Technical Data 4141
Effective March 2019
Supersedes September 2017
DR124
High power density, high efficiency, low profile shielded
drum core power inductors
Applications
Notebook power
LCD panels
Desktop and servers
DVD players and portable power devices
DC-DC Converters
Buck, boost, forward, and resonant
converters
Noise filtering and filter chokes
Environmental Data
Product features
Low profile surface mount inductor
12.5 mm x 12.5 mm x 4.5 mm shielded
drum core
Inductance range from 0.47 µH to 1000 µH
Current range from 0.44 A to 24.4 A
Frequency range up to 1 MHz
Ferrite core material
Storage temperature range (Component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
Technical Data 4141
DR124
High power density, high efficiency, low profile shielded drum
Product specifications
Part Number
OCL1
μH±20%
Irms2
(A)
Isat3
(A)
DR124-R47-R
0.47
0.42
16.0
24.40
2.2
2.7
17.51
DR124-1R0-R
1.0
0.83
13.9
18.00
3.00
3.6
12.50
DR124-1R5-R
1.5
1.37
11.1
14.00
4.75
5.7
9.73
DR124-2R2-R
2.2
2.04
9.1
11.45
5.92
7.1
7.96
DR124-3R9-R
3.9
3.80
7.0
8.40
12.50
15.0
5.84
DR124-4R7-R
4.7
4.88
6.5
7.65
13.50
16.2
5.15
DR124-6R8-R
6.8
6.10
5.6
6.47
18.06
21.7
4.61
DR124-8R2-R
8.2
7.45
5.2
6.22
21.67
26.0
4.17
DR124-100-R
10
8.94
4.5
5.80
23.33
28.0
3.81
DR124-120-R
12
11.5
4.1
4.96
31.67
38.0
3.50
DR124-150-R
15
14.2
3.6
4.62
37.30
44.8
3.02
DR124-180-R
18
16.2
3.4
4.32
46.97
56.4
2.82
DR124-220-R
22
20.7
3.2
3.83
53.99
64.8
2.50
DR124-270-R
27
25.7
2.8
3.44
66.67
80.0
2.24
DR124-330-R
33
31.2
2.6
3.12
80.83
97.0
2.04
DR124-390-R
39
37.3
2.3
2.85
110.00
132.0
1.86
DR124-470-R
47
44.0
2.2
2.63
124.66
149.6
1.72
DR124-560-R
56
54.9
2.0
2.35
144.32
173.2
1.54
DR124-680-R
68
67.1
1.8
2.13
183.33
220.0
1.39
DR124-820-R
82
80.5
1.7
1.94
212.72
255.3
1.27
DR124-101-R
100
95.1
1.5
1.79
256.67
308.0
1.17
DR124-121-R
120
111
1.3
1.65
311.18
373.4
1.08
DR124-151-R
150
146
1.3
1.44
371.02
445.2
0.94
DR124-181-R
180
179
1.1
1.30
501.66
602.0
0.87
DR124-221-R
220
216
1.0
1.15
558.00
669.6
0.77
DR124-271-R
270
256
0.88
1.09
725.00
870.0
0.71
DR124-331-R
330
327
0.83
0.92
825.00
990.0
0.63
DR124-471-R
470
460
0.68
0.74
1242.50
1491.0
0.53
DR124-681-R
680
669
0.56
0.65
1845.83
2215.0
0.45
DR124-821-R
820
825
0.53
0.62
2109.17
2351.0
0.40
DR124-102-R
1000
998
0.44
0.53
2898.00
3477.00
0.37
1. Open Circuit Inductance Test Parameters: 100 kHz, 0.25 V, 0.0 Adc.
2. Irms: DC current for an approximate ∆T of 40 °C without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow,
and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not
exceed +125 °C under worst case operating conditions verified in the end
application.
3. Isat Amps peak for approximately 25% rolloff (@ +25 °C).
2
www.eaton.com/electronics
DCR
mΩ @20°C
Typ
DCR
mΩ @ +20°C
Max
Rated
Inductance
(μH)
K-factor4
4. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K*L*∆I, Bp-p (mT), K: (K factor from table), L: (Inductance in μH),
∆I (Peak to peak ripple current in Amps).
5. Part Number Definition: DR124-xxx-R
- DR124 = Product code and size; -xxx = Inductance value in uH;
- R = decimal point; If no R is present, third character = # of zeros.
- “-R” suffix = RoHS compliant
DR124
Technical Data 4141
Dimensions- mm
FRONT VIEW
BOTTOM VIEW
TOP VIEW
RECOMMENDED PCB LAYOUT
SCHEMATIC
2.05
Typ.
13.8
5.00 1
Typ
2
4.5
Max
12.50
Max
1
1
12.50
Max
DR124-###
wwllyy R
2
5.50
2
10
3.85
wwlly = Date code, R = Revision level.
Dimensions are in millimeters.
Do not route traces or vias underneath the inductor.
Packaging- mm
1.5 dia
+0.1/-0.0
1.5 dia
min
A
1.75
4.0
12.6
Bo
11
DR124-###
wwllyy R
Ao=13.2 mm
Bo=13.2 mm
A1=10mm
B1=10 mm
Ko=5.2 mm
B1
A1
Ao
Ko
16.0
SECTION A-A
24.0
A
User direction of feed
Parts packaged on 13" Diameter reel, 750 parts per reel.
Temperature rise vs. total loss
120
Temperature Rise (°C)
100
80
60
40
0.8
1.2
1.6
2
Total Pow er Loss (W)
3
Technical Data 4141
DR124
Core loss vs. Bp-p
100
1 MHz
10
500 kHz
100 kHz
1
Core Loss (W)
300 kHz
200 kHz
0.1
0.01
0.001
0.0001
1
10
100
1000
Bp-p (m T)
Inductance characteristics
OCL vs. Isat
120.0
100.0
-40 °C
% OCL
80.0
+25 °C
60.0
+85 °C
40.0
20.0
0.0
0.0
20.0
40.0
60.0
% Isat
4
80.0
100.0
120.0
DR124
Technical Data 4141
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“DR124-220-R”相匹配的价格&库存,您可以联系我们找货
