HCM1A1104V2-R47-R
HCM1A1104V2-R47-R
    EATON(伊顿)
    SMD,10.8x10mm
    固定电感器 Nonstandard 470nH ±20% 25A 1.27mΩ 73MHz
HCM1A1104V2-R47-R 数据手册
Technical Data 10903 Effective April 2019 HCM1A1104V2 Automotive grade high current power inductors Applications • • Product features • AEC-Q200 qualified • High current carrying capacity • Magnetically shielded, low EMI • DC-DC converter applications up to 1 MHz • Filtering applications up to Self Resonant Frequency (SRF) [See product specification table] • Body electronics • Central body control module • Vehicle access control system • Headlamps, tail lamps and interior lighting and LED lighting • Heating ventilation and air conditioning controllers (HVAC) • Doors, window lift and seat control Advanced driver assistance systems • Adaptive cruise control (ACC) • Automatic parking control • Collision avoidance system/ Car black box system Infotainment and cluster electronics • Audio subsystem: head unit and trunk amp • Digital instrument cluster • In-vehicle infotainment (IVI) and navigation • Port power/USB HUB for front and rear passengers • Inductance range from 0.20 μH to 68 μH Chassis and safety electronics • Airbag control unit • Current range from 2.2 A to 60 A • Electronic stability control system (ESC) • 11.2 mm x 10.3 mm footprint surface mount package in a 4.0 mm height • Electric parking brake • • Moisture Sensitivity Level (MSL): 1 Engine and Powertrain Systems • Electric pumps, motor control and auxiliaries • Alloy powder core material • Powertrain control module (PCU)/ Engine Control unit (ECU) • Transmission Control Unit (TCU) • Environmental data • Storage temperature range (Component): -55 °C to +155 °C • Operating temperature range: -55 °C to +155 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE HCM1A1104V2 Automotive grade high current power inductors  Technical Data 10903 Effective April 2019 Product specifications Part number6 OCL1 (μH) ± 20% FLL2 (μH) minimum Irms3 (A) Isat4 (A) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C SRF (MHz) typical K-factor5 HCM1A1104V2-R20-R 0.20 0.13 43 60 0.63 0.72 150 726 HCM1A1104V2-R36-R 0.36 0.23 26 33 1.04 1.20 80 493 HCM1A1104V2-R45-R 0.45 0.29 25 40 1.07 1.23 85 450 HCM1A1104V2-R47-R 0.47 0.30 25 35 1.10 1.27 73 450 HCM1A1104V2-R56-R 0.56 0.36 22.5 24 1.56 1.80 62 469 HCM1A1104V2-R90-R 0.90 0.58 20 22 2.17 2.5 49 361 HCM1A1104V2-1R0-R 1.0 0.64 19 25 2.7 3.1 38 303 HCM1A1104V2-1R5-R 1.5 0.96 14 22 3.8 4.2 33 281 HCM1A1104V2-2R2-R 2.2 1.41 10.5 16 6.0 7.0 25 432 HCM1A1104V2-3R3-R 3.3 2.11 8.2 11.5 9.9 11.4 19 215 HCM1A1104V2-4R7-R 4.7 3.01 8.0 10.8 13.2 15 15 309 HCM1A1104V2-5R6-R 5.6 3.58 7.5 9.0 14 17 14 160 HCM1A1104V2-6R8-R 6.8 4.35 6.4 9.0 16 19 12 149 HCM1A1104V2-100-R 10 6.40 6.0 6.0 27 30 10 131 HCM1A1104V2-150-R 15 9.60 4.7 4.6 40 45 6.8 132 HCM1A1104V2-220-R 22 14.1 3.8 4.6 58 65 6.5 77 HCM1A1104V2-330-R 33 21.1 3.3 4.6 89 102 5.0 55 HCM1A1104V2-470-R 47 30.1 2.7 3.6 147 165 3.9 63 HCM1A1104V2-680-R 68 43.5 2.2 3.0 190 210 3.1 39 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C 2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C 3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +155 °C under worst case operating conditions verified in the end application. 4. Isat: Peak current for approximately 20% rolloff @ +25 °C 5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps). 6. Part Number Definition: HCM1A1104V2-xxx-R HCM1A1104V2 = Product code and size xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant Dimensions (mm) Schematic 1 2 Part marking: 1AxxxV2, xxx=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros. xxxx=Lot code All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.3 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise DCR measured from point “a” to point “b” Do not route traces or vias underneath the inductor 2 www.eaton.com/electronics Technical Data 10903 HCM1A1104V2 Automotive grade high current power inductors Effective April 2019  Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 500 parts per 13” diameter reel Core loss vs Bp-p HCM1A1104V2-R20-R HCM1A1104V2-R36-R 700 kHz 500 kHz 300 kHz 1000 700 kHz 500 kHz 300 kHz 100 100 kHz 50 kHz 100 100 kHz 50 kHz Core Loss (mW) Core Loss (mW) 1000 10 1 0.1 0.01 10 1 0.1 100 0.01 1000 Bp-p (Gauss) HCM1A1104V2-R47-R HCM1A1104V2-R45-R 1000 700 kHz 500 kHz 300 kHz 1000 700 kHz 500 kHz 300 kHz 100 100 kHz 100 100 kHz 50 kHz 50 kHz Core Loss (mW) Core Loss (mW) 1000 100 Bp-p (Gauss) 10 1 1 0.1 0.1 0.01 10 0.01 100 1000 Bp-p (Gauss) 100 1000 Bp-p (Gauss) www.eaton.com/electronics 3 HCM1A1104V2 Automotive grade high current power inductors  Technical Data 10903 Effective April 2019 Core loss vs Bp-p HCM1A1104V2-R56-R HCM1A1104V2-R90-R 1000 1000 700 kHz 500 kHz 300 kHz 100 100 kHz 700 kHz 500 kHz 300 kHz 100 100 kHz 10 1 0.1 0.01 50 kHz Core Loss (mW) Core Loss (mW) 50 kHz 10 1 0.1 100 0.01 1000 1000 100 Bp-p (Gauss) Bp-p (Gauss) HCM1A1104V2-1R0-R HCM1A1104V2-1R5-R 1000 700 kHz 500 kHz 300 kHz 1000 100 100 kHz 100 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz Core Loss (mW) Core Loss (mW) 50 kHz 10 1 0.1 0.01 10 1 0.1 100 0.01 1000 100 Bp-p (Gauss) HCM1A1104V2-3R3-R HCM1A1104V2-2R2-R 1000 1000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 10 1 100 kHz 50 kHz 10 1 0.1 0.1 0.01 100 1000 Bp-p (Gauss) 4 700 kHz 500 kHz 300 kHz 100 Core Loss (mW) Core Loss (mW) 100 0.01 1000 Bp-p (Gauss) www.eaton.com/electronics 1000 100 Bp-p (Gauss) Technical Data 10903 HCM1A1104V2 Automotive grade high current power inductors Effective April 2019  Core loss vs Bp-p HCM1A1104V2-4R7-R HCM1A1104V2-5R6-R 1000 1000 700 kHz 500 kHz 300 kHz Core Loss (mW) 100 kHz 50 kHz 10 1 0.1 0.01 100 Core Loss (mW) 100 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 10 1 0.1 100 0.01 1000 1000 100 Bp-p (Gauss) Bp-p (Gauss) HCM1A1104V2-100-R HCM1A1104V2-6R8-R 1000 1000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 10 1 100 Core Loss (mW) Core Loss (mW) 100 100 kHz 50 kHz 10 1 0.1 0.1 0.01 700 kHz 500 kHz 300 kHz 0.01 100 1000 Bp-p (Gauss) HCM1A1104V2-150-R HCM1A1104V2-220-R 1000 1000 700 kHz 500 kHz 300 kHz 100 kHz 50 kHz 10 1 0.1 700 kHz 500 kHz 300 kHz 100 Core Loss (mW) Core Loss (mW) 100 0.01 1000 100 Bp-p (Gauss) 100 kHz 50 kHz 10 1 0.1 100 1000 Bp-p (Gauss) 0.01 1000 100 Bp-p (Gauss) www.eaton.com/electronics 5 HCM1A1104V2 Automotive grade high current power inductors  Technical Data 10903 Effective April 2019 Core loss vs Bp-p HC1A1104V2-330-R HCM1A1104V2-470-R 1000 100 700 kHz 500 kHz 300 kHz 1000 100 kHz 100 700 kHz 500 kHz 300 kHz 100 kHz Core Loss (mW) Core Loss (mW) 50 kHz 10 1 0.1 0.01 100 0.01 1000 1000 700 kHz 500 kHz 300 kHz 100 100 kHz 50 kHz 10 1 0.1 0.01 100 1000 Bp-p (Gauss) www.eaton.com/electronics 1000 100 Bp-p (Gauss) HCM1A1104V2-680-R Core Loss (mW) 1 0.1 Bp-p (Gauss) 6 50 kHz 10 Technical Data 10903 HCM1A1104V2 Automotive grade high current power inductors Effective April 2019  Inductance and impedance vs. frequency HCM1A1104V2-R36-R HCM1A1104V2-R20-R 0.9 1000 0.35 0.8 0.3 10 0.15 0.1 Impedance 100 0.5 Inductance 0.4 0.3 10 0.2 1 Impedance 0.1 0.05 0.1 1 10 0 0.1 100 0.1 1 10 100 1 Frequency (MHz) Frequency (MHz) HCM1A1104V2-R47-R HCM1A1104V2-R45-R 1.2 1000 1 0.9 1000 1 100 10 0.5 Inductance 0.4 0.3 0.6 10 Inductance 0.4 1 1 Impedance 0.2 0.8 OCL (uH) 0.6 Impedance (Ω) 100 0.7 Impedance (Ω) 0.8 OCL (uH) Impedance (Ω) 0.2 OCL (uH) 0.6 Inductance Impedance (Ω) OCL (uH) 0.7 100 0.25 0 1000 Impedance 0.2 0.1 0.1 1 10 100 0 0.1 0.1 1 HCM1A1104V2-R56-R 3.5 1.6 1000 100 1 0.8 10 Inductance 0.6 OCL (uH) 2.5 Impedance (Ω) OCL (uH) 10000 3 1000 1.2 2 100 Impedance 1.5 10 1 0.4 0.1 Inductance 1 Impedance 0.2 0 0.1 HCM1A1104V2-R90-R 10000 1.4 100 Frequency (MHz) Frequency (MHz) 1.8 10 Impedance (Ω) 0 1 0.5 1 10 Frequency (MHz) 100 0.1 0 0.1 1 10 100 0.1 Frequency (MHz) www.eaton.com/electronics 7 HCM1A1104V2 Automotive grade high current power inductors  Technical Data 10903 Effective April 2019 Inductance and impedance vs. frequency HCM1A1104V2-1R5-R HCM1A1104V2-1R0-R 4.5 9 10000 8 4 1000 100 Impedance 2 10 1.5 1 Inductance 5 100 4 Impedance 3 10 2 1 Inductance 1 0.5 0.1 1 10 100 0 0.1 0.1 1 10 HCM1A1104V2-3R3-R HCM1A1104V2-2R2-R 14 30 10000 12 8 100 Impedance 6 4 OCL (uH) 20 15 10 10 10 5 2 Inductance 0.1 1 Inductance 10 100 0 1 0.1 1 1 100 HCM1A1104V2-5R6-R HCM1A1104V2-4R7-R 35 40 10000 10000 35 30 100 Impedance 15 10 10 5 Impedance 20 1 10 Frequency (MHz) www.eaton.com/electronics 100 1 100 15 10 10 5 Inductance 0.1 1000 25 OCL (uH) 20 Impedance (Ω) 1000 25 0 Inductance 0.1 1 10 Frequency (MHz) 100 1 Impedance (Ω) 30 0 10 Frequency (MHz) Frequency (MHz) OCL (uH) 100 Impedance Impedance (Ω) 1000 1000 Impedance (Ω) OCL (uH) 10000 25 10 8 1 100 Frequency (MHz) Frequency (MHz) 0 Impedance (Ω) 2.5 1000 6 OCL (uH) OCL (uH) 3 7 Impedance (Ω) 3.5 0 10000 Technical Data 10903 HCM1A1104V2 Automotive grade high current power inductors Effective April 2019  Inductance and impedance vs. frequency HCM1A1104V2-100-R HCM1A1104V2-6R8-R 60 100000 100 10000 90 50 20 10 Impedance 40 10 10 10 100 0 1 Inductance 0.1 1 10 Frequency (MHz) Frequency (MHz) HCM1A1104V2-220-R HCM1A1104V2-150-R 140 250 100000 120 1000 60 Impedance 100 OCL (uH) 80 Impedance (Ω) OCL (uH) 100 100000 200 10000 40 1 100 10000 150 1000 100 Impedance Impedance (Ω) 1 100 20 Inductance 0.1 50 30 10 0 1000 60 Impedance (Ω) 100 OCL (uH) Impedance 30 70 Impedance (Ω) OCL (uH) 40 10000 80 1000 100 50 20 Inductance 0.1 1 10 100 0 10 Inductance 0.1 10 100 10 Frequency (MHz) Frequency (MHz) HCM1A1104V2-470-R HCM1A1104V2-330-R 300 350 100000 100000 300 250 10000 1000 Impedance 100 OCL (uH) 150 10000 250 Impedance (Ω) 200 OCL (uH) 1 200 1000 150 Impedance 100 100 100 50 50 Inductance 0 0.1 1 10 Frequency (MHz) 100 10 0 Impedance (Ω) 0 Inductance 0.1 1 10 100 10 Frequency (MHz) www.eaton.com/electronics 9 HCM1A1104V2 Automotive grade high current power inductors  Technical Data 10903 Effective April 2019 Inductance and impedance vs. frequency HCM1A1104V2-680-R 700 100000 600 OCL (uH) 400 1000 300 Impedance 200 Impedance (Ω) 10000 500 100 100 Inductance 0 0.1 1 10 100 10 Frequency (MHz) Inductance and temperature rise vs. current HCM1A1104V2-R20-R HCM1A1104V2-R36-R 100 0.40 90 0.15 60 50 0.10 40 30 Temperature rise 0.05 0 10 20 30 40 Idc (A) 10 www.eaton.com/electronics 50 60 20 70 80 90 80 0.30 70 0.25 OCL (uH) OCL (uH) 70 0.00 0.35 80 Inductance Temperature rise (°C) 0.20 100 Inductance 60 0.20 50 40 0.15 30 0.10 10 0.05 0 0.00 Temperature rise 20 10 0 10 20 30 Idc (A) 40 50 0 Temperature Rise (°C) 0.25 Technical Data 10903 HCM1A1104V2 Automotive grade high current power inductors Effective April 2019  Inductance and temperature rise vs. current HCM1A1104V2-R47-R 100 Inductance 70 0.30 60 0.25 50 0.20 40 Temperature rise 30 0.10 10 0.00 0 0 10 20 30 40 50 60 0.40 80 0.35 70 0.30 60 0.25 50 0.20 40 0.15 30 Temperature rise 0.10 20 0.05 90 0.00 10 0 10 20 30 Inductance 60 0.3 50 40 0.2 30 Temperture rise 20 10 15 20 25 30 35 40 OCL (uH) 70 0.4 OCL (uH) Temperature Rise (°C) 80 10 0.8 80 0.7 70 0.6 60 0.5 50 0.4 40 Temperature rise 0.3 20 0.1 10 0 5 10 15 1.4 70 1.2 60 0.6 50 40 0.4 30 20 Temperature rise 10 15 20 Idc (A) 25 30 35 0 OCL (uH) 80 Temperature rise (°C) OCL (uH) 0.8 10 35 0 100 90 1.6 90 Inductance 5 30 1.8 100 0 25 HCM1A1104V2-1R5-R 1.2 0.0 20 Idc (A) HCM1A1104V2-1R0-R 0.2 30 0.2 0.0 0 90 Inductance Idc (A) 1.0 0 100 0.9 90 0.5 5 60 1.0 100 0 50 HCM1A1104V2-R90-R HCM1A1104V2-R56-R 0.6 0.0 40 Isat (A) Idc (A) 0.1 20 0.05 Temperature Rise (°C) 0.15 OCL (uH) Temperature Rise (°C) 80 0.35 OCL (uH) 0.45 90 0.40 100 Inductance Inductance 80 70 60 1.0 50 0.8 40 0.6 30 Temperature rise 0.4 20 0.2 0.0 Temperature Rise (°C) 0.45 0.50 Temperature Rise (°C) HCM1A1104V2-R45-R 10 0 5 10 15 20 25 30 35 0 Idc (A) www.eaton.com/electronics 11 HCM1A1104V2 Automotive grade high current power inductors  Technical Data 10903 Effective April 2019 Inductance and temperature rise vs. current HCM1A1104V2-3R3-R Inductance 4.0 90 3.5 80 1.5 60 50 1.0 40 30 60 2.0 50 40 1.5 30 1.0 10 15 20 0.0 0 10 0 2 4 6 Idc (A) 3.0 60 2.5 50 2.0 40 1.5 30 20 Temperature rise 90 80 70 60 3.0 50 40 2.0 30 Temperature rise 20 1.0 10 10 0 2 4 6 8 10 12 14 0.0 0 0 2 4 6 HCM1A1104V2-6R8-R 8 5 60 4 50 40 3 30 Temperature rise 10 6 www.eaton.com/electronics 8 90 Inductance 80 70 60 6 50 40 4 30 20 1 Idc (A) 0 8 OCL (uH) 70 Temperature Rise (°C) 6 4 14 100 10 80 2 12 12 90 Inductance 0 10 HCM1A1104V2-100-R 100 2 8 Idc (A) Idc (A) 7 0 100 4.0 OCL (uH) 70 OCL (uH) 16 5.0 Temperature Rise (°C) OCL (uH) 3.5 0.5 12 14 Inductance 90 80 0 12 6.0 100 Inductance 4.0 0.0 10 HCM1A1104V2-5R6-R 5.0 1.0 8 Idc (A) HCM1A1104V2-4R7-R 4.5 20 Temperature rise Temperature Rise (°C) 5 70 2.5 0.5 10 0 80 20 Temperature rise 0.0 90 Inductance 10 12 20 Temperature rise 2 10 0 0       Idc (A)      0 Temperature Rise (°C) 0.5 100 3.0 OCL (uH) OCL (uH) 70 Temperature Rise (°C) 2.0 100 Temperature Rise (eC) HCM1A1104V2-2R2-R 2.5 Technical Data 10903 HCM1A1104V2 Automotive grade high current power inductors Effective April 2019  Inductance and temperature rise vs. current HCM1A1104V2-150-R 100 16 90 Inductance Temperature Rise (°C) 50 8 40 6 30 4 15 50 10 40 5 1 2 3 4 5 6 7 8 10 0 0 60 20 50 15 40 30 10 20 Temperature rise 2 3 5 6 7 0 5 6 90 Inductance 40 80 35 70 30 60 25 50 20 40 15 30 10 20 Temperature rise 5 10 4 OCL (uH) 70 Temperature Rise (°C) 80 1 4 100 45 90 Inductance 0 3 50 100 25 0 2 HCM1A1104V2-470-R 35 5 1 Idc (A) HCM1A1104V2-330-R 30 0 0 0 Temperature rise (°C) 0 20 Temperature rise 10 Idc (A) OCL (uH) 60 30 20 Temperature rise 2 80 70 OCL (uH) OCL (uH) 60 10 90 20 70 12 100 Inductance 80 14 0 HCM1A1104V2-220-R 25 Temperature Rise (°C) 18 10 0 1 2 3 4 5 0 Idc (A) HCM1A1104V2-680-R 80 100 90 Inductance 80 60 70 OCL (uH) 50 60 40 50 40 30 30 20 20 10 0 Temperature rise (°C) 70 Temperature rise 0 0.5 1 1.5 2 2.5 10 3 3.5 4 0 Idc (A) www.eaton.com/electronics 13 Technical Data 10903 HCM1A1104V2 Automotive grade high current power inductors  Effective April 2019 Solder reflow profile TP TC -5 °C tP Max. ramp up rate = 3 °C/s Max. ramp down rate = 6 °C/s Temperature TL Preheat A T smax Package thickness Volume mm3
HCM1A1104V2-R47-R 价格&库存
很抱歉,暂时无法提供与“HCM1A1104V2-R47-R”相匹配的价格&库存,您可以联系我们找货
HCM1A1104V2-R47-R
    HCM1A1104V2-R47-R
    • 1+13.236011+1.71238
    库存:9
