SD3814-151-R
SD3814-151-R
    EATON(伊顿)
    固定电感器 Nonstandard 150µH ±15% 191mA 4.359Ω
SD3814-151-R 数据手册
Technical Data 4318 Effective October 2017 Supersedes March 2007 SD38 Low profile metalized shielded drum core power inductors Applications . d d n lete a ) ep 2 2 V 1 8 is d 123 D ry 25 S ( o PI t 6 n 1 ve M 0 r 2 in , o y l l i u nt 14 J u SD e r v ti ) o 2, c fe 814 2-V t. f E 3 n 1 , e d SD I40 m e e u 6( c P n i t 01 M pla n o t 2 iew re c s Di gus rev nate Au ease alter Pl an as • • • • • • • SMD Device Environmental data • Product features • • • • • 3.8 mm x 3.8 mm shielded drum cores available 1.2 mm and 1.4 mm heights Current range from 0.1 A to 4.4 A Inductance range from 0.47 uH to 680 uH Ferrite shielded, low EMI Ferrite core material Mobile phones Digital cameras Media players Small LCD displays LED driver and LED flash circuits Hard disk drives LCD Backlighting • • Storage temperature range (component): -40 °C to +125 °C Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) Solder reflow temperature: J-STD-020 (latest revision) compliant SD38 Low profile metalized shielded drum core power inductors Technical Data 4318 Effective October 2017 Product specifications Part Number SD3812-R47-R SD3812-1R0-R SD3812-1R2-R SD3812-1R5-R SD3812-2R2-R SD3812-3R3-R SD3812-4R7-R SD3812-6R8-R SD3812-8R2-R SD3812-100-R SD3812-150-R SD3812-220-R SD3812-330-R SD3812-470-R SD3812-680-R SD3812-820-R SD3812-101-R SD3812-151-R SD3812-221-R SD3814-R47-R SD3814-R82-R SD3814-1R2-R SD3814-1R5-R SD3814-2R2-R SD3814-3R3-R SD3814-4R7-R SD3814-6R8-R SD3814-8R2-R SD3814-100-R SD3814-150-R SD3814-220-R SD3814-330-R SD3814-470-R SD3814-680-R SD3814-820-R SD3814-101-R SD3814-151-R SD3814-221-R SD3814-331-R SD3814-471-R SD3814-681-R Rated Inductance (µH) 0.47 1.0 1.2 1.5 2.2 3.3 4.7 6.8 8.2 10.0 15.0 22.0 33.0 47.0 68.0 82.0 100.0 150.0 220.0 0.47 0.82 1.2 1.5 2.2 3.3 4.7 6.8 8.2 10.0 15.0 22.0 33.0 47.0 68.0 82.0 100.0 150.0 220.0 330.0 470.0 680.0 OCL (1) +/-15% (µH) 0.405 0.845 1.125 1.445 2.205 3.125 4.805 6.845 8.405 10.125 15.125 21.125 32.805 47.045 68.445 80.645 99.405 149.645 218.405 0.360 0.752 1.001 1.286 1.962 2.781 4.276 6.768 8.228 9.830 14.458 21.186 32.151 47.210 67.324 81.101 98.794 149.026 217.342 326.812 470.031 680.320 Part Marking Designator A B C D E F G H I J K L M N O P Q R S A B C D E F G H I J K L M N O P Q R S T U V Irms (2) (A) Isat (3) (A) 2.53 2.00 1.71 1.58 1.32 1.10 0.87 0.80 0.690 0.662 0.539 0.499 0.399 0.327 0.269 0.259 0.217 0.178 0.160 2.81 2.18 1.85 1.76 1.43 1.31 1.06 0.87 0.753 0.713 0.574 0.519 0.418 0.346 0.285 0.270 0.228 0.191 0.170 0.136 0.111 0.100 3.89 2.69 2.33 2.06 1.67 1.40 1.13 0.95 0.854 0.778 0.636 0.538 0.432 0.361 0.299 0.276 0.248 0.202 0.167 4.44 3.08 2.67 2.35 1.90 1.60 1.29 1.03 0.930 0.851 0.702 0.580 0.471 0.388 0.325 0.296 0.268 0.219 0.181 0.148 0.123 0.102 DCR (4) (Ω) Typ. 0.030 0.048 0.066 0.078 0.111 0.159 0.256 0.299 0.406 0.441 0.665 0.776 1.212 1.809 2.666 2.885 4.099 6.130 7.585 0.020 0.033 0.046 0.051 0.077 0.093 0.141 0.207 0.279 0.311 0.481 0.589 0.908 1.322 1.951 2.174 3.048 4.359 5.480 8.59 12.85 15.78 Volt (5) u-sec Typ. 2.52 3.64 4.20 4.76 5.88 7.0 8.7 10.4 11.5 12.6 15.4 18.2 22.7 27.2 32.8 36 39 48 59 2.16 3.12 3.60 4.08 5.04 6.0 7.4 9.4 10.3 11.3 13.7 16.6 20.4 24.7 29.5 32 36 44 53 65 78 94 . d d n lete a ) ep 2 2 V 1 8 is d 123 D ry 25 S ( o PI t 6 n 1 ve M 0 r 2 in , o y l l i u nt 14 J u SD e r v ti ) o 2, c fe 814 2-V t. f E 3 n 1 , e d SD I40 m e e u 6( c P n i t 01 M pla n o t 2 iew re c s Di gus rev nate Au ease alter Pl an as (1) Test Parameters: 100 kHz, 0.100 Vrms, 0.0 Adc. (2) RMS current for an approximate ∆T of 40 °C without core loss. It is recommended that the temperature of the part not exceed +125 °C. De-rating is necessary for AC currents. (3) Peak current for approximately 30% rolloff at +20 °C. 2 www.eaton.com/electronics (4) DCR limits @ +20 °C. (5) Applied Volt-Time product (V-us) across the inductor at 100 kHz necessary to generate a core loss equal to 10% of the total losses for 40 °C temperature rise. De-rating of the Irms is required to prevent excessive temperature rise. SD38 Low profile metalized shielded drum core power inductors Technical Data 4318 Effective October 2017 Dimensions- mm SD3812 BOTTOM VIEW TOP VIEW SIDE VIEW 4.8 MA X 3.65 typ Pin #1 indicator Marking (see note A) 1.2 max 0.09 max no plating 1.25 ±0.12 . d d n lete a ) ep 2 2 V 1 8 is d 123 D ry 25 S ( o PI t 6 n 1 ve M 0 r 2 in , o y l l i u nt 14 J u SD e r v ti ) o 2, c fe 814 2-V t. f E 3 n 1 , e d SD I40 m e e u 6( c P n i t 01 M pla n o t 2 iew re c s Di gus rev nate Au ease alter Pl an as 2.03 ±.02 4.0 max 4.0 max 0.415 min RECOMMENDED PCB LAYOUT SCHEMATIC 1.0 2 plcs 2.5 2plcs 4.0 typ 5.0 Note A: 3 digit marking. First digit indicates inductance value per chart above. Second digit indicates bi-weekly date code. Third digit of year produced. Box indicates SD3814 part. Do not route traces or vias underneath the inductor SD3814 TOP VIEW SIDE VIEW Pin #1 indicator Marking (see note A) BOTTOM VIEW 4.8 MA X 3.65 typ 0.09 max no plating 1.4 max 1.25 ±0.12 2.03 ±.02 4.0 max 4.0 max 0.415 min RECOMMENDED PCB LAYOUT 1.0 2 plcs SCHEMATIC 2.5 2 plcs 4.0 typ 5.0 Note A: 3 digit marking. First digit indicates inductance value per chart above. Second digit indicates bi-weekly date code. Third digit of year produced. Box indicates SD3814 part. Do not route traces or vias underneath the inductor www.eaton.com/electronics 3 SD38 Low profile metalized shielded drum core power inductors Technical Data 4318 Effective October 2017 Packaging information- mm 4.00 2.00 ± 0.05 1.5 Dia min. 1.5 Dia. +0.1/-0.0 1.75 Ao=5.1mm Bo=4.6mm Ko=1.6mm 12.0 +/-0.3 Bo 5.50 4.5 4.5 . d d n lete a ) ep 2 2 V 1 8 is d 123 D ry 25 S ( o PI t 6 n 1 ve M 0 r 2 in , o y l l i u nt 14 J u SD e r v ti ) o 2, c fe 814 2-V t. f E 3 n 1 , e d SD I40 m e e u 6( c P n i t 01 M pla n o t 2 iew re c s Di gus rev nate Au ease alter Pl an as Ao Ko Parts packaged on 13" Diameter reel, 4,150 parts per reel. 8.0 SECTION A-A Direction of feed Core loss % of Losses from Irms (maximum) Irms DERATING WITH CORE LOSS % of Applied Volt-µsecond Inductance characteristics OCL vs Isat SD3814 OCL vs Isat SD3812 100 90 OCL (%) 80 OCL (%) 70 60 50 40 30 20 10 0 20 10 0 0 0 10 20 30 40 50 60 70 % of Isat 4 100 90 80 70 60 50 40 30 www.eaton.com/electronics 80 90 100 110 120 130 10 20 30 40 50 60 70 80 90 10 11 12 13 14 15 16 0 0 0 0 0 0 0 % of Isat SD38 Low profile metalized shielded drum core power inductors Technical Data 4318 Effective October 2017 Solder Reflow Profile TP tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s TC -5°C Table 1 - Standard SnPb Solder (Tc) Volume mm3 220°C 220°C . d d n lete a ) ep 2 2 V 1 8 is d 123 D ry 25 S ( o PI t 6 n 1 ve M 0 r 2 in , o y l l i u nt 14 J u SD e r v ti ) o 2, c fe 814 2-V t. f E 3 n 1 , e d SD I40 m e e u 6( c P n i t 01 M pla n o t 2 iew re c s Di gus rev nate Au ease alter Pl an as Temperature TL 25°C Preheat A T smax t Table 2 - Lead (Pb) Free Solder (T c) Tsmin ts Package Thickness 2.5mm Time 25°C to Peak Volume mm3 2000 260°C 245°C 245°C Time Reference JDEC J-STD-020 Profile Feature Preheat and Soak • Temperature min. (Tsmin) • Temperature max. (Tsmax) • Time (Tsmin to Tsmax) (ts) Average ramp up rate Tsmax to Tp Liquidous temperature (TL) Time at liquidous (tL) Peak package body temperature (TP)* Time (tp)** within 5 °C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25°C to Peak Temperature Standard SnPb Solder 100°C Lead (Pb) Free Solder 150°C 150°C 200°C 60-120 Seconds 60-120 Seconds 3°C/ Second Max. 3°C/ Second Max. 183°C 60-150 Seconds 217°C 60-150 Seconds Table 1 Table 2 20 Seconds** 30 Seconds** 6°C/ Second Max. 6°C/ Second Max. 6 Minutes Max. 8 Minutes Max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Compan . Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant inju y to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 4318 October 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
SD3814-151-R 价格&库存
很抱歉,暂时无法提供与“SD3814-151-R”相匹配的价格&库存,您可以联系我们找货
