RG1005N-59R0-C-T10
RG1005N-59R0-C-T10
    SUSUMU
    贴片电阻 0402 59Ω ±0.25% 1/16W ±10ppm/℃
RG1005N-59R0-C-T10 数据手册
Metal thin film chip resistors (the highest precision) ■RG series AEC-Q200 Compliant Features ・ Long term stability with inorganic passivation ・ Less than ±0.1% drift after 10000 hours of reliability test Thin film surface mount resistors ・ High precision resistance tolerance: ±0.05%, very small TCR: ±5ppm/℃ ・ Thin film structure enabling low noise and anti-sulfur Applications ・ Automotive electronics ・ Industrial measurement instrumentation, industrial machines RG series ・ Various sensors, medical electronics ◆Part numbering system RG 1608 N - 102 - B - T5 Series code Packaging quantity: T5(5,000pcs), T10(10,000pcs) Size: RG1005, RG1608, RG2012, RG3216 Resistance tolerance Temperature coefficient of resistance Nominal resistance value (E-24: 3 digit, E-96: 4 digit, RG3216: all 4 digit) ◆Electrical Specification Type Low RG1005 Temperature coefficient of resistance Power ratings 1/32W Regular 1/16W High 1/8W (ppm/°C) Resistance range(Ω)Resistance tolerance(%) ±5(V) 100≦R<3k ±10(N) 47≦R≦100k ±25(P) 47≦R≦150k ±100(R) ー ±5(V) RG1608 1/16W 1/10W 1/6W 1/10W 1/8W 1/4W ±10(N) 1/8W 1/4W ー 47≦R≦274k ±50(Q) ー 75V T10 10≦R<47 ー Pakaging quantity T5 100V 47≦R≦1M 10≦R<47 ー E-24, E-96 -55℃ ~ 155℃ 100≦R<10.2k ±10(N) 47≦R≦475k ±25(P) 47≦R≦475k ±50(Q) ー T5 150V 47≦R≦2.7M 10≦R<47 ー 100≦R≦33.2k ±10(N) 47≦R≦1M ±25(P) 47≦R≦5.1M ±50(Q) Operating temperature ±0.5%(D) 47≦R≦274k ±25(P) ±5(V) RG3216 Resistance value series 100≦R<5.1k ±5(V) RG2012 ±0.1% (B) ±0.05% (W) Maximum voltage ー 200V 10≦R<47 ー ◆Dimensions L Type W a t b 15 Size (inch) L W a b t RG1005 0402 1.00+0.1/−0.05 0.50±0.05 0.20±0.10 0.25±0.05 0.35±0.05 RG1608 0603 1.60±0.20 0.80±0.20 0.30±0.20 0.30±0.20 0.40±0.10 RG2012 0805 2.00±0.20 1.25±0.20 0.40±0.20 0.40±0.20 0.40±0.10 RG3216 1206 3.20±0.20 1.60±0.20 0.50±0.25 0.50±0.20 0.40±0.10 (unit:mm) ◆Reliability specification Test Items Low 2.5 x rated voltage, 5 seconds Short time overload *1 70℃, rated voltage, 90min on 30min off, 1000hours Life (biased) High Typical ≦47Ω ≧47Ω ≦47Ω ≧47Ω ≦47Ω ±0.10% ±0.05% ±0.10% ±0.05% ー ±0.10% ±(0.01%) ±0.25% ±0.10% ±0.50% ±0.25% ー ±0.50% ±(0.01%) ±0.25% ±0.10% ±0.50% ±0.25% ー ±0.50% ±(0.05%) Condition (test methods) *1 Regular ≧47Ω Low 85℃, 85%RH, 1/10 of rated power, High temperature high humidity 90min on 30min off, 1000hours -55℃ (30min) ∼ 125℃ (30min) 1000cycles ±0.25% ±0.10% ±0.25% ±0.10% ー ±0.10% ±(0.01%) High temperature exposure 155℃, no bias, 1000hours ±0.25% ±0.10% ±0.25% ±0.10% ー ±0.10% ±(0.01%) Resistance to soldering heat 260±5℃, 10 seconds (reflow) ±0.1% ±0.1% ±0.1% ±0.1% ー ±0.1% ±(0.01%) *1 Rated voltage is given by E= RxP E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W) If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage. ◆10000 hour reliability test data 0.50 0.20 0.10 Resistance drift(%) 0.30 0.00 −0.10 −0.20 1kΩ 10kΩ 56kΩ −0.30 −0.40 −0.50 100 10 Test duration(h) 1000 100kΩ 330kΩ 3000 0.10 0.00 −0.10 −0.20 −0.50 10000 0.20 0.00 −0.10 −0.20 −0.30 Test duration(h) 1000 3000 100kΩ 330kΩ 10000 High temperature exposure(155℃) −0.40 Number of cycles 1000 Sample : RG1608series Test Temperature155℃ conditions: n=100 0.40 0.30 0.20 0.10 0.00 −0.10 −0.20 1kΩ 10kΩ 56kΩ −0.30 56kΩ 100kΩ 100 100 10 0.50 0.10 10 1kΩ 10kΩ 56kΩ ○High temperature exposure Resistance drift(%) Resistance drift(%) 0.20 −0.40 Sample : RG1608series Test -55℃ (30min) →room temp (. 3min) → conditions: +125℃ (30min) →room temp (. 3min) n=50 0.30 −0.50 0.30 Temperature shock 0.40 Sample : RG1608series Test Temperature85℃ Humidity85%RH conditions: 1/10 rated power 90min.on/30min. off Rated power=0.1W n=100 0.40 −0.30 ○Temperature shock 0.50 High temperature high humidity bias (THB 85℃ 85%) 0.50 Sample : RG1608series Test Temperature85℃ conditions: Rated voltage 90 min. on/30min. off Rated power=0.1W n=100 0.40 Resistance drift(%) ○High temperature high humidity (biased) High temoperature life test (85℃) RG series ○Biased life test −0.40 −0.50 10000 10 100 Test duration(h) 1000 3000 100kΩ 330kΩ 10000 Ratio to rated power (%) ◆Derating Curve High power application Regular power application High precision 100 50 0 -55 0 50 155 70 85 100 Ambient temperature (℃) ◆Maximum pulse power limit Maximum pulse power limit(W) 100 Test procedure Voltage pulse is applied to the test samples mounted 10 1 0.1 0.0001 on the test board. 1005 1608 2012 3216 After each pulse, resistance drift is measured. Pulse type type type type 0.001 voltage is increased until the drift exceeds +/-0.5%. The power at that voltage is defined as the 0.01 0.1 Pulse duration (seconds) 1 10 Thin film surface mount resistors Temperature shock maximum pulse power. 16
RG1005N-59R0-C-T10
1. 物料型号:RG系列,包括RG1005, RG1608, RG2012, RG3216等尺寸。
2. 器件简介:SUSUMU的RG系列是薄膜表面贴装电阻器,具有高精度和长期稳定性,采用无卤素和符合RoHS标准的材料,符合AEC-Q200标准。
3. 引脚分配:文档中未明确提供引脚分配信息,但通常表面贴装电阻器不需要引脚分配
4. 参数特性: - 电阻公差:±0.05% (W级),±0.1% (B级),±0.5% (D级) - 温度系数:±5ppm/℃ - 额定功率:根据不同尺寸有1/32W, 1/16W, 1/8W, 1/6W, 1/10W, 1/4W等不同等级 - 最大电压:75V至200V不等 - 工作温度范围:-55°C至155°C
5. 功能详解:RG系列电阻器具有长期稳定性、低噪声、抗硫性等特点,适合用于汽车电子、工业测量仪器、各种传感器、医疗电子等领域。
6. 应用信息:适用于汽车电子、工业测量仪器、工业机器、各种传感器、医疗电子等。
7. 封装信息:提供T5(5,000pcs)和T10(10,000pcs)的包装数量,具体尺寸和封装信息如下: - RG1005: 0402尺寸,1.00±0.10mm x 0.50±0.05mm - RG1608: 0603尺寸,1.60±0.20mm x 0.80±0.20mm - RG2012: 0805尺寸,2.00±0.20mm x 1.25±0.20mm - RG3216: 1206尺寸,3.20±0.20mm x 1.60±0.20mm
RG1005N-59R0-C-T10 价格&库存
很抱歉,暂时无法提供与“RG1005N-59R0-C-T10”相匹配的价格&库存,您可以联系我们找货
