Technical Data 10906
Effective April 2019
HCM1A1707V2
Automotive grade
High current power inductors
Applications
Product features
AEC-Q200 qualified
High current carrying capacity
Magnetically shielded, low EMI
DC-DC converter applications up to 1 MHz
Filtering applications up to Self Resonant
Frequency (SRF) [See product specification
table]
Inductance range from 1.0 μH to 68 μH
Current range from 5.0 A to 27 A
17.45 mm x 17.15 mm footprint surface mount
package in a 7.0 mm height
Moisture Sensitivity Level (MSL): 1
Alloy powder core material
Body electronics
• Central body control module
Headlamps, tail lamps and interior lighting and
LED lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system/ Car black
box system
Infotainment and cluster electronics
• Audio subsystem: head unit and trunk amp
Digital instrument cluster
In-vehicle infotainment (IVI) and navigation
Chassis and safety electronics
• Airbag control unit
Electronic stability control system (ESC)
Electric parking brake
Electronic power steering (EPS)/
Anti-locking braking system (ABS)
Engine and Powertrain Systems
• Electric pumps, motor control and auxiliaries
Powertrain control module (PCU)/
Engine Control unit (ECU)
Transmission Control Unit (TCU)
Environmental data
Storage temperature range (Component):
-55 °C to +155 °C
Operating temperature range: -55 °C to +155 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCM1A1707V2
Automotive grade High current power inductors
Product specifications
Part number6
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
SRF (MHz)
typical
K-factor5
HCM1A1707V2-1R0-R
1.0
0.64
36
57
1.24
1.46
34
110
HCM1A1707V2-1R5-R
1.5
0.96
23
41
1.94
2.24
25
93
HCM1A1707V2-2R2-R
2.2
1.41
22
31
2.25
2.41
18
82
HCM1A1707V2-3R3-R
3.3
2.11
19.5
28
3.00
3.27
15
80
HCM1A1707V2-4R7-R
4.7
3.01
18
27
4.10
4.72
12
59
HCM1A1707V2-6R8-R
6.8
4.35
14
7.16
9
58
HCM1A1707V2-8R2-R
8.2
5.25
12.5
8.7
8
46
HCM1A1707V2-100-R
10
6.40
12
17
8.94
10
6
42
HCM1A1707V2-150-R
15
9.60
11.8
11
12.6
15.5
5
30
HCM1A1707V2-220-R
22
14.1
7.7
11.5
21.0
22.2
5
25
HCM1A1707V2-330-R
33
21.1
6.2
9
34.8
37
3
19
HCM1A1707V2-470-R
47
30.1
5.5
8
39.9
46
2
17
HCM1A1707V2-680-R
68
43.5
5.0
6.8
55.5
60
2
16
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, , +25 °C
3. Irms: DC current for an approximate temperature rise of 30 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +155 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM1A1707V2-xxx-R
HCM1A1707V2 = Product code and size
xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Schematic
1
2
Part marking: 1A1707V2, XXX=inductance value in uH, R=decimal point. If no R is present then last character equals number of zeros.
xxxx=Lot code
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.3 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
HCM1A1707V2
Packaging information (mm)
Drawing not to scale
1A1707V2
xxx
xxxx
Supplied in tape and reel packaging, 200 parts per 13” diameter reel
Section A-A
Section B-B
User direction of unreeling
Core loss vs Bp-p
HCM1A1707V2-1R5-R
HCM1A1707V2-1R0-R
10000
10000
700 kHz
500 kHz
300 kHz
100 kHz
1000
Core Loss (mW)
Core Loss (mW)
50 kHz
100
10
1
50 kHz
100
10
1
0.1
0.1
0.01
700 kHz
500 kHz
300 kHz
100 kHz
1000
0.01
100
1000
1000
100
Bp-p (Gauss)
Bp-p (Gauss)
HCM1A1707V2-3R3-R
HCM1A1707V2-2R2-R
10000
10000
700 kHz
500 kHz
300 kHz
100 kHz
50 kHz
100
Core Loss (mW)
Core Loss (mW)
1000
10
1
100 kHz
50 kHz
100
10
1
0.1
0.1
0.01
700 kHz
500 kHz
300 kHz
1000
0.01
100
1000
Bp-p (Gauss)
100
1000
Bp-p (Gauss)
3
HCM1A1707V2
Core loss vs Bp-p
HCM1A1707V2-4R7-R
HCM1A1707V2-6R8-R
10000
700 kHz
500 kHz
300 kHz
100
10
1
0.1
700 kHz
500 kHz
300 kHz
1000
100 kHz
50 kHz
Core Loss (mW)
Core Loss (mW)
1000
0.01
10000
100 kHz
50 kHz
100
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
1000
100
Bp-p (Gauss)
HCM1A1707V2-8R2-R
HCM1A1707V2-100-R
10000
700 kHz
500 kHz
300 kHz
1000
100
10
1
0.1
0.01
700 kHz
500 kHz
300 kHz
1000
100 kHz
50 kHz
Core Loss (mW)
Core Loss (mW)
10000
100 kHz
50 kHz
100
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
Bp-p (Gauss)
HCM1A1707V2-150-R
HCM1A1707V2-220-R
10000
Core Loss (mW)
Core Loss (mW)
100
10
1
700 kHz
500 kHz
300 kHz
1000
100 kHz
50 kHz
0.1
100 kHz
50 kHz
100
10
1
0.1
100
1000
Bp-p (Gauss)
4
10000
700 kHz
500 kHz
300 kHz
1000
0.01
1000
100
0.01
1000
100
Bp-p (Gauss)
HCM1A1707V2
Core loss vs Bp-p
HCM1A1707V2-330-R
HCM1A1707V2-470-R
10000
700 kHz
500 kHz
300 kHz
100
10
1
0.1
700 kHz
500 kHz
300 kHz
1000
100 kHz
50 kHz
Core Loss (mW)
Core Loss (mW)
1000
0.01
10000
100 kHz
50 kHz
100
10
1
0.1
100
0.01
1000
Bp-p (Gauss)
1000
100
Bp-p (Gauss)
HCM1A1707V2-680-R
10000
700 kHz
500 kHz
300 kHz
Core Loss (mW)
1000
100 kHz
50 kHz
100
10
1
0.1
0.01
100
1000
Bp-p (Gauss)
5
HCM1A1707V2
Inductance and impedance vs. frequency
HCM1A1707V2-1R0-R
5
HCM1A1707V2-1R5-R
10000
12
10000
4.5
100
Impedance
2.5
10
2
1.5
1
0.1
1
8
Impedance
10
4
1
2
Inductance
0.1
0.1
100
100
6
1
Inductance
0.5
1000
Impedance (Ohm)
3
Inductance (uH)
3.5
1000
Impedance (Ohm)
Inductance (uH)
4
1
10
Frequency (MHz)
100
0.1
Frequency (MHz)
HCM1A1707V2-3R3-R
HCM1A1707V2-2R2-R
8
100
Impedance
6
10
4
2
Inductance (uH)
10
1
10
100
Frequency (MHz)
1000
Impedance
10
5
0.1
Inductance
0.1
HCM1A1707V2-4R7-R
0.1
10000
100
15
10
1
5
Inductance
0.1
1
10
Frequency (MHz)
100
0.1
35
Impedance
30
100
25
10
1
10
5
Inductance
0.1
1
10
Frequency (MHz)
100
0.1
Impedance (Ohm)
Impedance
Inductance (uH)
25
1000
40
Impedance (Ohm)
Inductance (uH)
100
50
1000
30
6
Frequency (MHz)
10
45
35
HCM1A1707V2-6R8-R
10000
40
100
15
1
Inductance
0.1
10000
25
1000
Impedance (Ohm)
Inductance (uH)
12
10000
Impedance (Ohm)
14
HCM1A1707V2
HCM1A1707V2-100-R
HCM1A1707V2-8R2-R
10000
80
10
30
Inductance
0.1
1
10
100
Frequency (MHz)
50
10
40
30
1
10
Inductance
0.1
1
100
100
80
10
60
40
Inductance
0.1
1
10
Frequency (MHz)
100
100
100
10
50
1
Inductance
0.1
HCM1A1707V2-330-R
Inductance (uH)
1000
Impedance
100
100
10
50
1
Inductance
10
Frequency (MHz)
100
0.1
Impedance (Ohm)
10000
200
1
10
Frequency (MHz)
100
450
0.1
100000
400
10000
350
Inductance (uH)
100000
0.1
1
HCM1A1707V2-470-R
250
150
1000
Impedance
150
1
200
Inductance (uH)
Impedance
Impedance (Ohm)
Inductance (uH)
100000
250
1000
120
HCM1A1707V2-220-R
10000
140
Frequency (MHz)
HCM1A1707V2-150-R
160
10
300
1000
Impedance
250
100
200
10
150
100
1
50
Impedance (Ohm)
10
100
60
Impedance (Ohm)
100
Impedance
70
Impedance (Ohm)
Impedance
40
1000
80
Inductance (uH)
50
Impedance (Ohm)
1000
60
Inductance (uH)
10000
90
70
Inductance
0.1
1
10
100
0.1
Frequency (MHz)
7
HCM1A1707V2
HCM1A1707V2-680-R
1000
100000
900
Inductance (uH)
700
Impedance
600
1000
100
500
400
10
300
200
Inductance
100
Impedance (Ohm)
10000
800
0.1
1
10
100
Frequency (MHz)
0.1
Inductance and temperature rise vs. current
HCM1A1707V2-1R0-R
0.80
80
70
Inductance
0.60
60
0.50
50
0.40
40
0.30
30
Temperature rise
0.10
0.00
60
10
80
Idc (A)
100
120
1.40
1.20
70
60
0.80
50
0.60
40
30
0.40
0.00
50
40
30
Temperature rise
30
40
Idc (A)
10
50
50
60
Idc (A)
70
80
90
70
80
90
3.0
80
Inductance
2.5
OCL (uH)
70
Inductance
Temperature rise (℃)
OCL (uH)
8
80
3.5
90
10
30
10
HCM1A1707V2-3R3-R
100
Temperature rise
HCM1A1707V2-2R2-R
2.40
2.20
2.00
1.80
1.60
1.40
1.20
1.00
0.80
0.60
0.40
0.20
0.00
80
1.00
0.20
Inductance
70
2.0
60
1.5
40
50
30
1.0
0.0
Temperature rise
0.5
Idc (A)
30
10
40
50
0.20
100
1.60
90
OCL (uH)
100
0.90
1.00
0.70
OCL (uH)
HCM1A1707V2-1R5-R
HCM1A1707V2
HCM1A1707V2-4R7-R
4.50
90
4.00
80
3.00
60
2.50
50
2.00
40
1.50
30
1.00
Temperature rise
Idc (A)
30
40
50
60
3.0
40
50
30
2.0
10
90
7.0
80
Inductance
60
5.0
50
4.0
40
3.0
30
2.0
Temperature rise
10
15
Idc (A)
25
10
30
35
40
10
9
8
7
6
5
4
3
2
1
80
12
Inductance
70
60
8
50
6
40
30
4
Temperature rise
4
6
8
10 12 14 16 18 20 22 24
Idc (A)
30
35
40
80
70
Inductance
60
50
40
30
Temperature rise
10
15
10
Idc (A)
30
35
25
90
80
OCL (uH)
100
14
2
Idc (A)
25
HCM1A1707V2-220-R
16
10
HCM1A1707V2-150-R
OCL (uH)
70
OCL (uH)
100
8.0
9.0
1.0
15
10
HCM1A1707V2-100-R
HCM1A1707V2-8R2-R
6.0
Temperature rise
0.00
4.0
1.0
10
70
Inductance
15
60
50
40
10
Temperature rise
5
30
10
0.50
80
Inductance
5.0
OCL (uH)
70
90
6.0
Inductance
100
7.0
100
3.50
OCL (uH)
HCM1A1707V2-6R8-R
5.00
4
6
8
Idc (A)
9
HCM1A1707V2
HCM1A1707V2-330-R
35
100
90
Inductance
OCL (uH)
25
70
60
15
40
30
10
5
Temperature rise
4
6
8
10
Idc (A)
12
14
16
18
OCL (uH)
70
60
30
40
50
30
Temperature rise
4
6
8
10
10
Idc (A)
12
14
16
18
80
Inductance
2
40
15
30
10
100
70
60
10
60
80
Inductance
30
5
70
10
90
35
HCM1A1707V2-680-R
50
100
45
40
OCL (uH)
80
30
50
Temperature rise
4
6
8
10
Idc (A)
10
12
14
16
18
HCM1A1707V2-470-R
HCM1A1707V2
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM1A1707V2-2R2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+19.49833200+2.53120
- 国内价格 香港价格
- 200+22.63909200+2.93893
