SLM43328A-R51MHF
SLM43328A-R51MHF
    ITG
    SMD,10x8mm
    固定电感器 Nonstandard 510nH ±20% 29A 0.93mΩ
SLM43328A-R51MHF 数据手册
SLM40328 Series 1. Features: · Ferrite based SMD inductor with lower core loss. · Inductance range: 400.00 nH to 710.00 nH, custom values are welcomed. · High current output chokes, up to 40.00 Amp with approx. 20% roll off. · Low profile 8.00 mm Max. height. · 10.00 x 8.00 mm Foot Print. · Ideal for Buck Converter, VRM & High Density Board Design. · Operating frequency up to 1.0 MHz. · Operating Temperature Range -55°C to + 130°C , RoHs & HF compliant . · T & R Qtys: 450 pcs ,13'' Reel. 2. Electrical Characteristic of SLM40328 Series: OCL 1 (nH) L @ Isat1 2 (nH) DCR 3 (mΩ) Isat1 4 (A) Isat2 4 (A) Isat3 4 (A) Irms 5 (A) ± 20% Min.@25℃ ± 8.0% @25℃ @75℃ @100℃ @25℃ SLM40328A-R39MHF 400.00 288.00 0.85 40.00 37.00 34.00 31.00 SLM40328A-R47MHF 470.00 338.40 0.85 33.00 30.00 28.00 31.00 SLM40328A-R56MHF 550.00 396.00 0.85 27.00 25.00 23.50 31.00 SLM40328A-R72MHF 710.000 511.20 0.85 21.00 19.50 18.00 31.00 ITG Part Number 3. Mechanical Dimension (Unit:mm): B C D E F G Max. Max. Max. Max. Nom. ± 0.20 ± 0.30 8.00 8.70 8.00 10.00 4.75 D B Marking A 2.50 2.50 F C a A E Side View b Glue G Bottom View 4.20 2x3.00 2x3.15 Suggested Pad Layout Notes: 1> Open Circuit Inductance (OCL) test condition: 100KHz, 0.1Vrms, 0Adc at 25℃. 2> L @ Isat and L @ Irms test condition: 100KHz, 0.1Vrms (Ta=25Ԩ). 3> The nominal DCR is measured from point" a " to point" b ", as shown above on the mechanical drawing (Ta=25℃). 4> Isat1,Isat2 & Isat3 : DC current that will cause inductance to drop approximately by 20%. 5> Irms: DC current for an approximate temperature rise of 40℃ without core loss. Derating is necessary for AC currents. PCB pad layout, trace thickness and width,air-flow and proximity of other heat generating components will affect the temperature rise. It is recommended the part temperature not exceed 130°C under worst case operating conditions as verified in the end application. US 1 914 347 2474 ●Taiwan 886 972 022 388 ●Shenzhen 86 755 8418 6263 ●Shanghai 86 21 5424 5141 ●HK 852 9688 9767 Sales@inter-technical.com www.inter-technical.com Rev. A, Aug.27, 2014 C H F A N T O M P L I C H F A N T O M P L I SLM40328 Series Inductance vs. Current L (nH) 4. Inductance Characteristics (Inductance vs. Current): SLM40328A-R39MHF 450.0 400.0 350.0 300.0 250.0 200.0 150.0 100.0 50.0 0.0 25Ԩ 75Ԩ 100Ԩ L (nH) 0.0 10.0 20.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 41.0 42.0 43.0 44.0 45.0 46.0 47.0 Direct Current (A) SLM40328A-R47MHF 520.0 468.0 416.0 364.0 312.0 260.0 208.0 156.0 104.0 52.0 0.0 25Ԩ 75Ԩ 100Ԩ L (nH) 0.0 10.0 15.0 20.0 25.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 Direct Current (A) SLM40328A-R56MHF 605.0 550.0 495.0 440.0 385.0 330.0 275.0 220.0 165.0 110.0 55.0 0.0 25Ԩ 75Ԩ 100Ԩ 0.0 L (nH) 5.0 5.0 10.0 15.0 20.0 22.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 31.0 32.0 33.0 34.0 35.0 Direct Current (A) SLM40328A-R72MHF 800.0 720.0 640.0 560.0 480.0 400.0 320.0 240.0 160.0 80.0 0.0 25Ԩ 75Ԩ 100Ԩ 0.0 5.0 8.0 10.0 12.0 14.0 16.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 Direct Current (A) US 1 914 347 2474 ●Taiwan 886 972 022 388 ●Shenzhen 86 755 8418 6263 ●Shanghai 86 21 5424 5141 ●HK 852 9688 9767 Sales@inter-technical.com www.inter-technical.com Rev. A, Aug.27, 2014
SLM43328A-R51MHF 价格&库存
很抱歉,暂时无法提供与“SLM43328A-R51MHF”相匹配的价格&库存,您可以联系我们找货
