SLQ40407A-1R2MHF
SLQ40407A-1R2MHF
    ITG
    SMD
    固定电感器 SMD-2 1.2µH ±20% 31A 0.73mΩ
SLQ40407A-1R2MHF 数据手册
A B D C 1. Mechanical Dimensions (in mm): E 2. Electrical Characteristics (Ta=25℃): 1> Open Circuit Inductance (OCL) :1.2uH±20% at 500KHz, 0.25Vrms, 0Adc, at 25℃. 2> Isat1 @25℃: 13.5A, Isat2 @75℃: 12.0A, Isat3 @100℃: 11.0A,DC current that will cause 1 inductance to drop approximately by 20%. 1 3> L @ Isat: 0.86uH Min. at Isat1=13.5A. 4> Irms: 31.0A , DC current that causes an approximate temperature rise (△T) of 40℃. 5> DCR: 0.73mΩ Typical, 0.85mΩ Max. (Ta=25℃). 3. Inductance Characteristics (Inductance vs. Current): A 2 10.6 B 5.2 25C 2.9x2 1200.0 L (nH) White Label Suggested Pad Layout b E 0.0 2.0 4.0 6.0 8.0 10.0 12.0 14.0 16.0 Direct Current (A) A B C E F G 10.00 7.00 10.00 4.80 2.50 2.00 ± ± ± Max. Max. Max. 0.30 0.20 0.30 mm mm mm mm mm mm NOTES: 1>. Reel Qty: 500 pcs / Reel. 2>. Operating temperature: -55℃ to + 130℃ . 4 3>. Operating frequency up to 5.0 MHz application. 4>. Rohs and HF Compliance Component. 5>. Storage conditions: -40℃~85℃ ,75%RH (Max.). REVISION HISTORY DATE DESCRIPTION APPROVED A.0 9/23/2019 New Eva Zhong UNLESS OTHERWISE SPECIFIED ITG Electronics, Inc. DIMENSIONS ARE IN mm. SLQ40407A-1R2MHF TOLERANCES 2PL ± 0.50 5 DWG. NO. Third Angle Projection REV. A.0 SLQ40407A-1R2MHF SCALE: 1/1 B C 5 Ind, 1.2uH, 13.5A,0.73mΩ DCR 3PL ± 0.35 A 3 0.0 F G 4 100C C Coplanarity:0.1mm Max. a 75C 600.0 S40407 1R2MA ITGYYWW 3 2 SLQ40407A-1R2MHF 1800.0 D SHEET 1 OF 1 E Due to continuous product improvement ,all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
SLQ40407A-1R2MHF 价格&库存
很抱歉,暂时无法提供与“SLQ40407A-1R2MHF”相匹配的价格&库存,您可以联系我们找货
