Technical Data 4144
Effective August 2017
Supersedes November 2011
SD6020
Low profile shielded drum core power inductors
Applications
Notebook, laptop computers
Digital cameras
LED Drivers
TFT LCD Bias supplies
Wireless handsets,
Handheld instruments
Gaming consoles
GPS devices
Battery backup/power
DC-DC Converters,
Buck-boost regulators
Product features
Low profile surface mount shielded drum core
inductors
6.0 mm x 6.0 mm x 2.0 mm surface mount
package
Ferrite core material
Inductance range from 1.99 uH to 100 uH
Current range from 0.36 A to 4.2 A
Frequency range up to 1 MHz
Environmental data
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4144
Product specifications
Part Number5
SD6020-2R2-R
SD6020-4R1-R
SD6020-5R4-R
SD6020-6R2-R
SD6020-8R9-R
SD6020-100-R
SD6020-120-R
SD6020-150-R
SD6020-180-R
SD6020-220-R
SD6020-270-R
SD6020-330-R
SD6020-390-R
SD6020-470-R
SD6020-560-R
SD6020-680-R
SD6020-820-R
SD6020-101-R
OCL1 µH ± 30%
1.99
3.9
5.5
6.5
8.5
9.7
11
13
16
29
37
45
55
68
80
94
Irms2 (A)
4.2
2.22
1.80
1.63
1.47
1.39
1.31
1.07
1.10
0.94
0.82
0.76
0.63
0.61
0.57
0.50
0.48
0.42
Typ. DCR mΩ @ +20 °C
30.0
47.5
63.3
80.0
96.7
103.3
115.0
163.3
175.0
241.7
275.0
320.8
416.7
495.8
515.0
700.0
815.0
1000.0
Isat3 (A)
2.2
1.95
1.60
1.40
1.25
1.20
1.10
0.97
0.85
0.80
0.75
0.65
0.57
0.54
0.50
0.43
0.41
0.36
1 Open Circuit Inductance Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc.
2 Irms: DC current for an approximate ΔT of 40 °C without core loss. Derating is necessary for AC
currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating
components will affect the temperature rise. It is recommended that the temperature of the part
not exceed +125 °C under worst case operating conditions verified in the end application.
3 Isat Amps peak for 35% rolloff (@ +25 °C)
Max DCR mΩ @ +20 °C
36.0
57.0
76.0
96.0
116.0
124.0
138.0
196.0
210.0
290.0
330.0
385.0
500.0
595.0
618.0
840.0
978.0
1200.0
K-factor4
40.0
28.5
24.0
22.2
19.3
18.1
17.1
15.4
13.9
12.7
10.9
10.5
9.2
8.2
7.8
6.7
6.3
5.8
4 K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K*L*ΔI, B p-p(mT), K: (K factor from table), L: (Inductance in μH),
ΔI (Peak-to-peak ripple current in Amps).
5 Part Number Definition: SD6020-xxx-R
SD6020 = Product code and size; -xxx = Inductance value in μH;
R = decimal point; If no R is present, third character equals
number of zeros. -R suffix = RoHS compliant
Dimensions-mm
BOTTOM VIEW
TOP VIEW
SCHEMATI C
RECOMMENDED PCB LAYOUT
FRONT VIEW
6.0 max.
6.3
2.0 max.
1
2.2
2.0 5.5
XXX
wwlly R
6.0 max.
2
2
2
5.5
xxx = Inductance value in uH. R = decimal point. If no R is present third character = #of zeros, wwlly or wwllyy = Date code, R = Revision level.
Do not route traces or vias underneath the inductor.
Packaging information-mm
Parts packaged on 13" Diameter reel, 2,600 parts per reel.
2
www.eaton.com/electronics
1
LEFT VIEW
SD6020
Technical Data 4144
Core loss vs Bp-p
500kHz
1MHz
1
300kHz
200kHz
100kHz
Core Loss (W)
0.1
0.01
0.001
0.0001
1
10
100
1000
B p-p (mT)
Temperature rise vs total loss
160.00
140.00
Te mpe rat ur e Rise (°C)
120.00
100.00
80.00
60.00
40.00
20.00
0.00
0.00
0.10
0.20
0.30
0.40
0.50
0.60
0.70
0.80
0.90
1.00
Total Loss (W)
Inductance characteristics
OCL Vs. I sat
120%
100%
% of OC
80%
-40°C
+25°C
60%
40%
+85°C
20%
0%
0%
20%
40%
60%
80%
100%
120%
% of I sat
3
SD6020
Technical Data 4144
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4144 BU-SB111169
August 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“SD6020-100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2600+9.112392600+1.14271
- 国内价格 香港价格
- 1+17.989671+2.25594
- 10+14.7617610+1.85116
- 100+12.14105100+1.52251
- 1000+11.153561000+1.39868
