Technical Data 10277
Effective October 2017
Supersedes August 2014
HCMA1305
Automotive grade
High current power inductors
Applications
Product features
Body electronics
• Central body control module
Vehicle access control system
Headlamps, tail lamps and interior lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• Basic and smart surround, and rear and front
view camera
Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system/Car black
box system
AEC-Q200 qualified
High current carrying capacity
Low core losses
Magnetically shielded, low EMI
Frequency range up to 5 MHz
Digital instrument cluster
Inductance range from 0.1 μH to 33 μH
In-vehicle infotainment (IVI) and navigation
Current range from 5.2 A to 118 A
13.8 mm x 12.5 mm footprint surface
mount package in a 5.0 mm height
Iron powder core material
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
Chassis and safety electronics
• Airbag control unit
Electronic Stability Control system (ESC)
Electric parking brake
Electronic Power Steering (EPS)
Environmental Data
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCMA1305
Automotive grade high current power inductors
Product Specifications
DCR (mΩ)
@ +20 °C
nominal
DCR (mΩ)
@ +20 °C
maximum
K-factor5
118
0.52
0.59
848
51
110
0.63
0.72
843
0.21
42
80
0.80
0.92
506
0.30
38
65
0.80
0.92
506
0.56
0.36
36
55
1.15
1.33
500
0.68
0.44
34
54
1.15
1.33
500
HCMA1305-R82-R
0.82
0.52
31
53
1.40
1.61
358
HCMA1305-1R0-R
1.00
0.64
29
50
2.10
2.42
275
HCMA1305-1R5-R
1.50
0.96
23
48
2.75
3.16
225
HCMA1305-1R8-R
1.80
1.15
21
40
4.00
4.60
216
HCMA1305-2R2-R
2.20
1.41
4.60
5.29
191
HCMA1305-3R3-R
3.30
2.11
15
32
7.70
9.20
170
HCMA1305-4R7-R
4.70
3.01
12
27
11.0
12.7
161
HCMA1305-5R6-R
5.60
3.58
11.5
22
12.0
13.8
142
HCMA1305-6R8-R
6.80
4.35
11
21
13.0
15.0
129
HCMA1305-7R8-R
7.80
4.99
10
18.5
16.8
19.4
117
HCMA1305-8R2-R
8.20
5.25
9.5
18
17.5
20.1
117
HCMA1305-100-R
10.0
6.40
9.0
16
19.0
21.9
90
HCMA1305-150-R
15.0
9.60
7.7
13
29.0
33.4
74
HCMA1305-220-R
22.0
14.1
6.2
10
45.0
51.8
63
HCMA1305-330-R
33.0
21.1
5.2
8
74.5
85.5
48
OCL1
(μH) ± 20%
FLL2 Min.
(μH)
Irms3
(A)
Isat4
(A)
HCMA1305-R10-R
0.10
0.064
55
HCMA1305-R22-R
0.22
0.14
HCMA1305-R33-R
0.33
HCMA1305-R47-R
0.47
HCMA1305-R56-R
HCMA1305-R68-R
Part Number6
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc,
+25 °C.
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, @ +25 °C.
3. Irms: DC current for an approximate temperature rise of 40 °C without core
loss. Derating is necessary for AC currents. PCB layout, trace thickness and
width, air-flow, and proximity of other heat generating components will affect
the temperature rise. It is recommended that the temperature of the part not
exceed +125 °C under worst case operating conditions verified in the end
application.
2
www.eaton.com/electronics
4. Isat: Peak current for approximately 20% rolloff at +25 °C.
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I.
Bp-p: (Gauss), K: (K-factor from table), L: (Inductance in μH),∆I (Peak to peak
ripple current in amps).
6. Part Number Definition: HCMA1305-yyy-R
- HCMA1305 = Product code and size
yyy= Inductance value in μH, R = decimal point,
if no R is present then third character equals number of zeros.
“-R” suffix = RoHS compliant
HCMA1305
Dimensions- mm
Top View
13.3±0.5
Side View
5.0 max.
Bottom View
Recommended Pad Layout
Schematic
2.54±0.3
3.3
12.2±0.3
4.0±0.5
AXXX
wlyy R
7.7 typ.
8.5 typ.
14.2
4.9
Part Marking: A = Automotive grade, xxx = Inductance value in µH, R = decimal point, if no R is present, third character equals number of zeros, wlyy = (Date Code),
R = (Revision Level) All soldering surfaces to be coplanar within 0.10 millimeters.
Tolerances are ±0.3 millimeters unless stated otherwise.
Color: Grey.
Do not route traces or vias underneath the inductor
AXXX
wlyy R
Packaging information- mm
Drawing not to scale
Supplied in tape and reel packaging , 400 parts per 13” diameter reel
3
HCMA1305
Temperature rise vs. total loss
50.0
Temperature Rise (°C)
40.0
30.0
20.0
10.0
0.0
0.0
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
Total Loss (W)
Core loss vs Bp-p
10000
1MHz
500KHz
300KHz
200KHz
100KHz
Core Loss (mW)
1000
100
10
1
100
1000
Bp-p (Gauss)
4
10000
HCMA1305
Inductance characteristics
HCMA1305-R22-R
110%
100%
100%
90%
90%
% of OCL
% of OCL
HCMA1305-R10-R
110%
80%
70%
70%
60%
60%
50%
50%
40%
80%
40%
60
80
100
120
140
60
80
100
120
140
Idc (A)
Idc (A)
HCMA1305 -R33-R
110%
100%
90%
90%
% of OCL
100%
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
60
Idc (A)
80
100
120
HCMA1305 -R56-R
110%
90%
90%
% of OCL
100%
80%
70%
60
80
Idc (A)
100
120
HCMA1305 -R68-R
110%
100%
% of OCL
% of OCL
HCMA1305 -R47-R
110%
80%
70%
60%
60%
50%
50%
40%
40%
60
Idc (A)
80
100
120
40
50
60
70
80
Idc (A)
5
HCMA1305
HCMA1305 -R82-R
110%
HCMA1305 -1R0-R
110%
100%
90%
90%
% of OCL
% of OCL
100%
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
40
50
60
70
10
Idc (A)
HCMA1305-1R5-R
110%
90%
90%
% of OCL
100%
% of OCL
100%
70%
70
80%
70%
50%
50%
40%
40%
10
15
30
Idc (A)
35
40
45
50
55
5
10
100%
90%
90%
% of OCL
100%
70%
30
35
40
45
50
55
60
HCMA1305-3R3-R
110%
80%
15
Idc (A)
HCMA1305-2R2-R
110%
% of OCL
60
60%
60%
80%
70%
60%
60%
50%
50%
40%
40%
10
15
Idc (A)
6
50
HCMA1305-1R8-R
110%
80%
40
Idc (A)
30
35
40
45
50
10
15
Idc (A)
30
35
40
45
50
HCMA1305
HCMA1305-4R7-R
100%
100%
90%
90%
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
10
15
Idc (A)
25
30
90%
90%
80%
80%
% of OCL
100%
70%
60%
50%
50%
40%
40%
10
15
2
4
6
90%
90%
% of OCL
% of OCL
100%
80%
70%
8
10
50%
50%
6
8
10
12
14
Idc (A)
16
18
24
26
14
16
18
24
26
18
24
26
70%
60%
40%
12
80%
60%
4
30
HCMA1305 -100-R
110%
100%
2
25
Idc (A)
HCMA1305 -8R2-R
HCMA1305 -7R8-R
Idc (A)
110%
15
70%
60%
5
10
110%
100%
Idc (A)
HCMA1305 -6R8-R
110%
% of OCL
HCMA1305-5R6-R
110%
% of OCL
% of OCL
110%
40%
4
6
8
10
12
14
Idc (A)
16
7
HCMA1305
HCMA1305 -150-R
110%
90%
90%
% of OCL
100%
% of OCL
100%
80%
70%
70%
50%
50%
40%
40%
4
2
8
10
12
14
16
18
Idc (A)
HCMA1305 -330-R
110%
100%
90%
% of OCL
80%
60%
60%
80%
70%
60%
50%
40%
HCMA1305 -220-R
110%
2
4
6
8
Idc (A)
10
12
14
16
18
4
6
8
Idc (A)
10
12
14
16
18
HCMA1305
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCMA1305-100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.36726
- 200+0.91617
- 400+0.88398
- 800+0.86800
- 国内价格 香港价格
- 400+7.62542400+0.95625
- 800+7.19057800+0.90171
- 1200+6.947981200+0.87129
- 2000+6.654372000+0.83447
- 2800+6.467882800+0.81109
- 4000+6.276124000+0.78704
- 10000+5.8711110000+0.73625
- 国内价格 香港价格
- 1+11.571521+1.45109
- 10+9.4988210+1.19117
- 25+8.7875825+1.10198
- 50+8.2844550+1.03889
- 100+7.81120100+0.97954
