档中未明确列出应用信息,但根据电感器的参数特性,可能适用于电源管理、信号处理等领域。 - 封装信息:文档中未提供封装的具体信息,但提到了可以根据需求定制版本。
SC3308F-100 价格&库存
很抱歉,暂时无法提供与“SC3308F-100”相匹配的价格&库存,您可以联系我们找货
