SLC1615A-R022LHF
SLC1615A-R022LHF
    ITG
    SMD
    固定电感器 SMD-2 22nH ±10% 22A 0.23mΩ
SLC1615A-R022LHF 数据手册
RoHS COMPLIANT SLC1615 Series HF COMPLIANT 1. Features: · Ferrite based SMD Inductor with lower core loss. · Inductance Range:22.0nH to 10.0nH,Custom values are welcomed. · High current output chokes, upto 60.0 Amp with approx. 20% roll off. · Low Profile 3.9mm Max. height . · Foot Print 4.0 x 4.0 mm Max. · Ideal for Buck Converter, VRM & High Density Board Design. · Operating frequency up to 1 MHz application. · Operating Temperature Range -55°C to + 130°C , RoHs & HF compliance . · T & R Qtys: 2000 pcs , 13'' Reel ; 2. Electrical Characteristic of SLC1615 Series: Inductance DCR Isat1 Isat2 Isat3 Irms (nH) (mΩ) (A) (A) (A) (A) +10%/-30% ± 9.0% @25℃ @75℃ @100℃ @25℃ SLC1615A-R022LHF 22.00 0.23 60.00 58.00 55.00 22.00 SLC1615B-R01MHF 10.00 0.22 80.00 74.00 70.00 25.00 Part Number D B C A B C D E F G Max. Max. Max. Max. Nom. Nom. Nom. 4.00 3.95 3.90 4.00 1.40 1.40 1.35 F A 3. Mechanical Dimension(Unit:mm): Marking E 2XG 2X1.9 0.90 2X1.7 a b Suggested Pad Layout Note: 1>.Open Circuit Inductance (OCL) test condition:100KHz,0.1Vrms,0Adc ,at 25 ℃. 2>.Full Load Inductance (FLL) Test condition:100KHz,0.1Vrms ,Isat ;(Ta=25 ℃). 3>.Isat1,Isat2 & Isat3 : DC current that will cause inductance to drops approximately by 20% ; 4>. Irms: DC current for an approximate temperature rise of 40℃ without core loss,.Derating is necessary for AC currents. PCB pad layout,trace thickness and width,air-flow and proximity of other heat generating components will affect the temperature rise. It is recommended the part temperature not exceed 130°C under worst case operating conditions verified in the end application. 5>.The nominal DCR is measured from point "a" to point"b",as shown above on the mechanical drawing. 4. Inductance Characteristics (Inductance vs. Current): US 1 914 347 2474 ●Taiwan 886 972 022 388 ●Shenzhen 86 755 8418 6263 ●Shanghai 86 21 5424 5141 ●HK 852 9688 9767 Sales@inter-technical.com www.inter-technical.com , Rev.D, Dec.20, 2012 SLC1615 Series RoHS COMPLIANT HF COMPLIANT Inductance vs. Current SLC1615x-R022LHF 24.40 21.35 18.30 25Ԩ L (nH) 15.25 12.20 75Ԩ 9.15 6.10 100Ԩ 3.05 0.00 0.0 10.0 20.0 30.0 40.0 50.0 Direct Current (A) 55.0 60.0 65.0 70.0 SLC1615x-R01MHF 12.00 10.00 25Ԩ L (nH) 8.00 6.00 75Ԩ 4.00 100Ԩ 2.00 0.00 0.0 20.0 40.0 60.0 70.0 72.0 74.0 76.0 80.0 82.0 84.0 85.0 88.0 Direct Current (A) US 1 914 347 2474 ●Taiwan 886 972 022 388 ●Shenzhen 86 755 8418 6263 ●Shanghai 86 21 5424 5141 ●HK 852 9688 9767 Sales@inter-technical.com www.inter-technical.com , Rev.D, Dec.20, 2012
SLC1615A-R022LHF 价格&库存
很抱歉,暂时无法提供与“SLC1615A-R022LHF”相匹配的价格&库存,您可以联系我们找货
