1530B334
1530B334
    HAMMONDMANUFACTURING
    插件,D4.1xL6.4mm
    固定电感器 Axial 330µH ±5% 103mA 13.9Ω 41@790KHz
1530B334 数据手册
12/7/2017 Sub- Miniature R.F. Chokes (1530 Series) - Hammond Mfg. Quality Products. Service Excellence. Sub- Miniature R.F. Chokes 1530 Series Features Subminiature design ranging from only .25" to .63" Coils are varnish impregnated. Ideally suited to network, filter, delay lines etc., applications. L and Q values measured on a Q meter. Inductance L uH Induct. Tolerance Q Min. Test Freq. Mhz. Fo Min. Mhz R - D.C. Max. Ohms I - D.C. Max. ma. Coil Dia. Max. Form Length +/.03" Core Material 1530B106 1 +/- 20% 41 25 118 0.048 2041 0.165 0.25 Iron 1530B126 1.2 +/- 10% 45 7.9 118 0.072 1666 0.16 0.25 Iron 1530B156 1.5 +/- 10% 42 7.9 102 0.096 1443 0.16 0.25 Iron 1530B276 2.7 +/- 10% 34 7.9 74 0.168 1091 0.16 0.25 Iron 1530B336 3.3 +/- 10% 40 7.9 66 0.24 912 0.15 0.25 Iron 1530B396 3.9 +/- 10% 35 7.9 61 0.264 870 0.15 0.25 Iron 1530B476 4.7 +/- 10% 43 7.9 53 0.457 661 0.15 0.25 Iron 1530B566 5.6 +/- 10% 41 7.9 49 0.492 637 0.15 0.25 Iron 1530B686 6.8 +/- 10% 40 7.9 49 0.624 566 0.15 0.25 Iron 1530B105 10 +/- 10% 36 7.9 19 1.56 277 0.16 0.25 Iron 1530B155 15 +/- 10% 52 2.5 16 1.92 250 0.165 0.25 Iron 1530B225 22 +/- 5% 51 2.5 13 2.28 229 0.165 0.25 Iron 1530B335 33 +/- 5% 50 2.5 10 2.76 208 0.17 0.25 Iron 1530B395 39 +/- 5% 48 2.5 9.3 3.36 188 0.175 0.25 Iron 1530B475 47 +/- 5% 44 2.5 9.1 3.36 188 0.175 0.25 Iron 1530B565 56 +/- 5% 45 2.5 8.6 3.84 176 0.18 0.25 Iron 1530B685 68 +/- 5% 42 2.5 8.1 4.2 169 0.18 0.25 Iron 1530B825 82 +/- 5% 41 2.5 6.7 4.8 158 0.185 0.25 Iron 1530B104 100 +/- 5% 25 2.5 3.6 7.68 139 0.165 0.25 Iron 1530B154 150 +/- 5% 47 0.79 3 8.16 135 0.165 0.25 Iron 1530B224 220 +/- 5% 46 0.79 2.5 11.5 114 0.17 0.25 Iron 1530B334 330 +/- 5% 41 0.79 2 13.9 103 0.175 0.25 Iron 1530B474 470 +/- 5% 35 0.79 1.8 16.3 95 0.185 0.25 Iron 1530B684 680 +/- 5% 37 0.79 1.6 19.8 87 0.2 0.25 Iron 1530B824 820 +/- 5% 33 0.79 1.6 22.9 80 0.21 0.25 Iron 1530B103 1000 +/- 5% 30 0.79 1.4 24 79 0.225 0.25 Iron 1530B153 1500 +/- 5% 40 0.25 1.1 37.2 63 0.225 0.25 Iron 1530B223 2200 +/- 5% 40 0.25 0.96 45.6 57 0.24 0.25 Iron 1530C253 2500 +/- 5% 48 0.25 0.96 45.6 57 0.26 0.38 Iron 1530C333 3300 +/- 5% 52 0.25 0.8 51.6 53 0.26 0.38 Iron 1530C473 4700 +/- 5% 49 0.25 0.68 64.8 48 0.285 0.38 Iron Part No. https://www.hammfg.com/electronics/transformers/choke/1530 1/2 12/7/2017 Sub- Miniature R.F. Chokes (1530 Series) - Hammond Mfg. Inductance L Induct. Q Test Freq. Fo Min. R - D.C. Max. I - D.C. Max. Coil Dia. Form Length +/- Core uH Tolerance Min. Mhz. Mhz Ohms ma. Max. .03" Material 1530C683 6800 +/- 5% 51 0.25 0.64 78 43 0.31 0.38 Iron 1530C823 8200 +/- 5% 48 0.25 0.6 92.4 40 0.33 0.38 Iron 1530C102 10000 +/- 5% 41 0.25 0.52 101 38 0.335 0.38 Iron 1530C182 18000 +/- 5% 49 0.079 0.29 128 44 0.325 0.50 Iron 1530D252 25000 +/- 5% 59 0.079 0.25 115 46 0.34 0.63 Ferrite 1530D332 33000 +/- 5% 61 0.079 0.232 134 43 0.353 0.63 Ferrite 1530D101 100000 +/- 5% 48 0.079 0.157 278 29 0.446 0.63 Ferrite Part No. Data subject to change without notice © 2017. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/choke/1530 2/2
1530B334 价格&库存
很抱歉,暂时无法提供与“1530B334”相匹配的价格&库存,您可以联系我们找货
1530B334
    • 1+78.66720
    • 200+31.39560
    • 500+30.33720
    • 1000+29.81880
