Technical Data 10227
Effective September 2017
Supersedes April 2014
FP1108R
High frequency, high current power inductors
Applications
Multi-phase regulators
Voltage Regulator Modules (VRMs)
Desktop and server VRMs and EVRDs
Notebook and laptop regulators
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Load modules
DCR Sensing circuits
Environmental data
Product features
11.0 mm x 8.0 mm x 7.5 mm surface mount
package
Ferrite core material
Tight tolerance DCR for sensing circuits
Inductance range from 100 nH to 210 nH
Current range from 55 A to 100+ A
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Product specifications
OCL1
(nH) ±10%
FLL min.2
(nH)
FP1108R1-R10-R
100
81
FP1108R1-R15-R
150
110
Part Number9
FP1108R1-R18-R
180
132
FP1108R1-R21-R
210
151
Irms3
(A)
Isat14
(A)
100+
Isat25
(A)
Isat36
(A)
Isat47
(A)
96
94
90
77
72
66
63
65
65
61
58
50
55
51
48
45
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms,
0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.1 Vrms, Isat1, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core
loss. Derating is necessary for AC currents. PCB layout, trace thickness and
width, air-flow, and proximity of other heat generating components will affect
the temperature rise. It is recommended that the temperature of the part not
exceed +125 °C under worst case operating conditions verified in the end
application.
4. Isat1 : Peak current for approximately 20% (R10 10%) rolloff @
+25 °C (R10 10%)
5. Isat2: Peak current for approximately 20% (R10 10%) rolloff @ +85 °C
DCR
(mΩ) @ +20 °C
330
0.29±5%
FP1108R1
xxx
wwllyy R
0.2
typ.
10.7
±0.3
A
Front View
7.5
max
Schematic
2.1
±0.2
B
6.7
typ.
11.4
2.0
±0.2
3.10 (2x)
2.50 (2x)
DCR measured from point “A” to point “B”
Part marking: FP1108R1 (Product code and size), xxx = Inductance value in µH, wwllyy= date code, R= revision level
Tolerances are ±0.15 millimeters unless stated otherwise
PCB tolerances are ±0.1millimeters unless otherwise specified.
All soldering surfaces to be be coplanar within 0.1 millimeters.
Termination finish: matte Sn with Ni underplate
Do not route traces or vias underneath inductor
Packaging information - mm
1.5 dia
1.75
A
4.0
11.5
2.0
24
±0.3
FP1108R1
xxx
11.2
wwllyy R
16.0
A
1.5 dia
User Direction of Feed
Supplied in tape and reel packaging, 500 parts per 13” diameter reel,
2
www.eaton.com/electronics
330
6. Isat3 : Peak current for approximately 20% (R10 10%) rolloff @ +100 °C
7. Isat4: Peak current for approximately 20% (R10 10%) rolloff @ +125 °C
8. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I.
Bp-p:(Gauss), K: (K-factor from table), L: (Inductance in µH),
∆I (peak to peak ripple current in amps).
9. Part Number Definition: FP1108Rx-yyy-R
- FP1108Rx = Product code and size
- Rx = DCR indicator
- yyy= Inductance value in µH
- “-R” suffix = RoHS compliant
Recommended Pad Layout
Bottom View
Side View
330
330
Dimensions - mm
Top View
7.7
+0.3/-0.2
K-factor8
8.2
7.7
Section A-A
FP1108R
Temperature rise vs total loss
60
Temperature Rise (°C)
50
40
30
0.5
1.0
1.5
2.0
2.5
Total Loss (W)
Core loss vs Bp-p
Core Loss vs. Bp-p
10
Core Loss (W)
1
0.1
0.01
0.001
100
10,000
1000
B p-p (Gauss)
Inductance characteristics
% of OCL vs % of Isat1
100%
% of OCL
80%
-40° C
60%
+125° C
40%
+100° C
+85° C
+25° C
20%
0%
0%
20%
40%
60%
80%
100%
120%
140%
% of Isat1
3
FP1108R
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 10224 BU-SB14230
September 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“FP1108R1-R18-R”相匹配的价格&库存,您可以联系我们找货
