PL8907
PL8907
    INRCORE
    固定电感器 Nonstandard 7.6µH ±30% 5.5A 18.5mΩ
PL8907 数据手册
SMT POWER INDUCTORS Shielded Drum Core - PL89XX Series Ruggedized Inductance Range: 0.8µH to 54.4µH Current Rating: up to 11A Height: 7.1mm Max Footprint: 10.5mm x 10.5mm Max Moisture Sensitivity Level: 1 Electrical Specifications @ 25 °C — Operating Temperature - 40 °C to +130 °C Saturation 3 Part Inductance @0ADC Irated 2 Inductance @Irated DCR (mΩ) Heating 4 Current Current (A) Numbers TYP MAX (µH TYP) (µH) (A) @25°C (A) 0.80 11 3.5 4.0 1.0* 14 11 PL8901 1.20 10 4.3 6.0 1.5* 13 10 PL8902 2.1 9.0 5.1 7.3 2.7* 11 9 PL8903 2.9 8.0 6.9 8.5 3.7* 9.2 8 PL8904 3.7 7.3 7.9 9.5 4.7* 8.2 7.3 PL8905 4.8 6.0 10.9 16.5 6.0* 6.9 6.0 PL8906 6 5.5 14.8 18.5 7.6* 6.2 5.5 PL8907 8 5.0 16.7 21.8 10 5.5 5.0 PL8908 9.6 4.5 18.1 29.0 12 5.1 4.5 PL8909 12 4.1 21.2 35.4 15 4.4 4.1 PL8910 14.4 4.0 27.9 37.0 18 4.3 4.0 PL8911 17.6 3.8 29.8 42.0 22 3.8 3.8 PL8912 21.6 3.4 40.9 45.9 27 3.4 3.4 PL8913 26.4 3.0 43.1 64.8 33 3.0 3.1 PL8914 31.2 2.7 60.8 81.5 39 2.8 2.7 PL8915 37.6 2.6 67.1 89.0 47 2.6 2.6 PL8916 54.4 2.1 103.6 135.0 68 2.1 2.1 PL8917 *Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts. NOTES FROM TABLE: (See back page) Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL8901 becomes PL8901T). Mechanical 1 www.inrcore.com Electrical Schematic M117.C (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL89XX Series Ruggedized Notes for tables: Percentage of the intitial inductance� 4. The heating current is the DC current, which causes the temperature of the part to increase 1. Temperature of the component (ambient plus temperature rise) must be by approximately 40°C. This current is determined by extending the within specified operating temperature range. terminals of the component with 30mm length 28 gauge buss wires and 2. The rated current as listed is either the saturation current or the heating applying the current to the device for 30 minutes. The temperature is current depending on which value is lower. measured by placing the thermo-couple between the winding and the 3. The saturation current is the current which causes the inductance to drop shield. to 75% of its initial inductance at zero bias. This current is determined 5. In high volt*time applications, additional heating in the component can by placing the component at room ambient (25°C), and applying a occur due to core losses in the inductor which may necessitate derating short duration pulse current (to eliminate self-heating effects) to the the current in order to limit the temperature rise of the compo-nent. In component. order to determine the approximate total loss (or temperature rise) for a given application, both copper losses and core losses should be taken into account. Inductance vs. Current Characteristics 120% 100% 80% 60% 40% 20% 0% 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 Normalized Isat 2 www.inrcore.com M117.C (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL89XX Series Ruggedized For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 3 www.inrcore.com M117.C (07/20)
PL8907 价格&库存
很抱歉,暂时无法提供与“PL8907”相匹配的价格&库存,您可以联系我们找货
