Technical Data 10649
Effective July 2018
MPI25-V2
High current, low profile, miniature power inductors
Applications
Mobile/smart phones
Handheld/mobile equipment
Tablets/e-readers
Digital cameras
Wearable devices
Notebook/netbook/laptop regulators
Portable media players
Environmental data
Product features
High current carrying capacity in a compact
standard 1008 (2520 metric) footprint
Magnetically shielded, Low EMI
Rugged construction
Self resonant frequency (SRF) greater
than 25 MHz
Inductance range from 0.33 μH to 4.7 μH
Current range from 1.2 A to 7.5 A
2.7 mm x 2.2 mm footprint surface mount package in 1.05 mm, 1.25 mm heights
Moisture Sensitivity Level (MSL): 1
Storage temperature range (Component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Halogen free, lead free, RoHS compliant
HALOGEN
Pb HF
FREE
MPI25-V2
Effective July 2018
Product specifications
OCL1
(μH) ±20%
Irms2
(A)
Isat3
(A)
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
SRF
(MHz)
typical
K-factor4
MPI2510V2-R33-R
0.33
4.8
6.6
15
6336
MPI2510V2-R47-R
0.47
4.4
6.0
19
25
100
5039
MPI2510V2-R68-R
0.68
3.1
4.3
37
44
80
5733
MPI2510V2-1R0-R
1.00
3.1
4.3
41
52
55
3372
MPI2510V2-1R5-R
1.50
2.5
2.5
65
85
45
4695
MPI2510V2-2R2-R
2.20
2.1
2.8
88
110
45
2873
MPI2510V2-3R3-R
3.30
1.6
2.1
140
170
35
1893
MPI2510V2-4R7-R
4.70
1.22
1.8
220
262
25
1616
MPI2512V2-R33-R
0.33
5.1
7.5
14
19
130
6560
MPI2512V2-R47-R
0.47
4.9
6.7
17
23
100
3628
MPI2512V2-R68-R
0.68
3.4
6.0
29
35
70
3633
MPI2512V2-1R0-R
1.00
3.3
4.4
36
44
70
3083
MPI2512V2-1R5-R
1.50
2.3
3.2
64
77
45
4850
MPI2512V2-2R2-R
2.20
2.2
3.5
73
87
30
2924
MPI2512V2-3R3-R
3.30
1.8
2.8
110
135
35
1965
MPI2512V2-4R7-R
4.70
1.4
1.9
196
235
25
1580
Part Number5
1.0 mm height
1.2 mm height
1. Open Circuit Inductance (OCL) Test Parameters: 1.0 MHz, 0.1 Vrms, 0.0 Adc, +25 °C.
2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of
other heat generating components will affect the temperature rise. It is recommended that the
temperature of the part not exceed +125 °C under worst case operating conditions verified in the
end application.
3. Isat : Peak current for approximately 30% rolloff @ +25 °C.
Dimensions (mm)
Dimension A
MPI2510V2
1.05 maximum
MPI2512V2
1.25 maximum,
No marking
All soldering surfaces to be coplanar within 0.10 millimeters
Tolerances are ±0.2 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
4. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p :(Gauss),
K: (K-factor from table), L: (Inductance in uH), ΔI (Peak to peak ripple current in Amps).
5. Part Number Definition: MPI25xxV2-xxx-R
MPI25 = Product code
xx= Height indicator
V2=Version indicator
xxx= inductance value in μH, R= decimal point, If no R is present then last character equals
number of zeros
-R suffix = RoHS compliant
MPI25-V2
Effective July 2018
Packaging information (mm)
Supplied in tape and reel packaging, 3000 parts per 7” diameter reel
Core loss vs. Bp-p (+25 °C)
MPI2510V2-R47-R
MPI2510V2-R33-R
10.000
3 MHz
10.000
3 MHz
2 MHz
2 MHz
300 kHz
0.100
100 kHz
1.000
Core Loss (mW)
500 kHz
Core Loss (mW)
1 MHz
1 MHz
1.000
500 kHz
300 kHz
0.100
100 kHz
0.010
0.010
0.001
0.001
100
1000
Bp-p (Gauss)
100
1000
Bp-p (Gauss)
3
MPI25-V2
Effective July 2018
MPI2510V2-R68-R
MPI2510V2-1R0-R
10.000
10.000
3 MHz
3 MHz
2 MHz
2 MHz
500 kHz
300 kHz
0.100
100 kHz
1 MHz
1.000
1 MHz
500 kHz
Core Loss (mW)
Core Loss (mW)
1.000
0.010
300 kHz
0.100
100 kHz
0.010
0.001
0.001
100
1000
100
Bp-p (Gauss)
1000
Bp-p (Gauss)
MPI2510V2-1R5-R
MPI2510V2-2R2-R
10.000
10.000
3 MHz
3 MHz
2 MHz
2 MHz
1.000
1 MHz
1.000
500 kHz
0.100
300 kHz
100 kHz
0.010
Core Loss (mW)
Core Loss (mW)
1 MHz
500 kHz
300 kHz
0.100
100 kHz
0.010
0.001
100
1000
0.001
100
Bp-p (Gauss)
MPI2510V2-3R3-R
MPI2510V2-4R7-R
3 MHz
10.000
2 MHz
1 MHz
1.000
0.100
100 kHz
0.010
500 kHz
Core Loss (mW)
300 kHz
1 MHz
1.000
500 kHz
Core Loss (mW)
3 MHz
10.000
2 MHz
300 kHz
0.100
100 kHz
0.010
0.001
100
1000
Bp-p (Gauss)
4
1000
Bp-p (Gauss)
0.001
1000
100
Bp-p (Gauss)
MPI25-V2
Effective July 2018
MPI2512V2-R47-R
MPI2512V2-R33-R
10.000
3 MHz
10.000
3 MHz
2 MHz
1 MHz
1 MHz
Core Loss (mW)
500 kHz
300 kHz
0.100
500 kHz
1.000
100 kHz
300 kHz
Core Loss (mW)
1.000
100 kHz
0.100
0.010
0.010
0.001
0.001
100
100
1000
MPI2512V2-1R0-R
MPI2512V2-R68-R
3 MHz
10.000
1000
Bp-p (Gauss)
Bp-p (Gauss)
3 MHz
10.000
2 MHz
1.000
0.100
100 kHz
Core Loss (mW)
500 kHz
300 kHz
2 MHz
1 MHz
1 MHz
1.000
Core Loss (mW)
2 MHz
500 kHz
300 kHz
100 kHz
0.100
0.010
0.010
0.001
0.001
100
100
1000
1000
Bp-p (Gauss)
Bp-p (Gauss)
MPI2512V2-1R5-R
MPI2512V2-2R2-R
10.000
10.000
3 MHz
3 MHz
2 MHz
2 MHz
500 kHz
300 kHz
0.100
100 kHz
0.010
1 MHz
1.000
1 MHz
Core Loss (mW)
Core Loss (mW)
1.000
500 kHz
300 kHz
0.100
100 kHz
0.010
0.001
100
1000
Bp-p (Gauss)
0.001
100
1000
Bp-p (Gauss)
5
MPI25-V2
Effective July 2018
MPI2512V2-3R3-R
MPI2512V2-4R7-R
3 MHz
10.000
3 MHz
10.000
2 MHz
2 MHz
1 MHz
1 MHz
1.000
1.000
300 kHz
0.100
100 kHz
Core Loss (mW)
Core Loss (mW)
500 kHz
0.010
500 kHz
300 kHz
0.100
100 kHz
0.010
0.001
100
0.001
1000
100
1000
Bp-p (Gauss)
Bp-p (Gauss)
Inductance and Q vs. Frequency
MPI2510V2-R33-R
MPI2510V2-R47-R
0.40
30
0.20
0.15
Q value
40
0.25
0.00
1.0
10.0
100.0
35
30
0.4
25
0.3
10
0.1
5
1
Frequency (MHz)
70
2.0
60
1.8
60
1
50
40
0.6
30
0.4
Q value
0.8
Inductance (uH)
1.6
50
1.4
40
1.2
30
1.0
0.8
0.4
0.2
10
1
10
Frequency (MHz)
MPI2510V2-1R0-R
1.2
Inductance (uH)
100
Frequency (MHz)
MPI2510V2-R68-R
6
10
100
10
0.2
0.0
0.1
1.0
10.0
Frequency (MHz)
100.0
Q value
0.1
40
0.2
10
0.05
45
0.5
Inductance (uH)
0.30
50
0.6
50
0.35
Inductance (uH)
0.7
60
Q value
0.45
MPI25-V2
Effective July 2018
MPI2510V2-1R5-R
MPI2510V2-2R2-R
1.0
10
0.5
2.5
10.0
100.0
15
1.5
10
1.0
5
0.5
0.0
0.1
1.0
Frequency (MHz)
8
40
30
5
25
4
15
2
10
2.0
1
5
1.0
0.0
Inductance (uH)
35
6
100
35
8.0
7
9.0
Q value
Inductance (uH)
10.0
45
10
30
7.0
25
6.0
5.0
15
3.0
10
5
0.1
1.0
0.40
90
0.35
80
0.8
0.30
60
0.25
50
0.20
40
0.15
30
0.10
10
0.00
100
90
80
0.6
70
Frequency (MHz)
100
0.7
Inductance (uH)
100
Q value
Inductance (uH)
0.45
10
100.0
MPI2512V2-R47-R
MPI2512V2-R33-R
1
10.0
Frequency (MHz)
Frequency (MHz)
0.1
MPI2510V2-4R7-R
9
1
100.0
Frequency (MHz)
MPI2510V2-3R3-R
0.1
10.0
Q value
1.0
70
0.5
60
0.4
50
40
0.3
Q value
0.1
25
3.0
5
0.0
30
3.5
Inductance (uH)
15
Q value
35
4.0
25
2.0
40
4.5
30
2.5
Inductance (uH)
5.0
35
Q value
3.0
30
0.2
10
1
10
100
Frequency (MHz)
7
MPI25-V2
Effective July 2018
MPI2512V2-R68-R
50
1.6
60
1.4
50
0.6
40
30
0.4
Inductance (uH)
0.8
Q value
Inductance (uH)
60
1.8
70
1.0
MPI2512V2-1R0-R
2.0
80
40
1.2
1.0
30
0.8
0.4
10
0.0
0.1
1
10
100
Q value
1.2
10
0.2
0.0
0.1
1
Frequency
10 (MHz)
100
Frequency (MHz)
45
45
4
40
40
3.5
35
3
30
2.5
25
2
15
1
10
35
1.5
30
25
Q value
15
10
0.5
1
10
100
5
0.5
0.1
1
MPI2512V2-3R3-R
8
10
35
9
15
3
10
5
1
Frequency (MHz)
100
Inductance (uH)
25
5
35
30
8
30
6
2
8
40
Q value
Inductance (uH)
7
10
MPI2512V2-4R7-R
9
1
100
Frequency (MHz)
Frequency (MHz)
0.1
10
25
7
6
15
4
3
10
2
5
1
1
10
Frequency (MHz)
100
Q value
Inductance (uH)
2
50
Inductance (uH)
2.5
4.5
Q value
MPI2512V2-2R2-R
MPI2512V2-1R5-R
MPI25-V2
Effective July 2018
Inductance and temperature rise vs. Current
MPI2510V2-R33-R
MPI2510V2-R47-R
0.5
60
0.20
50
0.15
40
30
0.10
Inductance (uH)
70
0.25
Temperature rise (°C)
80
0.30
100
90
90
0.35
80
70
0.4
60
0.3
50
40
0.2
30
10
10
0.00
0.0
2
3
4
5
6
7
1
2
3
0.8
100
0.7
90
90
0.4
50
0.3
40
30
0.2
10
0.0
5
Inductance (uH)
60
100
1.0
Inductance (uH)
70
0.5
3
80
70
0.8
60
0.6
50
40
0.4
30
10
0.0
1
2
MPI2510V2-1R5-R
100
1.4
90
1.0
60
0.8
50
0.6
40
30
0.4
10
0.0
4
5
2.0
Inductance (uH)
70
100
90
Inductance (uH)
1.2
Idc (A)
5
2.5
80
2
4
MPI2510V2-2R2-R
1.6
1
3
Idc (A)
Idc (A)
1.2
80
0.6
2
7
MPI2510V2-1R0-R
MPI2510V2-R68-R
1
6
Idc (A)
Idc (A)
4
70
1.5
60
50
1.0
40
30
Inductance (uH)
0.6
100
0.40
10
1
1.5
2
2.5
3
3.5
4
Idc (A)
9
MPI25-V2
Effective July 2018
2.5
5.0
100
90
4.5
90
80
4.0
80
3.5
70
3.0
60
2.5
50
2.0
40
1.5
30
0.5
10
70
60
2.0
50
1.5
40
30
1.0
0.5
0.0
1
1.5
2
2.5
3
Idc (A)
90
0.25
70
60
0.20
50
0.15
40
30
0.10
10
0.00
4
5
6
7
Inductance (uH)
80
Inductance (uH)
0.30
2
0.50
100
0.45
90
0.40
80
0.35
70
0.30
60
0.25
50
0.20
40
0.15
30
0.10
10
0.00
8
Idc (A)
1
2
3
80
Inductance (uH)
0.6
70
0.5
60
0.4
50
0.3
40
30
0.2
10
0.0
Idc (A)
10
7
8
5
6
7
100
90
1.0
Inductance (uH)
0.7
90
3
6
1.2
100
2
5
MPI2512V2-1R0-R
MPI2512V2-R68-R
1
4
Idc (A)
0.8
MPI2512V2-R47-R
100
0.35
1
2
Idc (A)
MPI2512V2-R33-R
1
0.5
80
70
0.8
60
0.6
50
40
0.4
30
10
0.0
2
3
Idc (A)
4
5
6
Inductance (uH)
Inductance (uH)
3.0
100
3.5
MPI2510V2-4R7-R
MPI2510V2-3R3-R
MPI25-V2
Effective July 2018
MPI2512V2-1R5-R
MPI2512V2-2R2-R
100
90
90
1.4
2.0
60
0.8
50
40
0.6
30
0.4
80
70
Inductance (uH)
70
1.0
80
1.2
1.5
60
50
1.0
40
30
0.5
0.0
10
2
3
4
0.0
5
1
1.5
2
Idc (A)
3
3.5
4
Idc (A)
MPI2512V2-3R3-R
3.5
MPI2512V2-4R7-R
100
6.0
100
90
3.0
90
5.0
2.5
70
60
2.0
50
1.5
40
30
1.0
10
0.0
1
1.5
2
Idc (A)
2.5
3
3.5
4
Inductance (uH)
80
Inductance (uH)
2.5
80
70
4.0
60
3.0
50
40
2.0
30
Inductance (uH)
2.5
100
1.6
10
0.0
1
1.5
2
2.5
Idc (A)
11
MPI25-V2
Technical Data 10650
Effective July 2018
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“MPI2512V2-1R0-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+7.777363000+1.00670
- 6000+7.336056000+0.94958
- 9000+7.245009000+0.93779
- 国内价格 香港价格
- 1+12.639121+1.63601
- 10+10.3987010+1.34601
- 100+8.55091100+1.10683
- 1000+7.231401000+0.93603
